VM801P50A-PL
VM801P50A-PL
    BRIDGETEK
    MODULE FT801 5.0 LCD PRL BZL
VM801P50A-PL 数据手册
VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.:FT_001102 Clearance No.: FTDI#426 FTDI Chip VM801P Datasheet Embedded Video Engine Plus Module General Purpose Multi Media Controller The VM801P is a development module for FTDI’s FT801, which is used to develop and demonstrate the functionality of the FT801 Embedded Video Engine, EVE. The VM801P is a stand-alone display system which has a flash based microcontroller on board, thus providing a fully integrated display system ready to go. The VM801P supports many I/O daughter cards or shields for expanding external interfacing and control. These shields use 1 or 2 Micro-MaTch miniature connectors to interface to the VM801P main module. Users will be able to purchase shields from FTDI Chip in the coming months, or alternatively can build their own shield for specific applications. The VM801P series of modules support 2 different LCD panel size options and are designed for industrial or commercial environments with precision fitted bezels in either black (-BK) or pearl (-PL).  VM801P43A-xx is the 4.3” LCD  VM801P50A-xx is the 5.0” LCD The VM801P utilises the FTDI FT801 Embedded Video Engine, EVE. Graphic, audio and capacitive touch features of the FT801 chip can be accessed with the VM801P. For a full list of the FT801’s features please see the FT801 datasheet. The VM801P module has the following features:  FT801 for graphics, audio and touch processing  ATMEGA328P system microcontroller operating at 5V/16MHz supporting Arduino libraries  5 point Capacitive Touch screen LCD panel  Backlight LED driver  Audio power amplifier and micro speaker  FT232R USB serial port for firmware upgrade  Micro-SD socket for application storage, including 4GByte SD Card pre-loaded with sample applications  Battery backed Real Time Clock  2x Micro-MaTch miniature connectors for daughter card expansion  5V power supply from micro-USB or battery connector  Precision fitted bezel in black(-BK) or pearl (-PL) Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Future Technology Devices International Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Future Technology Devices International Ltd, Unit 1, 2 Seaward Place, Centurion Business Park, Glasgow G41 1HH United Kingdom. Scotland Registered Company Number: SC136640 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 1 Ordering Information Part No. Description VM801P43A-BK FT801 Display System, ATMEG328P @ 5V/16MHz, Micro-SD socket, 4.3” 480x272 resolution TFT LCD with capacitive touch panel, black case VM801P50A-BK FT801 Display System, ATMEG328P @ 5V/16MHz, Micro-SD socket, 5.0” 480x272 resolution TFT LCD with capacitive touch panel, black case VM801P43A-PL FT801 Display System, ATMEG328P @ 5V/16MHz, Micro-SD socket, 4.3” 480x272 resolution TFT LCD with capacitive touch panel, pearl case VM801P50A-PL FT801 Display System, ATMEG328P @ 5V/16MHz, Micro-SD socket, 5.0” 480x272 resolution TFT LCD with capacitive touch panel, pearl case ACCESSORIES VA800A-PROG Accessory - PLUS Production Programmer for ATMEGA328P inc Tag Connect TC2030-IDC-FP cable VA-PSU-UK1 Accessory - UK Model 5V/1A USB Power Supply ( Mfr # JX-B0520C-1-B ) VA-PSU-US1 Accessory - US Model 5V/1A USB Power Supply ( Mfr # JX-B0520B-1-B ) VA-PSU-EU1 Accessory - EU Model 5V/1A USB Power Supply ( Mfr # JX-B0520A-1-B ) VA-FC-1M-BKW Accessory - Flat USB A to Micro B Cable 1M- Black and White VA-FC-1M-BLW Accessory - Flat USB A to Micro B Cable 1M- Blue and White VI800A-TTLU VI800A UART TTL module, plug in board to VM800P Plus module VI800A-232U VI800A RS232 module, plug in board to VM800P Plus module VI800A-N485U VI800A RS485 module, plug in board for the VM800P Plus module VI800A-RELAY VI800A Opto-isolated Inputs and RELAY output module, plug in board to VM800P Plus module VI800A-ETH VI800A Ethernet module, plug in board for the VM800P Plus module VI800A-PoE VI800A POE Ethernet module, plug in board for the VM800P Plus module Table 1.1 VM801P & Accessory Ordering Information Copyright © 2014 Future Technology Devices International Limited 1 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Table of Contents 1 Ordering Information ...................................................................................................................... 1 2 Hardware Description ..................................................................................................................... 4 2.1 Physical Description ................................................................................................................ 5 2.1.1 2.2 CN1 - 2-pin power connector .......................................................................................... 5 2.2.2 CN2 – Micro USB Receptacle .......................................................................................... 6 2.2.3 J2 – Audio Selection ........................................................................................................ 6 2.2.4 J5 – Expansion Connector for I/O Daughter Card ........................................................... 6 2.2.5 J6 - Expansion Connector for Comm Daughter Card ...................................................... 7 2.2.6 JP1 – Audio Amplifier Power Selection ........................................................................... 8 2.2.7 SW1 – 5V Power Source Selection .................................................................................. 8 2.2.8 JP4 – USB Power Selection .............................................................................................. 8 5 6 7 Board Schematics .................................................................................................................... 9 Hardware Setup Guide .................................................................................................................. 13 3.1 4 Connectors and Jumpers......................................................................................................... 5 2.2.1 2.3 3 Dimensions...................................................................................................................... 5 Power Configuration ............................................................................................................. 13 Arduino® Setup .............................................................................................................................. 14 4.1 Hardware Setup .................................................................................................................... 14 4.2 Software Setup...................................................................................................................... 14 Assembling the Bezel and Panel Mounting .................................................................................. 17 5.1 Dimensions for 4.3” Bezel ..................................................................................................... 18 5.2 Dimensions for 5.0” Bezel ..................................................................................................... 19 Specifications ................................................................................................................................ 20 6.1 LCD Optical Specifications for 4.3” Panel.............................................................................. 20 6.2 LCD Optical Specifications for 5.0” Panel.............................................................................. 21 Contact Information...................................................................................................................... 22 Appendix A – References ...................................................................................................................... 23 Document References....................................................................................................................... 23 Acronyms and Abbreviations ............................................................................................................ 23 Copyright © 2014 Future Technology Devices International Limited 2 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Appendix B – List of Tables & Figures ................................................................................................... 24 List of Tables ..................................................................................................................................... 24 List of Figures .................................................................................................................................... 24 Appendix C – Revision History .............................................................................................................. 25 Copyright © 2014 Future Technology Devices International Limited 3 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 2 Hardware Description Figure 2-1 VM801P43A/VM801P50A Module Top and Bottom View NOTE: The above modules are also available with pearl coloured bezels. The VM801P module is available for different LCD sizes: 4.3” or 5”. Each VM801P module is assembled with the following parts:    HW_362_VM801P PCB board LCD panel with capacitive touch screen Bezel The main functions of the VM801PxxA module are as follows:             FT801 EVE for graphic, audio and capacitive touch control ATMEGA328P microcontroller operating at 5V and 16MHz, controlling the FT801 and other peripheral interfaces 3 stage audio filter 8Ω micro speaker to work with on-board audio amplifier Jumper selection allowing audio line out option LCD backlight LED driver Real Time Clock(RTC) with button battery USB interface for power supply and firmware programming 2-pin JST connector for alternative power source 3.3V regulator: takes 5V input and outputs 3.3V for on-board circuits 2x Micro-MaTch miniature connectors for various daughter card expansion SD Card Socket (4GByte card supplied with module) Copyright © 2014 Future Technology Devices International Limited 4 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 2.1 Physical Description The VM801P module dimensions are illustrated in Figure 2.2. 2.1.1 Dimensions 46.2 61.2 23.2 68.6 64.8 5 3.8 102.8 106.7 Figure 2-2 VM801P43A/VM801P50A Dimensions (Top view) ±0.50mm Tolerance All dimensions are in mm 2.2 Connectors and Jumpers Connectors and jumpers are described in the following sections. 2.2.1 CN1 - 2-pin power connector Pin No. Name Type Description 1 VCC P 5V DC power supply 2 GND P Ground Table 2.1 CN1 - Power Pin-out Copyright © 2014 Future Technology Devices International Limited 5 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 2.2.2 Clearance No.: FTDI#426 CN2 – Micro USB Receptacle Pin No. Name Type Description 1 VBUS P 5V power supply 2 D- IO USB D- line 3 D+ IO USB D+ line 4 NC NA No connection 5 GND P Ground Table 2.2 CN2 – Micro USB Pin-out 2.2.3 J2 – Audio Selection Select between audio line-out or connection to the power amplifier. Jumper position Description Short pin 1-2 Audio amp enabled (default) Short pin 2-3 Audio amp mute, Audio lineout on pin 1 Table 2.3 J2 – Audio Options 2.2.4 J5 – Expansion Connector for I/O Daughter Card This 16-pin Micro-MaTch miniature connector provides ATmega328P SPI/I2C/IO control to a daughter card. 5V and 3.3V power supplies are also available. Pin No. Name Type Description 1 SCK O SPI Clock output 2 MOSI O SPI Master Out Slave in 3 MISO I SPI Master In Slave out 4 IO7 O SPI slave select 5 INT0 I Interrupt input from DC 6 IO6 O Active LOW reset output to DC 7 AD4 IO I2C SDA data input/output 8 AD5 O I2C SCL clock output 9 3V3 P 3.3V power supply to DC 10 5V P 5V power supply to DC Copyright © 2014 Future Technology Devices International Limited 6 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Pin No. Name Type 11 GND P Ground 12 RST# O System reset output 13 IO5 IO GPIO 14 AD0 IO GPIO 15 AD7 AI ADC input 16 AD6 AI ADC input Clearance No.: FTDI#426 Description Table 2.4 J5 - I/O Expansion Connector Pin-out 2.2.5 J6 - Expansion Connector for Comm Daughter Card This 16-pin Micro MaTch Miniature connector provides ATmega328P SPI/I2C/IO control to the daughter card. 5V and 3.3V power supplies are also available. Pin No. Name Type Description 1 SCK O SPI Clock output 2 MOSI O SPI Master Out Slave in 3 MISO I SPI Master In Slave out 4 SS O SPI salve select 5 INT0 I Interrupt input from DC 6 IO6 O Active LOW reset output to DC 7 AD4 IO I2C SDA data input/output 8 AD5 O I2C SCL clock output 9 3V3 P 3.3V power supply to DC 10 5V P 5V power supply to DC 11 GND P Ground 12 RST# O System reset output 13 AD1 IO GPIO 14 IO4 IO GPIO 15 AD3 AI GPIO 16 AD2 AI GPIO Table 2.5 J5 - Communication Expansion Connector Pin-out Copyright © 2014 Future Technology Devices International Limited 7 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 2.2.6 Clearance No.: FTDI#426 JP1 – Audio Amplifier Power Selection This jumper provides the option to select the power supply voltage for the on-board power amplifier. Jumper position Description Short pin 1-2 3.3V selected (default) Short pin 2-3 5V selected Table 2.6 JP1 - Audio Amplifier Power Pin Options NOTE: This needs to be configured before audio can be heard. Default is 3.3V. Select 5V to increase the maximum volume for the speaker. 2.2.7 SW1 – 5V Power Source Selection Jumper position Description Short pin 1-2 Board power from CN1 Short pin 2-3 Board power from CN2 (default) Table 2.7 SW1 - Power Source Selection 2.2.8 JP4 – USB Power Selection Jumper position Description Open Enable USB power to application circuits when FT232R is enumerated (Default). USB power will be turned off during USB suspend Short USB power always enabled Table 2.8 JP4 - USB Power Selection Copyright © 2014 Future Technology Devices International Limited 8 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 2.3 Board Schematics Figure 2-3 Schematics: FT801 with LED driver and LCD/CTP interface Note: J10 is not mounted Copyright © 2014 Future Technology Devices International Limited 9 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Figure 2-4 Schematics: Audio filter and amplifier Copyright © 2014 Future Technology Devices International Limited 10 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Figure 2-5 Schematics: ATMEGA328P with USB and I0 Connectors Copyright © 2014 Future Technology Devices International Limited 11 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Figure 2-6 Schematics: SD socket and RTC Note: U12 is not mounted Copyright © 2014 Future Technology Devices International Limited 12 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 3 Hardware Setup Guide 3.1 Power Configuration There are 2 methods of powering the VM801P board. 1) USB Power(5V) - Connect USB power through micro-USB cable to CN2 2) DC IN(5V) - Connect 5V to CN1 The following table summarizes how to power the VM801P board using the various methods. Power Method CN1 CN2 USB Power N/C 5V DC IN(5V) 5V 5V SW1 Short pin 2-3 (default) Short pin 1-2 Table 3.1 Board Power Configuration Copyright © 2014 Future Technology Devices International Limited 13 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 4 Arduino® Setup FTDI provides sample source code, sample application notes and a ready to run demo based on the Arduino® platform. Detailed information can be found at: http://www.ftdichip.com/Support/Documents/AppNotes/AN_318_Arduino_Library_for_FT801_Seri es.pdf http://www.ftdichip.com/Support/Documents/AppNotes/AN_275_FT801_Example_with_Arduino.pd f http://www.ftdichip.com/Support/Documents/AppNotes/AN_246%20VM801CB_SampleApp_Arduin o_Introduction.pdf 4.1 Hardware Setup   Connect a USB cable (suggest FTDI accessory VA-FC-1M-BKW or VA-FC-1M-BLW) from the VM801P USB port CN2 to the PC USB host port or self-powered hub port. The USB will supply power to the VM801P module after the FTDI FT232R driver is properly loaded and the USB host completes USB device configuration. 4.2 Software Setup The arduino code can be downloaded from the Arduino IDE to the ATMEGA328P through the USB connector CN2 connected to the PC. The USB connector CN2 is also used to display debug output from the ATMEGA328P to the PC terminal application. Default sample code is downloaded to the ATMEGA328P during the VM801P module manufacturing. When the VM801P is connected to the PC through the USB connector CN2, the VM801P is powered up and the sample code is functional with the demo applications.     Download the Arduino IDE from http://arduino.cc/en/main/software. Install the Arduino IDE Open the Arduino IDE Open the FT801 sample project to be downloaded to the VM801P (Examples are available from: http://www.ftdichip.com/Support/SoftwareExamples/FT800_Projects.htm Or you may have developed your own code)    Select the Tools->Board-> Arduino Pro or Pro Mini(5V, 16MHz) w/ATmega328 as shown in Fig 4.1. Select the Tools->Serial Port->COMxx corresponding to the VM801P as shown in Fig 4.2. Click the Upload button as shown in Fig 4.3. This will upload the FT801 sample to the VM801P. Copyright © 2014 Future Technology Devices International Limited 14 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Figure 4-1 Select Board Figure 4-2 Select Serial Port (NOTE: Your device may not be COM22 as shown. Select the COM port you have installed) Copyright © 2014 Future Technology Devices International Limited 15 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Figure 4-3 Click Upload Button Copyright © 2014 Future Technology Devices International Limited 16 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 5 Assembling the Bezel and Panel Mounting Figure 5-1 VM801P Panel Mount (Front view) Figure 5-2 VM801P Panel Mount (Rear view) Copyright © 2014 Future Technology Devices International Limited 17 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 5.1 Dimensions for 4.3” Bezel Figure 5-3 VM801P43A panel mount dimensions Copyright © 2014 Future Technology Devices International Limited 18 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 5.2 Dimensions for 5.0” Bezel Figure 5-4 VM801P50A panel mount dimensions Copyright © 2014 Future Technology Devices International Limited 19 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 6 Specifications 6.1 LCD Optical Specifications for 4.3” Panel Figure 6-1 4.3” TFT Optical Specifications Copyright © 2014 Future Technology Devices International Limited 20 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 6.2 LCD Optical Specifications for 5.0” Panel Figure 6-2 5.0" TFT Optical Specifications Copyright © 2014 Future Technology Devices International Limited 21 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 7 Contact Information Head Office – Glasgow, UK Branch Office – Tigard, Oregon, USA Future Technology Devices International Limited Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Future Technology Devices International Limited (USA) 7130 SW Fir Loop Tigard, OR 97223-8160 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com E-Mail (Sales) E-Mail (Support) E-Mail (General Enquiries) us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Taipei, Taiwan Branch Office – Shanghai, China Future Technology Devices International Limited (Taiwan) 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8791 3570 Fax: +886 (0) 2 8791 3576 Future Technology Devices International Limited (China) Room 1103, No. 666 West Huaihai Road, Shanghai, 200052 China Tel: +86 21 62351596 Fax: +86 21 62351595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com System and equipment manufacturers and designers are responsible to ensure that their systems, and any Future Technology Devices International Ltd (FTDI) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested FTDI devices and other materials) is provided for reference only. While FTDI has taken care to assure it is accurate, this information is subject to customer confirmation, and FTDI disclaims all liability for system designs and for any applications assistance provided by FTDI. Use of FTDI devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless FTDI from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Future Technology Devices International Ltd, Unit 1, 2 Seaward Place, Centurion Business Park, Glasgow G41 1HH, United Kingdom. Scotland Registered Company Number: SC136640 Copyright © 2014 Future Technology Devices International Limited 22 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Appendix A – References Document References For module documentations, please refer to URL below: http://www.ftdichip.com/Products/modules/VM801P.html FT801 datasheet: DS_FT801 FT801 software programming guide: FT800_Series_Programmers_Guide AN_318: Arduino Library for FT800 Series AN_275 : FT800 Example with Arduino AN_246: VM800CB SampleApp_Arduino Introduction AN_299: FT800 FT801 Internal Clock Trimming AN_333: FT800 and FT801 Touch Capabilities Acronyms and Abbreviations Terms CTP Description Capacitive Touch Panel IO Input Output I2C Inter Integrated Circuit LCD Liquid Crystal Display LED Light-Emitting Diode RTC Real Time Clock SD Card Secure Digital Card SPI Serial Peripheral Interface USB Universal Serial Bus Copyright © 2014 Future Technology Devices International Limited 23 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Appendix B – List of Tables & Figures List of Tables Table 1.1 VM801P & Accessory Ordering Information ............................................................... 1 Table 2.1 CN1 - Power Pin-out .............................................................................................. 5 Table 2.2 CN2 – Micro USB Pin-out........................................................................................ 6 Table 2.3 J2 – Audio Options ................................................................................................ 6 Table 2.4 J5 - I/O Expansion Connector Pin-out ...................................................................... 7 Table 2.5 J5 - Communication Expansion Connector Pin-out ..................................................... 7 Table 2.6 JP1 - Audio Amplifier Power Pin Options ................................................................... 8 Table 2.7 SW1 - Power Source Selection ................................................................................ 8 Table 2.8 JP4 - USB Power Selection ..................................................................................... 8 Table 3.1 Board Power Configuration ................................................................................... 13 List of Figures Figure 2-1 VM801P43A/VM801P50A Module Top and Bottom View ............................................ 4 Figure 2-2 VM801P43A/VM801P50A Dimensions (Top view) ..................................................... 5 Figure 2-3 Schematics: FT801 with LED driver and LCD/CTP interface ....................................... 9 Figure 2-4 Schematics: Audio filter and amplifier .................................................................. 10 Figure 2-5 Schematics: ATMEGA328P with USB and I0 Connectors .......................................... 11 Figure 2-6 Schematics: SD socket and RTC .......................................................................... 12 Figure 4-1 Select Board ..................................................................................................... 15 Figure 4-2 Select Serial Port ............................................................................................... 15 Figure 4-3 Click Upload Button ........................................................................................... 16 Figure 5-1 VM801P Panel Mount (Front view) ....................................................................... 17 Figure 5-2 VM801P Panel Mount (Rear view) ........................................................................ 17 Figure 5-3 VM801P43A panel mount dimensions ................................................................... 18 Figure 5-4 VM801P50A panel mount dimensions ................................................................... 19 Figure 6-1 4.3” TFT Optical Specifications ............................................................................ 20 Figure 6-2 5.0" TFT Optical Specifications ............................................................................ 21 Copyright © 2014 Future Technology Devices International Limited 24 VM801P Embedded Video Engine Plus Module Datasheet Version 1.0 Document Reference No.: FT_001102 Clearance No.: FTDI#426 Appendix C – Revision History Document Title: VM801P Embedded Video Engine Plus Module Datasheet Document Reference No.: FT_001102 Clearance No.: FTDI#426 Product Page: www.ftdichip.com/Products/Modules/VM801P.html Document Feedback: Send Feedback Revision 1.0 Changes First release Date 2014-11-25 Copyright © 2014 Future Technology Devices International Limited 25
VM801P50A-PL 价格&库存
很抱歉,暂时无法提供与“VM801P50A-PL”相匹配的价格&库存,您可以联系我们找货
