ICP510
ICP510
    INTERNATIONALPOWER
    AC/DC CONVERTER 5V 12V
ICP510 数据手册
SPECIFICATIONS: LINEAR POWER SUPPLY ICP510 MADE IN THE U.S.A. VAC JUMPERING AND FUSING REQUIREMENTS: VAC INPUT: • • • 100/120/220/240 VAC, +10%, -13% TOLERANCE FOR 230 VAC IS +15%, -10% FREQUENCY RANGE: 47-63HZ SILKSCREENED ON CHASSIS FOR TRANFORMER PRIMARY TERMINALS For Use at Jumper Apply AC Max Current / Fuse Rating 100VAC 1&3, 2&4 1&5 120VAC 1&3, 2&4 1&4 220VAC 2&3 1&5 3A 230/240VAC 2&3 1&4 1.5A FOR -5VDC @ 0.7A OUTPUT, JUMPER E1-E2 AND RESET R44 OVERVOLTAGE PROTECTION: VDC OUTPUT: • • 5 VDC @ 6 AMP 12 VDC @ 2.5 AMP (AVG) 7.5 AMP (SURGE) • PROVIDED ON 5 VDC OUTPUT (FACTORY SET AT 6.2 VDC +/- 0.4 VDC) SHORT CIRCUIT PROECTION: • AUTOMATIC FOLDBACK OVERLOAD PROTECTION: • LINE REGULATION: • LOAD REGULATION: +/- 0.05% FOR A 10% LINE CHANGE OUTPUT RIPPLE: 5.0 mV PK-PK MAXIMUM TEMPERATURE RATINGS: • • OPERATING: 0ᵒC TO 50ᵒC FULL RATED DERATED LINEARLY TO 40% @ 70ᵒC STORAGE: -40ᵒC TO +85ᵒC STABILITY: +/VIBRATION: • • 0.3% FOR 24 HOURS AFTER 1 HOUR WARM-UP MIL-STD-810G, METHOD 514.6, CATEGORY 1, PROCEDURE1 RANDOM VIBRATION 10Hz - 2KHz, 6.15 grams (3 axis) REMOTE SENSING: AUTOMATIC CURRENT LIMIT PROVIDED • +/- 0.05% FOR A 50% LOAD CHANGE (DERATE OUTPUT CURRENT 10% FOR 50 HZ OPERATION) TRANSIENT RESPONSE: < 50 µsec per 50% LOAD CHANGE TEMPERATURE COEFFICIENT: • • TYPICAL: 0.01%/DEGREE C MAXIMUM: 0.03%/DEGREE C EFFICIENCY (TYPICAL): 45% SHOCK: • • MIL-STD-810G, METHOD 516.6, PROCEDURE III OPERATING: 20 GPK EMI/RFI: INHERENT LOW CONDUCTED AND REDIATED NOISE LEVELS. • • EMI: FCC CFR TITLE 47 PART 15 SUB-PART B RFI: EN55022/CISPR22-LEVEL B COMPATIBILITY UL recognized for US and Canada – File#E133338/ CE Mark: LVD 92/59/EEC/ RoHs-5 Lead in Solder Exemption US and Canadian (Bi-National) standards: ANSI/UL 60950-1/-21; CAN/CSA C22.2 #60950-1/-21; IEC 60950-1 900 GRAVES AVENUE * OXNARD, CA 93030 * PHONE: 805-981-1188 * EMAIL: powersales@internationalpower.com CASE SIZE: 510 900 GRAVES AVENUE * OXNARD, CA 93030 * PHONE: 805-981-1188 * EMAIL: powersales@internationalpower.com
ICP510 价格&库存
很抱歉,暂时无法提供与“ICP510”相匹配的价格&库存,您可以联系我们找货
