KUSB67X-SMTTH-CS4-B30TR 数据手册
1.00
A12
B12
Insulator: High Temp.
UL94V-0 rated
Color- Black
Contact Material:
Copper Alloy
Contact plating:
Standard: Gold Flash on Contact
Area, Tin Plated on Solder Tails,
All over Nickel Underplate
30 Option: 30u" Gold Plated on
Contact Area, Tin Plated on Solder
Tails, All over Nickel Underplate
3.42
1.75
2.96
3.96
Materials and Finish
B1
Ø0.60
0.80
7.45
1.50
1.00
2.25
9.00
6.80
9.00
8.74
7.45
B1
B12
B2
B11
0.80
1.60
2.00
1.60
6.10
2.06
Rated Current: 5A for Collectively
Power supply Pins (A1, A4, A9, A12,
B1, B4, B9, B12), 1.25A For Vconn Pin,
0.25A For Other Signal Pins.
Insulation Resistance:
100 Megohms Min.
Contact Resistance:
40 milliohms Max. Initial,
50 milliohms Max. After Life Test
Dielectric Withstanding Voltage:
100V AC (RMS) For 1 Minute
2.40
3.20
4.80
1.50
6.80
Ø0.65
Ø0.65
Ø0.40
Electrical Characteristics
A12
1.10
A1
Shield: Stainless Steel,
Nickel plated
1.00
0.50
5.50
0.50
0.35
1.50
0.70
0.70
0.70
9.74
1.60
3.10
10.65
KYCON, Inc. 305 Digital Drive, Morgan Hill, CA 95037 (408)494-0330
8.34
A1
0.50
1.00
Mechanical Characteristics
9.00
A1
Signal
Name
GND
Mating
Sequence
First
B12
Signal
Name
GND
A2
SSTXp1
Second
B11
SSRXp1 Second
A3
SSTXn1
Second
B10
SSRXn1 Second
A4
VBUS
First
B9
VBUS
First
A5
CC1
Second
B8
SBU2
Second
A6
Dp1
Second
B7
Second
A7
Dn1
Second
B6
Dn2
Dp2
A8
SBU1
Second
B5
A9
VBUS
First
B4
A10
SSRXn2 Second
B3
A11
SSRXp2 Second
A12
GND
Pin
0.80
0.25
Durability: 10,000 Mating Cycles
Insertion Force: 5N~20N
Extraction Force :
6N~20N After Life Test
Operating Temperature:
-40°C to +85°C
RECOMMEND P.C.B LAYOUT(COMPONENT SIDE)
6.10
4.80
3.20
2.40
1.60
0.50
5.52
Detail A
SHELL
Pin
Mating
Sequence
First
Part Number
Contact Area Plating Finish
Packaging
Second
KUSB67X-SMTTH-CS4-BTR
Gold Flash (standard)
Tape & Reel
CC2
Second
30u" Gold (30 option)
Tape & Reel
VBUS
First
B2
SSTXn2 Second
SSTXp2 Second
First
B1
GND
GND
SHELL
REV.
DATE
DESCRIPTION
REV. BY
CHK. BY
DRAWN BY
DATE
A0.1
A0.2
05/29/19
06/25/19
New Drawing
Added O-Ring info
H. MA
D. Shehan
D. Shehan
G. Serrato
H. MA
05/29/19
UNITS
mm
First
GND
Tolerances
PRELIMINARY
PART IN DESIGN
SPECIFICATION SUBJECT TO CHANGE
RoHS COMPLIANT
USB 3.1, SMT & T/H LEADS
WATERPROOF, CL1.75. RoHS COMPLIANT
X.X ± 0.35
X.XX ± 0.25
Unless Stated
Otherwise
10.94
O-Ring
0.30 Min.
1.30
5.3645
3.82
O-Ring
0.32
8.40
PCB
2.62
5.14
Assembly orientation
0.44
Compression Ratio 35% - 45%
0.80
Materials
13.14
O-Ring: Silicone, Black
11.14
10.22
Panel
9.44
0.00
8.94-0.06
R1
.8
3
R3
8.96
.40
R2
7.36
5.36
1.00
4.46
3.66
4.16
0.50
1.40
0.00
3.16-0.06
R
R1.9
8
1.
33
9.94
R1
.58
R
33
1.
2.20
Recommended Panel Opening Dimensions
Tolerance ±0.03mm
Mating Area with Sealing Ring
O-Ring
Material: Silicone, Black
Tolerances
PRELIMINARY
PART IN DESIGN
REV.
DATE
DESCRIPTION
REV. BY
CHK. BY
DRAWN BY
DATE
A0.1
A0.2
05/29/19
06/25/19
New Drawing
Added O-Ring info
H. MA
D. Shehan
D. Shehan
G. Serrato
H. MA
05/29/19
UNITS
mm
RoHS COMPLIANT
X.X ± 0.35
X.XX ± 0.25
Unless Stated
Otherwise
KUSB67X-SMTTH-CS4-B30TR 价格&库存
很抱歉,暂时无法提供与“KUSB67X-SMTTH-CS4-B30TR”相匹配的价格&库存,您可以联系我们找货
