Micro USB to 5V breakout
This pre-built USB to 5V breakout board offers a great way of powering projects that require a 5V supply, kits such as
our mono amp kit.
Code 5109
Product Description
This compact Micro USB Breakout Board offers an easy way of connecting circuits to the 5V power lines that a USB
connection supplies. The output (5V and Gnd) connections are two large solder-able pads on the PCB.
This board is ideal for replacing batteries in a variety of circuits such as our Mono Amp kit. It is compatible with Micro
USB chargers supplied with most mobile phones and tablets.
Features:
Power your electronics projects via USB.
Compatible with projects such as the Kitronik Mono Amp kit.
Contents:
1 x USB to 5V Breakout Board.
Dimensions:
PCB Length: 22mm.
PCB width: 16mm.
Requires:
Soldering Iron.
Solder.
Wire Cutters.
Wire Strippers.
Note:
Some soldering required to connect the breakout board to your project.
PC USB ports normally supply 100mA up to an absolute max of 500mA. If you plug anything in that requires a higher
current, damage to the USB port is possible.
https://www.kitronik.co.uk/5109‐micro‐usb‐to‐5v‐breakout.html 4‐20‐18
很抱歉,暂时无法提供与“5109”相匹配的价格&库存,您可以联系我们找货
