RGB Products
RGB Color Changing Flexible Strip
#NB-RGB C
4.5 in. – 473 in.
Select the perfect color to match your mood from a wide array of over
64,000 potential colors. Use with Inspired LED power supply, RGB
Controller, and four conductor cables for a complete system that is
controlled by the wireless remote.
RGB Controller with Wireless Remote
#5014
The Wireless RBG Controller is a sleek, convenient solution to
controlling RBG LED lighting. Choose from 15 different preprogrammed color-changing modes, or simply select a solid color
from the color wheel, by using the remote from us to 65 feet away
from the controller. Turn the entire system on and off with the
remote. When the system is turned back on, the previous setting will
be resumed.
RGB Junction Block – Four Way Angle
#5004
Connect your RGB strips to make a cross or junction block for wiring.
Includes four four-pin female ends.
RGB Junction Block – Right Angle
#5003
Connect your RGB strips to make a right angle turn. Includes two
Four Conductor Interconnect Cable
20 cm Cable #5005
100 cm Cable #5006
250 cm Cable #5007
370 cm Cable #5019
Use to interconnect RGB flexible strips together or connect a four pin
male connector in between this cable and your RGB controller.
Interface Connector for RGB Products – 6 Pack
#5002
Connect female connector to female connector or solder to RGB Flex
to make your own custom lengths.
RGB Products
Mini RGB Controller with RF Remote
#5012
This remote features 19 dynamic modes, 20 static colors, 256 PWM
and adjustable speed and brightness. This card type remote has an
ultra slim design and auto saves settings.
RGB Amplifier
#5013
This strip amplifier makes LED strip implementation more convenient.
Its slim design makes it easy to install LEDs together with strip or
cables even in a very narrow space. Its output power is up to 144W
and it is built with wiring protection.
RGB Controller with Musical Controller
#5016
This controller has a touch panel and provides intuitive lighting
control. It is very easy to adjust the color and brightness. It is
standard 86-type wall mounted box and is easy to mount on walls
and other surfaces.
Wifi Controller with Color Changing & Color Dimming
#5017
This controller is compatible with all 2.4G RF LED products. After
easy installation and settings, you can operate many different lamps
in different rooms at the same time or separately. You can use your
iPhone, iPad or iPod to control all LED products including LED bulb,
LED strip, LED tube, LED downlight, etc.
很抱歉,暂时无法提供与“5017”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+341.813201+41.43160
- 10+267.0856010+32.37380
- 25+262.1294025+31.77300
- 100+253.73310100+30.75530
- 250+248.78860250+30.15600
