HV-317664/230/USOSYGM-U1930 数据手册
3.0mm Round LED LAMP with Holder
Harvatek 3.0mm Round LED LAMP with Holder
Official Product
Customer Part No.
Data Sheet No.
Specifications are subject to change without notice. Data
Aug.14 2021
and drawings herein are copyrighted.
Version of 1.0
Page 1/14
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 2/14
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 317664 / 230 / USOSYGM - U1930
Series Name
HV :
HARVATEK
Color Code
Remark
317664:Array 1 Lamp
230:
3.0mm Round LED LAMP.
USOSYG:
AlGaInP 620nm Orange Chip.
AlGaInP 570nm Green Chip.
M:
White Diffused
U1930:
Customer Product
Code
Features:
Stable Color
Popular 3.0mm through hole package.
White Diffused Lens.
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 3/14
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 4/14
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
30
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+85
Soldering Temperature*1
Tsol
260±5
Power Dissipation
Pd
75
mW
Reverse Voltage
VR
5
V
Peak Forward Current*2
IFP
75
mA
*1:Soldering time ≦ 5 seconds. *2:Pulse Width≦ 100μs and Duty≦ 1%
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 5/14
Electrical and Optical Characteristic
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
VF
IF=20 mA
2.0
2.4
V
Reverse Current
IR
VR= 5 V
10
μA
O
10
30
mcd
G
10
30
mcd
O/G
60
deg
O
620
Luminous Intensity
Viewing Angle
Dominant Wavelength
Peak Wavelength
Spectrum Radiation
Bandwidth
IV
2θ1/2
λd
λρ
Δλ
IF=20 mA
IF=20 mA
IF=20 mA
nm
G
570
O
630
IF=20 mA
nm
G
575
O
18
IF=20 mA
nm
G
Notes:θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline
value.
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 6/14
Specifications for Bin Grading:(O)
Iv(mcd)
Grade
Min.
Max.
L
10
M
16
32
N
25
50
P
40
80
Q
63
125
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 7/14
Specifications for Bin Grading:(G)
Iv(mcd)
Grade
Min.
Max.
L
10
M
16
32
N
25
50
P
40
80
Q
63
125
λd(nm)
Grade
Min.
Max.
5
566
569
6
568
571
7
570
573
8
572
575
9
574
577
Notes:
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 8/14
Typical Electro-Optical Characteristics Curve(O)
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 9/14
Typical Electrical / Optical Characteristics Curves(G)
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 10/14
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration
until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
Official Product
2mm Min.(From solder joint to
Distance
Led)
2mm Min. (From solder joint
to Led)
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 11/14
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%
LTPD:3%
Item
Test Conditions
Solder Heat
TEMP:230℃±5
10 SEC
76 PCS
0/1
Temperature Cycle
H:+100℃ 15min
∫ 5min
L:-40℃ 15min
300
CYCLES
76 PCS
0/1
3
Thermal
H:+100℃ 5min
∫ 10sec
L:-10℃ 5min
300
CYCLES
76 PCS
4
High Temperature
Storage
TEMP:100℃
1000 HRS
76 PCS
5
Low Temperature
Storage
TEMP:-40℃
1000 HRS
76 PCS
0/1
6
DC Operating Life
TEMP:25℃
IF=20mA
1000 HRS
76 PCS
0/1
7
High Temperature /
High Humidity
85℃/85%RH
1000 HRS
76 PCS
0/1
No
1
2
Shock
Sample
Size
Failure
Judgment
Criteria
Test
Hours/Cycle
Iv≦Ivt*0.5
or
Vf≧U
or
Vf≦L
Ac/Er
0/1
0/1
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability test
U:Upper Specification Limit
L:Lower Specification Limit
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 12/14
Packing Specification:
CU
TE
TY
DA
ER
Q'
N.
OM
P/
ST
250PCS/Bag
CO
DE
PA
RT
S
/M
PC
ar
XX
Ye
NO
XX
on
th
/D
ay
1000PCS/In-Carton
CU S TO M E R
P / N .:
Q'TY:
DATE CODE:
T O TA L :
PART NO.
XXXXPCS
Year/Month/Day
XXXX PC S
10000PCS/Out-Carton
CUSTOMER
P/N.:
Q'TY:
DATE CODE:
TOTAL:
PART NO.
XXXXPCS
Year/Month/Day
XXXX PCS
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 13/14
Revision History
Revision
Page
Version No.
Revision Date
1.0
08-14-2021
Initial Release
Official Product
Customer Part No.
Data Sheet No.
Aug.14 2021
Version of 1.0
Page 14/14
HV-317664/230/USOSYGM-U1930 价格&库存
很抱歉,暂时无法提供与“HV-317664/230/USOSYGM-U1930”相匹配的价格&库存,您可以联系我们找货
