B2102UDUG20C000133U1930 数据手册
Side View Chip LED
Harvatek Surface Mount CHIP LEDs Approval Sheet
Official Product
HT Part No. B2102UDUG20C000133U1930
Tentative Product
Specifications are subject to changes for improvement
without advance notice. Proprietary data, drawings, and
company confidential all rights reserved.
03/12/2021
Version of 1.3
Page 1/14
Side View Chip LED
DISCLAIMER ........................................................................................................................................ 3
PRODUCT SPECIFICATION .............................................................................................................. 4
ATTENTION: ELECTRICSTATIC DISCHARGE (ESD) PROTECTION............................................... 4
LABEL SPEC.: ....................................................................................................................................... 5
PRODUCT SPECIFICATIONS............................................................................................................ 6
PRODUCT FEATURE .......................................................................................................................... 7
ELECTRO-OPTICAL CHARACTERISTICS ..................................................................................... 7
PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW
SOLDERING ............................................................................................................................ 7
ABSOLUTE MAXIMUM RATINGS ................................................................................................ 7
PRECAUTION FOR USE ............................................................................................................ 8
CHARACTERISTICS OF B2102UDUG ....................................................................................... 9
PACKAGING TAPE, REEL, AND PACKING MODEL ................................................................. 10
TAPE DIMENSION .................................................................................................................. 10
REEL DIMENSION .................................................................................................................. 11
PACKING .............................................................................................................................. 11
DRY PACK............................................................................................................................................ 12
BAKING................................................................................................................................ 12
PRECAUTIONS ...................................................................................................................... 12
REFLOW SOLDERING ..................................................................................................................... 13
REWORKING ......................................................................................................................... 13
CLEANING ............................................................................................................................ 13
REVISE HISTORY................................................................................................................... 14
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 2/14
Side View Chip LED
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of
the application or use of any product or circuit described herein; neither does it convey any
license under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices
or systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when
properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to
perform can be reasonably expected to cause the failure of the life support device or system, or
to affect its safety or effectiveness.
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 3/14
Side View Chip LED
Product Specification
Specification
Luminous
UD:45.0-180.0 mcd
Intensity(Iv)
UG:45.0-180.0 mcd
Material
Quantity
@20mA/ Ts= 25℃;Tolerance: + 10%
Wavelength
UD: 600.0-612.0 nm
UG : 567.5-579.5 nm
@20mA/ TS= 25℃;Tolerance: + 0.5nm
Vf
UD: 1.6-2.4 V
UG: 1.6-2.4 V
@20mA/ TS= 25℃ ;Tolerance: + 0.05V
Ir
< 10 µA @ VR = 5 V
Resin
Clear
Epoxy resin
Carrier tape
According to EIA 481-1A specs
Conductive tape
Reel
Plastic/ White
Label
HT standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/ no-zipper
One reel one bag
Carton
HT standard
Paper
Non-specified
3000pcs per reel
Others:
Every mid-box will be loaded 5 reels. These 5 reels can be different in lot, Iv, lambda, or Vf. Every reel will have an
independent label to identify its specification and the mid-box there will have a corresponding label post on it.
ATTENTION: Electricstatic Discharge (ESD) protection
The symbol shown on the page herein to introduce ‘Electro-Optical Characteristics’. ESD protection for GaP
and AlGaAs based chips is still necessary even though they are safe in low static-electric discharge. Parts built
with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD protection has to
considered and taken in the initial design stage.
If manual work/process is needed, please ensure the device is well protected from ESD during all the process.
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 4/14
Side View Chip LED
Label Spec.:
▓Customer P/N: To Be Defined:
B
210
2
UDUG
20C
Product
Dice
Current
PCB
2: Bi
20mA
0001
33
U1930
Taping
1.Taping style
Package
Color
2. Q’ty
Series Number
UD: Orange
Customer Code
Customer Product Code
3.2(L)x1.5(W)x1.0(H) mm
X001~XZZZ
UG: Ultra Bright Yellow Green
X0001~XZZZZ
▓Lot No.
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 5/14
Side View Chip LED
Product specifications
▓Luminous Intensity (Iv) Bin:
Color
Bin Code
Spec. Range
P
45.00-71.50 mcd
Q
71.50-112.5 mcd
R
112.5-180.0 mcd
P
45.00-71.50 mcd
Q
71.50-112.5 mcd
R
112.5-180.0 mcd
UD
UG
Note: It maintains a tolerance of ±10% on luminous intensity
▓Wavelength Bin:
Color
Bin Code
Spec. Range
B
600.0-603.0 nm
C
603.0-606.0 nm
D
606.0-609.0 nm
E
609.0-612.0 nm
C
567.5-570.5 nm
D
570.5-573.5 nm
E
573.5-576.5 nm
F
576.5-579.5 nm
UD
UG
Note: It maintains a tolerance of + 0.5nm on Wavelength Bin
▓Forward Voltage (Vf) Bin:
Color
Bin Code
Spec. Range
UD
E18
1.6-2.4 V
UG
E18
1.6-2.4 V
Note: It maintains a tolerance of ±0.05V on forward voltage measurements
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 6/14
Side View Chip LED
Product Feature
(TSoldering , 25 ℃)
Wavelength λ(nm)
VF(V)
Series
Emitting Color
Material
IV(mcd)
typ
max
λD
λP
△λ
Typical
2.0
2.4
605
611
17
71.5
Viewing
Angle
2
1
2
X=130
AlGalnP
UD
Y=100
B2102UDUG20
X=124
AlGalnP
UG
2.1
2.4
571
573
15
71.5
Y=115
Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering
Unit: mm Tolerance: +/-0.1
Outline Dim.
Suggest
Soldering Pattern
Soldering terminal may shift in x, y direction.
Absolute Maximum Ratings
(TSoldering 25 ℃)
Series
PD (mW)
IF (mA)
IFP (mA)*
TOP (℃)
TST (℃)
Power
Forward
Pulse Forward
Operating
Storage
Dissipation
Current
Current
Temperature
Temperature
UD
48
-40~+85
-40~+100
UG
48
-40~+85
-40~+100
Color
*Condition for IFP is pulse of 1/10 duty and 0.1msec width
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 7/14
Side View Chip LED
Precaution for Use
1. The chips should not be used directly in any type of fluid such as water, oil, organic
solvent, etc.
2. When the LEDs are illuminating, the maximum ambient temperature should be first
considered before operation.
3. LEDs must be stored in a clean environment. A sealed container with a nitrogen
atmosphere is necessary if the storage period is over 3 months after shipping.
4. The LEDs must be used within 4 weeks after unpacked. Unused products must be
repacked in an anti-electrostatic package, folded to close any opening and then stored in
a dry and cool space.
5. The appearance and specifications of the products may be modified for improvement
without further notice.
6. The LEDs are sensitive to the static electricity and surge. It is strongly recommended to
use a grounded wrist band and anti-electrostatic glove when handling the LEDs.
If a voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs.
Damaged LEDs will show some abnormal characteristics such as remarkable increase
of leak current, lower turn-on voltage and getting unlit at low current.
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 8/14
Side View Chip LED
Characteristics of B2102UDUG
Directive Characteristics
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 9/14
Side View Chip LED
Packaging Tape, Reel, and Packing Model
Tape Dimension
Official Product
Dim. A
Dim. B
Dim. C
Q’ty/Reel
3.40±0.10
1.70±0.10
1.20±0.10
3K
Tentative Product
03/12/2021
Version of 1.3
Page 10/14
Side View Chip LED
Reel Dimension
Packing
5 or 10 boxes per carton is available depending on shipment quantity.
Official Product
Tentative Product
03/12/2021
Version of 1.3
Page 11/14
Side View Chip LED
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times
during transportation or storage. Every reel is packaged in a moisture protected anti-static bag.
Each bag is properly sealed prior to shipment.
A humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Baking
Baking before soldering is recommended when the package has been unsealed for 4 weeks.
The conditions are as followings:
1. 60±3℃×(12~24hrs)and
