15DYS836-120333W-2.5 数据手册
15DYS836-xyW-2.5 40W Desktop Series
Universal Input 100~240VAC 50/60Hz
UL/IEC/EN 62368-1 Approved
Compliant to LVD & EMC safety standards
RoHS & CE Directive Compliant
Level VI efficiency
OVP, OCP, OTP & Short Circuit Protection
2.5mm barrel
The purpose of the document is to specify a Single-phase AC input, single output switching power
supply. This specification is suitable for: 15DYS836-xyW-2.5 40W Series. This product is AC to DC
switching power supply, it can provide 5-30V 40W max DC output constant voltage source. This
Specification defines the input, output, performance characteristics, environment, noise and safety
requirements.
Models
Model Number
Output Voltage
Output Current
Output Power
15DYS836-050500W-2.5*
5V DC
5A
25W
15DYS836-075426W-2.5
7.5V DC
4.26A
31.95W
15DYS836-090400W-2.5
9V DC
4A
36W
12V DC
3.33A
40W
15DYS836-150266W-2.5
15V DC
2.66A
40W
15DYS836-180222W-2.5
18V DC
2.22A
40W
15DYS836-240166W-2.5
24V DC
1.66A
40W
15DYS836-300133W-2.5
30V DC
1.33A
40W
Input Data
Min
Input Voltage
Input Frequency
Input Current
Inrush Current
Leakage Current
Typical
90
47
Max
Units
Notes
264
63
1
60
0.25
V AC
Hz
A
A
mA
100-240VAC +/- 10%
50-60Hz +/- 5%
At cold start, 100 / 240V AC
Output Data
Min
Output Voltage tolerance
Ripple & Noise
Over Current Protection
Over Voltage Protection
Typical
Max
Units
6
5
1
Notes
*Tolerance is ± 6%
Over Current Point Limited >2.16A
Continuous short circuit proof. Will recover if fault condition is removed
Ideal Power Limited | 14 Larks Way, Tree Beech Enterprise Park, Gunn, Barnstaple,
Devon, EX32 7NZ, England | www.idealpower.co.uk | +44 (0) 845 260 3400
Environmental Data
Minimum
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Typical
10
5
Maximum
Units
Notes
+40
+80
90
95
ºC
ºC
Operating 10% to 90%
Storage 5% to 95%
Other Information
Minimum
Dielectric Strength
MTBF
Weight
Dimensions
Typical
Maximum
Units
Notes
Primary to Secondary: 4242VDC/5mAMax (3 seconds)
hrs
At 25°C, Full load and nominal
200 +/-10g Depending on model
Refer to mechanical drawings
50,000
EMC Emissions (2014/30/EU)
Conducted
Radiated
Harmonic Standard
Standard
Test Level
Criteria
EN 55032
EN 55032
Pass
Pass
B
B
EN 61000-3-2
Class D
Notes
EMC Directive 2014/30/EU
P.F. shall >0.95 @100Vac input and >0.9 @240Vac input
EMC Immunity (2014/30/EU)
Standard
EMS
EMS
ESD
RS
EFT
Surge
Conducted
PFMF
Dips and Interruptions
EN 55035
EN 61204-3
IEC 61000-4-2
IEC 61000-4-3
IEC 61000-4-4
IEC 61000-4-5
Test Level
Criteria
Notes
B
Contact: +/- 4KV; Air: +/- 8KV
Frequency: 80-1000MHz; Field Strength: 3V/M ' 80% AM (1KHz)
0.5/1.0KV on input AC power ports
Line to Line: +/- 1KV (peak); Line to F.G: +/- 2KV (peak)
A/B
A
Safety Approvals
Safety Standards
RoHS/REACH
CE LVD Directive 2014/35/EU
cULus
TUV
RCM & C-Tick
RoHS Directive (EU) 2015/863 & REACH (205 SVHC)
Yes (UK/European)
Yes
Yes
Yes
Mechanical Drawing
15DYS836-120333W-2.5 价格&库存
很抱歉,暂时无法提供与“15DYS836-120333W-2.5”相匹配的价格&库存,您可以联系我们找货
