TYS4020100M-10
TYS4020100M-10
    LAIRD(莱尔德)
    Nonstandard
    FIXED IND 10UH 900MA 165 MOHM
TYS4020100M-10 数据手册
global solutions : local support ™ Ferrite EMI Cable Cores Electro-Magnetic Interference Solutions www.lairdtech.com Laird Technologies is the world leader in the design and supply of customized performance critical products for wireless and other advanced electronic applications. Laird Technologies partners with it's customers to help find solutions for applications in various industries such as: Aerospace Automotive Electronics Computers Consumer Electronics Data Communications Medical Equipment Military Network Equipment Telecommunications Laird Technologies offers its customers unique product solutions, dedication to research and development and a seamless network of manufacturing and customer support facilities located all across the globe. global solutions : local support ™ www.lairdtech.com  Contents Ferrite Material Impedance Comparison ................................. 4 Design & Selection “Rules of Thumb” ..................................... 4 High Frequency (HFB-) Cylindrical Cores .................................. 5 High Frequency (HFA-) Split, Snap-On Cores ........................... 6 Broadband (28B-) Cylindrical Cores ........................................ 7 Broadband (28A-) Split, Snap-On Cores ................................ 10 Sorted Quick Reference Charts Broadband (28B- and 28A-) Cable Cores .......................... 12 Low Frequency (LFB-) Cylinderical Cores ............................... 14 Broadband (28R-) Ribbon & Flex Cable Cores ....................... 15 Broadband (28S-) Split Ribbion & Flex Cable Cores .............. 18 Sorted Quick Reference Charts Broadband (28R- and 28S-) Ribbon Cores ......................... 20 Ferrite EMI Disks & Plates ..................................................... 22 All parts listed in this catalog are lead free and RoHS compliant. This catalog contains a limited selection of Laird Technologies, cable core products. Refer to www.lairdtech.com for other cable core products not included in this cable core catalog. visit www.lairdtech.com for product additions and more product details  FERRITE MATERIAL COMPARISON LF, 28, HF Material Impedance vs Frequency ( 300 KHz - 2 GHz ) Impedance Materials for Cable & Wiring Harness Cores HF LF Low Frequency Impedance ( Z ) in Ohms ( Ω ) 0.3 28 28 Broadband High Performance HF High Frequency LF 0.5 1 5 10 50 100 500 1000 2000 Frequency ( MHz ) DESIGN & SELECTION “RULES OF THUMB” · Select the appropriate ferrite material for the EMI frequency range to be attenuated (refer to cable core material impedance vs. frequency chart above). · Ferrite material composition affects core performance most. High performance material is best. Cheap, low performance materials require the use of larger, heavier cores. · Shape (design) and mass of the ferrite core significantly affect impedance. · Don’t over size. Use high performance ferrite material and select the smallest core that will do the job. High performance material allows the use of smaller, lighter and lower cost cores. · Select a ferrite core that fits over the cable’s outside dimensions. Core should slide easily over the cable during installation. · When possible, install a cable core over wires in a common-mode configuration (out and back lines inside the same ferrite cable core). A differential cable pair inside the same core will make the ferrite core a common mode choke that is not susceptible to saturation from very high currents. · Install the ferrite core near the noise source · Additional turns through a core will provide multiple amounts of peak impedance. Example: Two wire turns provide 4 times the impedance of one turn (pass through) the ferrite core. Also, with each added turn, the peak impedance shifts to a slightly lower frequency. · Two piece split cores are available. One-piece cylindrical or flat ribbon ferrite core shapes are usually preferable but, split cores can be used in applications where cores cannot slide over cable ends and connectors. Some split cores are available with snap-on plastic cases or metal clips. · Side by side impedance testing of ferrite cores is the best way to compare performance of different cores. Ferrite core impedance measurement equipment and test methods are not standardized in the industry. Every ferrite company has their own test methods. Catalog (web site) impedance data cannot be accurately compared. Optimized, high performance, low cost custom part designs are available.  High Frequency Ferrite Cylindrical EMI Cores 300 MHz to 2 GHz Optimized Cylindrical Solid Ferrite Cores for Round Cables & Wiring Harnesses DIMENSIONS mm (inches) Part Number C Net Impedance ( Z ) in Ohms ( W ) B A B C @ 300 MHz @ 500 MHz @ 800 MHz @1 GHz HFB075024-000 7.52 (0.296) 2.39 (0.094) 10.00 (0.394) 124 136 138 138 HFB095051-100 9.52 (0.375) 5.08 (0.200) 10.00 (0.394) 64 74 89 85 HFB095051-200 9.52 (0.375) 5.08 (0.200) 19.00 (0.748) 120 135 151 147 HFB123049-000 12.32 (0.485) 4.88 (0.192) 5.00 (0.197) 50 56 63 61 HFB123049-100 12.32 (0.485) 4.88 (0.192) 10.00 (0.394) 97 110 120 115 HFB123049-300 12.32 (0.485) 4.88 (0.192) 25.40 (1.000) 258 287 300 246 HFB143064-000 14.27 (0.562) 6.35 (0.250) 5.00 (0.197) 43 50 58 60 HFB143064-100 14.27 (0.562) 6.35 (0.250) 10.00 (0.394) 85 100 113 115 HFB143064-300 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 270 315 270 200 HFB150070-200 14.99 (0.590) 6.99 (0.275) 28.58 (1.125) 242 287 270 204 HFB152034-000 15.24 (0.600) 3.38 (0.133) 10.00 (0.394) 165 190 189 185 HFB157070-000 15.65 (0.616) 6.99 (0.275) 20.00 (0.787) 170 200 220 205 HFB159079-100 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 235 290 302 260 HFB160093-200 16.00 (0.630) 9.25 (0.364) 19.00 (0.748) 120 145 155 170 HFB160093-300 16.00 (0.630) 9.25 (0.364) 27.99 (1.102) 170 198 232 220 HFB170070-000 16.99( 0.669) 7.01 (0.276) 10.00 (0.394) 97 115 127 140 HFB170070-100 16.99 (0.669) 7.01 (0.276) 20.00 (0.787) 185 215 239 220 HFB187102-100 18.67 (0.735) 10.16 (0.400) 30.00 (1.181) 205 250 270 210 HFB259128-100 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 175 210 254 250 A All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. This catalog lists a limited sample of available parts. Custom parts are also available. visit www.lairdtech.com for product additions and more product details  High Frequency Ferrite EMI Cores Split, Snap-On Ferrite Cores in Plastic Cases 300 MHz to 2 GHz Optimized For retrofit and post-assembly operations a selection of high frequency EMI “split” cores are offered. Similar in performance to one piece cylindrical core designs, these split ferrite cores provide excellent common and differential mode high frequency EMI suppression on round cable and wire assemblies. Black plastic snap-on cases provide secure closure of the split cores onto the cable or wire bundle. PART NUMBERING SYSTEM EXAMPLE HF A 100049 -0 A 2 Material Type Product Code Part Size Code (mm) Selected Dimension Code (Usually Length) Additional Part Description Plastic Case Color Code Part Number Fig # PLASTIC CASE DIMENSIONS mm (inches) A B C D Maximum Cable Diameter mm (inches) @ 300 MHz All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. @1 GHz Laird Technologies’ Solid Cylindrical Core Similar Parts (for reference) Net Impedance ( Z ) in Ohms ( W ) @ 500 @ 800 MHz MHz HFA100049-0A2 1 13.72 (0.540) 5.44 (0.214) 30.56 (1.203) 13.72 (0.540) 4.88 (0.192) 133 152 168 162 HFB095051-200 HFA150066-0A2 2 18.15 (0.715) 7.05 (0.278) 32.50 (1.280) 18.90 (0.744) 6.60 (0.260) 274 350 340 256 HFB143064-300 HFA150068-0A2 1 21.00 (0.827) 6.80 (0.268) 41.70 (1.642) 21.00 (0.827) 6.76 (0.266) 275 340 281 200 HFB150070-200 HFA163090-0A2 1 19.10 (0.752) 9.09 (0.358) 40.36 (1.589) 20.80 (0.819) 9.01 (0.355) 210 260 262 200 HFB160093-300 HFA187102-0A2 2 22.88 (0.877) 10.00 (0.394) 32.77 (1.290) 21.84 (0.860) 10.16 (0.400) 220 290 281 210 HFB187102-100 HFA259131-0A2 2 29.00 (1.142) 13.00 (0.512) 32.50 (1.280) 29.62 (1.166) 13.06 (0.514) 250 315 272 200 HFB259128-100 - 0A2 part number suffix designates black plastic case. Additional colors may be available, please inquire with Laird Technologies’ customer service. Figure 1 Figure 2 A B D C Please visit www.Lairdtech.com for the most up to date information. All dimensions & impedance values can be sorted and compared on www.Lairdtech.com Custom parts are available.  Broadband EMI Ferrite Cylindrical Cores For Round Cables & Wiring Harnesses PART NUMBERING SYSTEM EXAMPLE 28 B 0250 -1 0 0 Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description or Coating A DIMENSIONS mm (inches) B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0250-100 6.35 (0.250) 3.18 (0.125) 15.88 (0.625) 90 182 300 28B0268-000 6.78 (0.267) 3.99 (0.157) 14.22 (0.560) 65 138 260 28B0275-000 7.00 (0.276) 3.80 (0.150) 13.50 (0.531) 69 146 268 28B0296-000 7.52 (0.296) 2.39 (0.94) 7.54 (0.297) 75 160 270 28B0315-000 8.00 (0.315) 3.17 (0.125) 4.78 (0.188) 43 100 220 28B0315-100 8.00 (0.315) 3.17 (0.125) 10.06 (0.396) 76 158 281 28B0339-000 8.60 (0.339) 3.80 (0.150) 10.00 (0.394) 68 143 264 28B0355-000 9.00 (0.354) 4.75 (0.187) 20.00 (0.787) 110 205 360 28B0375-000 9.53 (0.375) 5.08 (0.200) 10.41 (0.410) 57 125 245 28B0375-100 9.53 (0.375) 5.08 (0.200) 14.48 (0.570) 74 154 282 28B0375-300 9.53 (0.375) 5.08 (0.200) 19.05 (0.750) 100 194 310 28B0375-400 9.52 (0.375) 5.08 (0.200) 4.83 (0.190) 33 81 200 28B0384-000 9.75 (0.384) 3.80 (0.150) 10.00 (0.394) 82 159 286 28B0384-200 9.75 (0.384) 3.80 (0.150) 25.00 (0.984) 182 322 473 28B0390-200 9.91 (0.390) 6.35 (0.250) 15.00 (0.590) 57 128 248 28B0395-000 10.01 (0.394) 5.97 (0.235) 6.17 (0.243) 31 83 199 28B0434-000 11.00 (0.433) 5.10 (0.201) 32.00 (1.260) 200 349 481 28B0453-000 11.50 (0.453) 4.90 (0.193) 25.00 (0.984) 148 262 378 28B0472-090 12.00 (0.472) 3.60 (0.142) 20.00 (0.787) 158 272 390 Part Number Broadband (28) round cable parts are sorted by inside diameter on page 12 and sorted by impedance on page 13. C Typical Impedance ( Z ) in Ohms ( W ) B A Please refer to the seperate Toroid Catalog from Laird Technologies for an extensive list of small ferrite inductor toroid core sizes and materials. visit www.lairdtech.com for product additions and more product details  Broadband EMI Ferrite Cylindrical Cores A DIMENSIONS mm (inches) B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0473-000 12.00 (0.472) 3.55 (0.140) 10.00 (0.394) 101 195 320 28B0473-200 12.00 (0.472) 3.55 (0.140) 25.00 (0.984) 240 424 558 28B0485-000 12.32 (0.485) 4.88 (0.192) 25.40 (1.000) 170 320 450 28B0500-100 12.70 (0.500) 7.92 (0.312) 6.35 (0.250) 33 83 200 28B0500-300 12.70 (0.500) 7.92 (0.312) 12.70 (0.500) 54 118 230 28B0562-000 14.27 (0.562) 6.35 (0.250) 10.16 (0.400) 69 145 270 28B0562-100 14.27 (0.562) 6.35 (0.250) 13.46 (0.530) 89 184 303 28B0562-200 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 177 317 470 28B0562-300 14.27 (0.562) 6.35 (0.250) 28.32 (1.115) 150 270 420 28B0563-000 14.27 (0.562) 7.26 (0.286) 15.24 (0.600) 85 173 295 28B0563-100 14.27 (0.562) 7.26 (0.286) 20.30 (0.800) 109 217 333 28B0563-200 14.27 (0.562) 7.26 (0.286) 28.57 (1.125) 149 287 406 28B0570-000 14.48 (0.570) 8.51 (0.335) 5.51 (0.217) 32 82 200 28B0590-000 14.99 (0.590) 6.99 (0.275) 27.94 (1.100) 170 300 450 28B0591-200 15.00 (0.591) 5.90 (0.232) 35.00 (1.378) 250 450 580 28B0592-000 15.00 (0.591) 4.50 (0.177) 40.00 (1.575) 361 653 627 28B0616-000 15.65 (0.616) 6.99 (0.275) 28.58 (1.125) 170 310 450 28B0625-000 15.88 (0.625) 7.87 (0.310) 14.27 (0.563) 79 163 273 28B0625-100 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 150 280 400 28B0631-000 16.00 (0.630) 9.25 (0.364) 11.99 (0.472) 60 130 250 28B0631-100 16.00 (0.630) 9.25 (0.364) 27.99 (1.102) 124 243 370 28B0672-000 17.07 (0.672) 8.76 (0.345) 25.40 (1.000) 130 245 360 28B0686-000 17.42 (0.686) 9.52 (0.375) 6.35 (0.250) 39 91 214 28B0686-100 17.42 (0.686) 9.52 (0.375) 12.70 (0.500) 66 139 265 28B0686-200 17.42 (0.686) 9.53 (0.375) 28.58 (1.125) 124 242 390 Part Number  C Typical Impedance ( Z ) in Ohms ( W ) B A Additional wire turns multiply impedance Broadband EMI Ferrite Cylindrical Cores A DIMENSIONS mm (inches) B C @ 25 MHz @ 100 MHz @ 300 MHz 28B0734-000 18.67 (0.735) 11.18 (0.440) 28.58 (1.125) 116 229 370 28B0735-000 18.67 (0.735) 10.16 (0.400) 28.58 (1.125) 135 250 400 28B0735-300 18.67 (0.735) 10.16 (0.400) 14.27 (0.562) 73 150 270 28B0773-050* 19.64 (0.773) 11.64 (0.458) 12.70 (0.500) 69 141 273 28B0825-000 20.95 (0.825) 13.21 (0.520) 6.35 (0.250) 31 79 204 28B0870-000 22.10 (0.870) 13.72 (0.540) 6.35 (0.250) 34 85 205 28B0870-100 22.10 (0.870) 13.72 (0.540) 12.70 (0.500) 56 122 236 28B0999-000 25.40 (1.000) 15.49 (0.610) 12.70 (0.500) 56 122 247 28B1000-000 25.40 (1.000) 12.70 (0.500) 12.70 (0.500) 73 151 278 28B1020-100 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 147 276 412 28B1122-100 28.50 (1.122) 13.77 (0.542) 28.58 (1.125) 160 307 440 28B1122-300 28.50 (1.122) 13.77 (0.542) 20.00 (0.787) 115 210 350 28B1142-000 29.01 (1.142) 19.00 (0.748) 7.49 (0.295) 34 85 200 28B1142-100 29.01 (1.142) 19.00 (0.748) 13.84 (0.545) 28B1225-000 31.12 (1.225) 19.05 (0.750) 15.93 (0.627) 68 140 270 28B1225-100 31.12 (1.225) 19.05 (0.750) 7.92 (0.312) 39 93 210 28B1225-300 31.12 (1.225) 19.05 (0.750) 10.00 (0.394) 46 110 240 28B1250-000 31.75 (1.250) 19.05 (0.750) 22.22 (0.875) 92 186 292 28B1417-200 36.00 (1.417) 23.00 (0.905) 12.70 (0.500) 52 115 230 28B1531-000* 38.86 (1.530) 12.95 (0.510) 28.58 (01.125) 109 210 347 28B1540-000 39.12 (1.540) 16.76 (0.660) 22.22 (0.875) 130 254 405 28B2000-100 50.80 (2.000) 25.40 (1.000) 28.70 (1.130) 157 305 442 28B2400-000 60.96 (2.400) 35.56 (1.400) 12.70 (0.500) 60 135 285 Part Number C Typical Impedance ( Z ) in Ohms ( W ) B 54 114 235 A C B E D A *Oval Core Part Number DIMENSIONS mm (inches) D E 28B0773-050 11.64 (0.458) 5.10 (0.201) 28B1531-000 26.16 (1.030) 26.04 (1.025) Broadband (28) round cable parts are sorted by inside diameter on page 12 and sorted by impedance on page 13. Custom Parts are also available visit www.lairdtech.com for product additions and more product details  Broadband EMI Ferrite Split/Snap-On Cores In Plastic Cases For Round Cables & Wiring Harnesses For retrofit and post-assembly operations, Laird Technologies’ offers a selection of “split” cores. Similar in performance to the one piece core designs, these split ferrite cores provide excellent common and differential mode EMI suppression on round cable and wire assemblies. Black or white plastic snap-on cases provide secure closure of the split cores onto the cable. PART NUMBERING SYSTEM EXAMPLE 28 A 0350 -0 B *0 (White Case) *2 (Black Case) Material Type Product Code Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Plastic Case Color Code PART NUMBER Figure # on page 11 PLASTIC CASE DIMENSIONS mm (inches) A B C D Maximum Cable Diameter mm (inches) Broad Band High Performance Material is 28 High Frequency Material is HF Laird Technologies Solid Cylindrical Core Similar Parts @ 300 MHz (for reference) Typical Impedance ( Z ) in Ohms ( W ) @ 25 MHz @ 100 MHz 28A0350-0B2 1 13.00 (0.511) 3.50 (0.138) 25.20 (0.992) 11.50 (0.453) 3.50 (0.138) 100 240 400 28B0472-090 28A0392-0A* 1 13.72 (0.540) 5.44 (0.214) 30.56 (12.03) 12.72 (0.540) 4.75 (0.187) 75 170 320 28B0375-300 28A0434-0A2 4 14.71 (0.579) 5.44 (0.214) 42.88 (1.688) 14.70 (0.579) 5.05 (0.119) 111 277 449 28B0434-000 28A0592-0A2 4 18.75 (0.738) 5.04 (0.198) 53.39 (2.102) 18.75 (0.738) 4.40 (0.137) 261 572 688 28B0592-000 28A0593-0A2 4 18.75 (0.738) 6.75 (0.266) 52.91 (2.083) 18.75 (0.738) 6.50 (0.256) 186 407 575 28B0591-200 28A0640-0A* 1 19.90 (0.783) 9.80 (0.346) 41.40 (1.630) 21.65 (0.819) 8.95 (0.352) 105 240 390 28B0631-100 28A0807-0A2 4 24.82 (0.977) 10.00 (0.394) 55.91 (2.201) 24.82 (0.977) 10.00 (0.394) 160 348 514 28B0735-000 28A2024-0A* 2 29.00 (1.142) 13.00 (0.512) 32.50 (1.280) 29.62 (1.166) 12.85 (0.506) 130 280 440 28B1020-100 28A2025-0A* 2 18.15 (0.715) 7.05 (0.278) 32.50 (1.280) 18.90 (0.744) 6.45 (0.254) 130 320 510 28B0562-200 28A2026-0A2 1 21.00 (0.827) 6.80 (0.268) 41.70 (1.642) 21.00 (0.827) 6.45 (0.254) 95 270 460 28B0562-200 28A2029-0A* 2 22.28 (0.877) 10.00 (0.394) 32.77 (1.290) 21.84 (0.860) 9.95 (0.392) 95 250 420 28B0734-000 28A2432-0A2 3 19.20 (0.756) 8.20 (0.323) 19.90 (0.783) 23.10 (0.909) 8.05 (0.317) 62 160 300 28B0672-000 28A2736-0A2 1 19.70 (0.776) 9.00 (0.354) 35.10 (1.382) 18.00 (0.709) 8.90 (0.350) 120 220 360 28B0631-100 28A3039-0A2 3 24.55 (0.967) 10.20 (0.402) 13.60 (0.535) 28.50 (1.122) 10.15 (0.400) 55 130 250 28B0735-300 28A3851-0A2 1 30.00 (1.181) 13.00 (0.512) 33.70 (1.327) 30.00 (1.181) 12.85 (0.506) 150 260 410 28B1020-100 28A4155-0A2 3 28.80 (1.134) 13.60 (0.535) 15.40 (0.606) 33.20 (1.307) 13.55 (0.533) 50 120 230 28B0825-100 28A5131-0A2 5 56.64 (2.230) 19.50 (0.768) 45.00 (1.772) 56.63 (2.230) 25.40 (1.000) 187 425 533 28B2000-100 29.20 19.30 28A5776-0A2 2 (1.150) (0.760) 0A0 = White Plastic Snap On Case * * - 0A2 = Black Plastic Snap On Case 42.00 (1.654) 29.40 (1.157) 19.00 (0.748) 10 115 210 360 28B1250-000 Broadband (28) round cable parts are sorted by inside diameter on page 12 and sorted by impedance on page 13. High Frequency Split, Snap-On, Ferrite Cores in Plastic Cases PART NUMBER PLASTIC CASE DIMENSIONS mm (inches) Figure # A B C D Maximum Typical Impedance Cable ( Z ) in Ohms ( W ) Diameter mm @ 1 GHz (inches) @ 500 MHz @ 800 MHz Laird Technologies Solid Cylindrical Core Similar Parts (for reference) HFA100049-0A2 1 13.72 (0.540) 5.44 (0.214) 30.56 (1.203) 13.72 (0.540) 4.88 (0.192) 152 168 162 HFB095051-200 HFA150066-0A2 2 18.15 (0.715) 7.05 (0.278) 32.50 (1.280) 18.90 (0.744) 6.60 (0.260) 350 350 256 HFB143064-200 HFA150068-0A2 1 21.00 (0.827) 6.80 (0.268) 41.70 (1.642) 21.00 (0.827) 6.76 (0.266) 340 280 200 HFB150070-200 HFA163090-0A2 1 19.10 (0.752) 9.09 (0.358) 40.36 (1.589) 20.80 (0.819) 9.01 (0.355) 260 260 200 HFB160093-300 HFA187102-0A2 2 22.28 (0.877) 10.00 (0.394) 32.77 (1.290) 21.84 (0.860) 10.16 (0.400) 290 281 210 HFB187102-100 HFA259131-0A2 2 29.00 (1.142) 13.00 (0.512) 32.50 (1.280) 29.62 (1.166) 13.06 (0.514) 315 274 200 HFB259128-100 -0A2 = Black Plastic Snap On Case - Other parts may be available. Please contact Laird Technologies. All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. Plastic Case Split / Snap-On Part Diagrams Figure 2 Figure 1 Figure 3 C B B D B A C D C A A Figure 4 Figure 5 A C C A B B D visit www.lairdtech.com for product additions and more product details 11 REFERENCE CHART - SORTED BY INSIDE DIAMETER ( B ) Broadband 28 Material Parts Only One Piece (28B) & Split / Snap-on (28A) Cores for Round Cables & Wires DIMENSIONS in mm I.D. B C PART NUMBER Sorted by I.D. A 28B0296-000 7.52 2.39 28B0315-000 8.00 28B0315-100 DIMENSIONS in mm I.D. B C D PART NUMBER Sorted by I.D. A 7.54 - 28B0500-100 12.70 7.92 6.35 - 3.17 4.78 - 28B0500-300 12.70 7.92 12.70 - 8.00 3.17 10.06 - 28A2432-0A2 19.20 8.20 19.90 - 28B0250-100 6.35 3.18 15.88 - 28B0570-000 14.48 8.51 5.51 - 28A0350-0B2 13.00 3.50 25.20 11.50 28B0672-000 17.07 8.76 25.40 - 28B0473-000 12.00 3.55 10.00 - 8.80 41.40 21.65 12.00 3.55 25.00 - 28A0640-0A* 28A2736-0A2 19.90 28B0473-200 19.70 9.00 35.10 18.00 28B0472-090 12.00 3.60 20.00 28B0631-000 16.00 9.25 11.99 - 28B0339-000 8.60 3.80 10.00 - 28B0631-100 16.00 9.25 27.99 - 28B0384-000 9.75 3.80 10.00 - 28B0686-000 17.42 9.52 6.35 - 28B0275-000 7.00 3.80 13.50 - 28B0686-100 17.42 9.52 12.70 - 28B0384-200 9.75 3.80 25.00 - 28B0686-200 17.42 9.53 28.58 - 28B0268-000 6.78 3.99 14.22 - 10.00 32.77 21.84 15.00 4.50 40.00 - 28A2029-0A* 28B0735-300 22.28 28B0592-000 18.67 10.16 14.27 - 28B0355-000 9.00 4.75 20.00 - 28B0735-000 18.67 10.16 28.58 - 28B0485-000 12.32 4.88 25.40 - 28A3039-0A2 24.55 10.20 13.60 28.50 28B9453-000 11.50 4.90 25.00 - 28B0734-000 18.67 11.18 28.58 - 28A0592-0A2 18.75 5.04 53.39 - 28B0773-050 19.64 11.64 12.70 13.10 28B0375-400 9.52 5.08 4.83 - 28B1000-000 25.40 12.70 12.70 - 28B0375-000 9.53 5.08 10.41 - 28B1020-100 25.91 12.83 28.58 - 28B0375-100 9.53 5.08 14.48 - 28B1531-000 38.86 12.95 28.58 26.16 28B0375-300 9.53 5.08 19.05 - 13.00 32.50 29.62 11.00 5.10 32.00 - 28A2024-0A* 28A3851-0A2 29.00 28B0434-000 30.00 13.00 33.70 30.00 28A0434-0A2 14.70 5.25 43.00 14.70 28B0825-000 20.95 13.21 6.35 - 28A0392-0A* 28B0591-200 13.72 5.44 30.56 12.30 28A4155-0A2 28.80 13.60 15.40 33.20 15.00 5.90 35.00 - 28B0870-000 22.10 13.72 6.35 - 28B0395-000 10.01 5.97 6.17 - 28B0870-100 22.10 13.72 12.70 - 28B0562-000 14.27 6.35 10.16 - 28B1122-300 28.50 13.77 20.00 - 28B0562-100 14.27 6.35 13.46 - 28B1122-100 28.50 13.77 28.58 - 28B0390-200 9.91 6.35 15.00 - 28B0999-000 25.40 15.49 12.70 - 28B0562-300 14.27 6.35 28.32 - 28B1540-000 39.12 16.76 22.22 - 28B0562-200 14.27 6.35 28.58 - 28B1142-000 29.01 19.00 7.49 - 28A0593-0A2 18.75 6.75 52.90 - 28B1142-100 29.01 19.00 13.84 - 28A2026-0A2 21.00 6.80 41.70 21.00 28B1225-100 31.12 19.05 7.92 - 28B0590-000 14.99 6.99 27.94 - 28B1225-300 31.12 19.05 10.00 - D 28B0616-000 15.65 6.99 28.58 - 28B1225-000 31.12 19.05 15.93 - 28A2025-0A* 28B0563-000 18.15 7.05 32.50 18.90 28B1250-000 31.75 19.05 22.22 - 14.27 7.26 15.24 - 28A5776-0A2 29.20 19.30 42.00 29.40 28B0563-100 14.27 7.26 20.30 - 28A5131-0A2 56.64 19.50 45.00 56.63 28B0563-200 14.27 7.26 28.57 - 28B1417-200 36.00 23.00 12.70 - 28B0625-000 15.88 7.87 14.27 - 28B2000-100 50.80 25.40 28.70 - 28B0625-100 15.88 7.87 28.58 - 28B2400-000 60.96 35.56 12.70 - 12 Refer to pages 7, 8, 9 & 10 for more broadband data. All chart data can be sorted on www.Lairdtech.com REFERENCE CHART - SORTED BY IMPEDANCE @ 100 MHz Broadband 28 Material Parts Only One Piece (28B) & Split / Snap-on (28A) Cores for Round Cables & Wires PART NUMBER Sorted by Impedance TYPICAL IMPEDANCE ( Z ) IN OHMS ( W ) @ 25 MHz @ 100 MHz @ 300 MHz PART NUMBER Sorted by Impedance TYPICAL IMPEDANCE ( Z ) IN OHMS ( W ) @ 25 MHz @ 100 MHz @ 300 MHz 28B0825-000 31 79 204 28B0375-300 100 194 310 28B0375-400 33 81 200 28B0473-000 101 195 320 28B0570-000 32 82 200 28B0355-000 110 205 360 28B0395-000 31 83 199 28B1531-000 109 210 347 28B0500-100 33 83 200 28B1122-300 115 210 350 28B1142-000 34 85 200 28A5776-0A2 115 210 360 28B0870-000 34 85 205 28B0563-100 109 217 333 28B0686-000 39 91 214 28A2736-0A2 120 220 360 28B1225-100 39 93 210 28B0734-000 116 229 370 28B0315-000 43 100 220 240 390 46 110 240 28A0640-0A* 28A0350-0B2 105 28B1225-300 100 240 400 28B1142-100 54 114 235 28B0686-200 124 242 390 28B1417-200 52 115 230 28B0631-100 124 243 370 28B0500-300 54 118 230 28B0672-000 130 245 360 28A4155-0A2 50 120 230 28B0735-000 135 250 400 28B0870-100 56 122 236 95 250 420 28B0999-000 56 122 247 28A2029-0A* 28B1540-000 130 254 405 28B0375-000 57 125 245 28A3851-0A2 150 260 410 28B0390-200 57 128 248 28B0453-000 148 262 378 28A3039-0A2 55 130 250 28B0562-300 150 270 420 28B0631-000 60 130 250 28A2026-0A2 95 270 460 28B2400-000 60 135 285 28B0472-090 158 272 390 28B0268-000 65 138 260 28B1020-100 147 276 412 28B0686-100 66 139 265 28A0434-0A2 111 277 449 28B1225-000 68 140 270 28B0625-100 150 280 400 28B0773-050 69 141 273 130 280 440 28B0339-000 68 143 264 28A2024-0A* 28B0563-200 149 287 406 28B0562-000 69 145 270 28B0590-000 170 300 450 28B0275-000 69 146 268 28B2000-100 157 305 442 28B0735-300 73 150 270 28B1122-100 160 307 440 28B1000-000 73 151 278 28B0616-000 170 310 450 28B0375-100 74 154 282 28B0562-200 177 317 470 28B0315-100 76 158 281 28B0485-000 170 320 450 28B0384-000 82 159 286 320 510 75 160 270 28A2025-0A* 28B0384-200 130 28B0296-000 182 322 473 28A2432-0A2 62 160 300 28B0434-000 200 349 481 28B0625-000 79 163 273 28A0593-0A2 186 407 575 28A0392-0A* 28B0563-000 75 170 320 28B0473-200 240 424 558 85 173 295 28A5131-0A2 187 425 533 28B0250-100 90 182 300 28B0591-200 250 450 580 28B0562-100 89 184 303 28A0592-0A2 261 575 688 28B1250-000 92 186 292 28B0592-000 361 653 627 Refer to pages 7, 8, 9 & 10 for more broadband data. Custom Parts are also available visit www.lairdtech.com for product additions and more product details 13 Low Frequency Ferrite EMI Cores For Round Cables & Wiring Harnesses 300 KHz to 30 MHz Optimized PART NUMBERING SYSTEM EXAMPLE LF B Material Type Product Code 090050 -0 Part Size Code (mm) Selected Dimension Code (Usually Length) 0 Additional Part Description Additional Part Description or Coating Code Typical Impedance ( Z ) in Ohms ( W ) DIMENSIONS mm (inches) PART NUMBER 0 All impedance values for high frequency cores are NET; NET impedance is impedance of the ferrite core only. All impedance contribution from the test wire and fixtures has been removed. W @ 500 KHz W @ 1 MHz W @ 5 MHz # of Wire Turns # of Wire Turns # of Wire Turns A B C 1 2 5 1 2 5 1 2 5 LFB090050-000 9.00 (0.354) 5.00 (0.197) 7.00 (0.275) 12 58 370 21 90 558 36 140 867 LFB095051-000 9.50 (0.374) 5.10 (0.201) 19.05 (0.750) 36 150 846 63 240 1464 86 340 2514 LFB127079-000 12.70 (0.500) 7.92 (0.312) 7.00 (0.276) 9 45 301 16 70 436 25 102 593 LFB143064-000 14.27 (0.562) 6.35 (0.250) 28.58 (1.125) 70 290 1757 122 490 2842 120 480 2646 LFB143064-100 14.27 (0.562) 6.35 (0.250) 13.46 (0.530) 33 145 626 57 220 1169 53 215 1552 LFB159079-000 15.88 (0.625) 7.87 (0.310) 28.58 (1.125) 61 250 1605 105 410 2615 100 390 2305 LFB174095-000 17.40 (0.685) 9.50 (0.374) 28.58 (1.125) 52 200 1290 91 350 2184 85 340 2044 LFB180100-000 18.10 (0.713) 10.00 (0.394) 10.00 (0.394) 18 75 493 31 138 809 29 115 722 LFB187102-000 18.67 (0.735) 10.16 (0.400) 28.58 (1.125) 53 200 1182 91 350 1969 84 330 1863 LFB220140-000 22.10 (0.870) 14.00 (0.551) 12.70 (0.500) 18 72 469 30 120 818 28 110 699 LFB250150-000 25.00 (0.984) 15.00 (0.591) 13.00 (0.512) 16 70 562 34 136 850 26 80 624 LFB259128-000 25.91 (1.020) 12.83 (0.505) 28.58 (1.125) 61 220 1446 106 420 2647 62 240 1487 LFB290190-000 28.98 (1.141) 19.05 (0.750) 15.21 (0.599) 19 90 533 34 155 963 22 70 513 LFB310190-000 31.00 (1.220) 19.00 (0.748) 13.00 (0.512) 19 80 523 33 143 845 22 88 554 LFB360230-300 36.00 (1.417) 23.00 (0.905) 15.00 (0.591) 24 96 614 27 110 653 19 75 438 C B A 1 Turn 2 Turns This catalog lists a limited sample of available parts. Custom parts are also available. 14 5 Turns Broadband Ferrite EMI Cores For Flat Ribbon & Flex Cables PART NUMBERING SYSTEM EXAMPLE 28 Material Type R Product Code 0315 -2 0 0 Part Size Code Selected Dimension Code (Usually Length) Additional Part Description Additional Part Description *Broadband ( 28 ) ribbon and flex cable cores are sorted by slot width on page 20 and sorted by impedance on page 21. Custom Parts with double sided mounting tape are available Part Number Figure # on Page 17 DIMENSIONS mm (inches) Typical Impedance ( Z ) in Ohms ( W ) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R0315-200 2 8.00 (0.315) 6.00 (0.236) 12.00 (0.472) 2.70 (0.106) 0.70 (0.028) 48 102 250 28R0453-200 2 11.50 (0.453) 8.00 (0.315) 12.00 (0.472) 3.00 (0.118) 0.70 (0.028) 43 104 260 28R0453-300 2 11.50 (0.453) 8.00 (0.315) 20.00 (0.787) 3.00 (0.118) 0.70 (0.028) 65 153 335 28R0480-000 2 12.20 (0.480) 8.00 (0.315) 18.00 (0.709) 5.50 (0.217) 1.00 (0.039) 100 190 320 28R0492-100 2 12.50 (0.492) 8.30 (0.327) 12.00 (0.472) 5.50 (0.217) 1.00 (0.039) 68 150 290 28R0546-000 2 13.90 (0.547) 9.40 (0.370) 18.00 (0.709) 5.30 (0.209) 0.80 (0.0315) 91 193 419 28R0592-010 2 15.01 (0.591) 10.00 (0.394) 22.86 (0.900) 7.49 (0.295) 1.50 (0.059) 121 227 370 28R0610-000 3 15.50 (0.610) 13.50 (0.531) 10.00 (0.394) 3.40 (0.134) 1.40 (0.055) 29 80 216 28R0614-100 2 15.60 (0.614) 13.60 (0.535) 12.00 (0.472) 2.80 (0.110) 0.70 (0.028) 36 98 245 28R0669-000 2 17.00 (0.669) 13.00 (0.512) 12.00 (0.472) 3.50 (0.138) 0.75 (0.030) 41 110 270 28R0756-000 3 19.20 (0.756) 15.00 (0.591) 10.00 (0.394) 5.35 (0.211) 1.15 (0.045) 40 107 258 28R0756-200 3 19.20 (0.756) 15.00 (0.591) 16.00 (0.630) 5.35 (0.211) 1.15 (0.045) 57 140 308 28R0825-000 3 20.95 (0.825) 14.00 (0.551) 19.05 (0.750) 7.75 (0.305) 0.80 (0.031) 96 190 363 28R0880-000 2 22.35 (0.880) 14.00 (0.551) 19.05 (0.750) 7.75 (0.305) 1.50 (0.059) 93 187 356 28R0898-100 2 22.80 (0.898) 18.70 (0.736) 12.00 (0.472) 2.80 (0.110) 0.70 (0.028) 38 110 266 28R0898-200 2 22.80 (0.898) 18.70 (0.736) 16.00 (0.630) 2.80 (0.110) 0.70 (0.028) 43 127 280 28R0945-000 3 24.00 (0.945) 19.00 (0.748) 10.00 (0.394) 6.25 (0.246) 1.25 (0.049) 43 112 269 28R0984-000 3 25.00 (0.984) 18.00 (0.709) 24.00 (0.945) 7.70 (0.303) 0.90 (0.035) 100 220 430 28R0984-200 3 25.00 (0.984) 18.00 (0.709) 16.00 (0.630) 7.70 (0.303) 0.90 (0.035) 70 170 370 visit www.lairdtech.com for product additions and more product details 15 Broadband Ferrite EMI Cores For Ribbon & Flex Cables Part Number 16 Figure # on Page 17 DIMENSIONS mm (inches) Typical Impedance ( Z ) in Ohms ( W ) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R1022-000 3 26.00 (1.022) 22.00 (0.866) 9.00 (0.354) 5.00 (0.197) 1.20 (0.047) 32 91 227 28R1024-000 2 26.00 (1.024) 20.50 (0.807) 10.00 (0.394) 6.00 (0.236) 0.80 (0.031) 48 128 299 28R1025-000 3 26.00 (1.024) 21.40 (0.8425) 10.00 (0.394) 5.00 (0.197) 0.75 (0.030) 37 97 242 28R1101-000 1 27.97 (1.101) 22.94 (0.903) 14.66 (0.577) 7.75 (0.305) 1.50 (0.059) 55 140 300 28R1102-000 2 28.00 (1.102) 23.00 (0.906) 15.00 (0.591) 5.80 (0.228) 0.80 (0.031) 61 154 340 28R1102-100 2 28.00 (1.102) 23.00 (0.906) 20.00 (0.787) 5.80 (0.228) 0.80 (0.031) 75 192 380 28R1103-000 2 28.00 (1.102) 23.00 (0.906) 27.00 (1.063) 6.10 (0.240) 1.10 (0.043) 95 230 480 28R1127-000 3 28.58 (1.125) 23.50 (0.925) 31.00 (1.220) 7.70 (0.303) 1.70 (0.067) 100 220 430 28R1127-200 3 28.58 (1.125) 23.50 (0.925) 24.89 (0.980) 7.70 (0.303) 1.70 (0.067) 85 191 410 28R1127-400 3 28.58 (1.125) 23.50 (0.925) 17.00 (0.669) 7.70 (0.303) 1.70 (0.067) 60 150 330 28R1127-500 3 28.58 (1.125) 23.50 (0.925) 9.70 (0.382) 7.70 (0.303) 1.70 (0.067) 40 110 265 28R1128-100 3 28.58 (1.125) 23.50 (0.925) 26.00 (1.024) 5.88 (0.231) 0.80 (0.031) 79 204 399 28R1128-200 3 28.58 (1.125) 24.00 (0.945) 14.00 (0.551) 5.38 (0.212) 0.80 (0.031) 52 145 312 28R1141-010 3 37.00 (1.457) 27.00 (1.063) 18.25 (0.715) 8.00 (0.315) 1.50 (0.059) 67 168 380 28R1227-100 2 31.12 (1.225) 24.77 (0.975) 13.30 (0.525) 8.26 (0.325) 1.91 (0.075) 52 128 300 28R1236-000 2 31.40 (1.236) 23.00 (0.906) 19.00 (0.748) 7.75 (0.305) 1.50 (0.059) 78 162 370 28R1240-010 2 31.40 (1.236) 23.00 (0.906) 21.00 (0.827) 7.75 (0.305) 1.00 (0.039) 84 211 440 28R1261-100 3 32.00 (1.260) 25.10 (0.988) 35.00 (1.378) 7.75 (0.305) 0.90 (0.035) 140 350 700 28R1261-200 3 32.00 (1.260) 25.10 (0.988) 9.70 (0.382) 7.75 (0.305) 0.90 (0.035) 50 135 310 28R1262-000 2 32.00 (1.260) 26.00 (1.024) 30.00 (1.181) 7.00 (0.276) 1.00 (0.039) 110 260 520 28R1340-100 3 34.00 (1.340) 28.00 (1.100) 12.00 (0.472) 7.00 (0.280) 1.00 (0.039) 50 139 315 28R1340-200 3 34.00 (1.340) 28.00 (1.100) 25.00 (0.984) 7.00 (0.280) 1.00 (0.039) 86 220 449 28R1417-000 2 36.00 (1.417) 26.00 (1.024) 40.00 (1.575) 11.00 (0.433) 1.00 (0.039) 187 393 734 28R1418-000 3 36.00 (1.1417) 33.00 (1.299) 10.00 (0.394) 4.00 (0.157) 1.00 (0.039) 34 104 245 28R1450-100 3 36.83 (1.450) 29.58 (1.165) 10.00 (0.394) 7.75 (0.305) 0.75 (0.030) 48 130 290 Broadband Ferrite EMI Cores For Ribbon & Flex Cables DIMENSIONS mm (inches) Figure # on Page 17 Part Number Typical Impedance ( Z ) in Ohms ( W ) A B C* D E @ 25 MHz @ 100 MHz @ 300 MHz 28R1457-400 3 37.01 (1.457) 33.00 (1.299) 13.46 (0.530) 4.50 (0.177) 0.51 (0.020) 44 140 310 28R1496-000 2 38.00 (1.496) 30.00 (1.181) 25.00 (0.984) 9.25 (0.364) 1.25 (0.049) 91 239 479 28R1517-000 2 38.10 (1.500) 26.67 (1.050) 25.40 (1.000) 12.07 (0.475) 1.91 (0.075) 110 230 520 28R1518-000 1 38.50 (1.516) 26.80 (1.055) 25.40 (1.000) 12.09 (0.476) 1.91 (0.075) 105 235 478 28R1654-010 3 42.00 (1.654) 37.50 (1.476) 5.00 (0.197) 5.00 (0.197) 0.70 (0.028) 27 84 200 28R1775-000 2 45.08 (1.775) 34.42 (1.355) 28.58 (1.125) 12.45 (0.490) 1.52 (0.060) 115 260 530 28R1779-000 2 63.50 (2.500) 52.07 (2.050) 28.58 (1.125) 12.70 (0.500) 1.68 (0.066) 114 298 588 28R1779-100 2 63.50 (2.500) 52.07 (2.050) 12.98 (0.511) 12.70 (0.500) 1.68 (0.066) 65 170 375 28R1799-010 3 45.60 (1.795) 37.00 (1.457) 18.40 (0.724) 7.90 (0.311) 1.40 (0.055) 57 172 388 28R1800-010 2 45.72 (1.800) 35.05 (1.380) 27.94 (1.100) 12.70 (0.500) 1.52 (0.060) 110 260 555 28R1862-000 2 47.70 (1.878) 39.00 (1.535) 31.00 (1.220) 15.00 (0.590) 3.00 (0.118) 116 261 561 28R1953-000 3 49.61 (1.953) 44.00 (1.732) 12.00 (0.472) 7.62 (0.300) 1.45 (0.057) 45 127 300 28R2000-010 2 50.80 (2.000) 40.60 (1.598) 15.20 (0.598) 12.20 (0.480) 2.00 (0.079) 63 170 380 28R2000-200 2 50.80 (2.000) 40.60 (1.600) 28.00 (1.102) 12.20 (0.480) 2.00 (0.079) 103 252 545 28R2170-000 2 55.12 (2.170) 43.69 (1.720) 25.40 (1.000) 12.70 (0.500) 1.27 (0.050) 110 280 550 28R2170-100 2 55.12 (2.170) 43.69 (1.720) 12.70 (0.500) 12.70 (0.500) 1.27 (0.050) 62 170 370 28R3149-000 2 79.98 (3.149) 68.58 (2.700) 12.70 (0.500) 11.99 (0.472) 1.91 (0.075) 51 135 318 Ferrite Core shape and size affect frequency response and impedance. *Broadband ( 28 ) ribbon and flex cable cores are sorted by slot width on page 20 and sorted by impedance on page 21. FIGURE 1 B D A C A FIGURE 2 FIGURE 3 A C E E D D E B C B Please visit www.Lairdtech.com for the most up to date information. All dimensions & impedance values can be sorted and compared on www.lairdtech.com. Custom parts are available. visit www.lairdtech.com for product additions and more product details 17 Broadband Split Ferrite Cores For Ribbon & Flex Cables Laird Techologies’ offers a selection of broadband “split” ribbon and flex cores for retrofit and postassembly operations. Similar in performance to one piece core designs, these split ferrite cores provide excellent differential and common mode EMI suppression on flat cable assemblies. Lightweight, inexpensive metal or plastic end clips and cases provide secure closure of the ferrite onto the flat cable. PART NUMBERING SYSTEM EXAMPLE 28 Material Type S Product Code 0670 -0 0* 0 Part Size Code Selected Dimension Code (Usually Length) Case or Clip Code Additional Part Description *0 = *M = *P = *A = No End Clip Metal Clip Plastic Clip Hinged Case Custom Parts with double sided mounting tape are available. Figure # on Page 19 *Available End Clip Types 28S0670-000 2 28S2001-0*0 Part Number DIMENSIONS mm (inches) Typical Impedance ( Z ) in Ohms ( W ) A B C* D E @ 25 MHz NA 17.02 (0.670) 12.50 (0.492) 14.99 (0.590) 3.40 (0.134) 0.51 (0.020) 60 150 310 1 M, P 63.50 (2.500) 52.07 (2.050) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 280 590 28S2001-2A2 3 Hinged Case 67.08 (2.641) 53.75 (2.116) 27.53 (1.084) 16.66 (0.656) 1.91 (0.075) 80 230 480 28S2011-0*0 1 M, P 76.20 (3.000) 65.28 (2.570) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 280 600 28S2012-0M0 1 M 88.90 (3.500) 78.23 (3.080) 28.58 (1.125) 6.48 (0.255) 0.84 (0.033) 80 240 630 28S2022-0*0 1 M, P 45.09 (1.775) 34.42 (1.355) 28.58 (1.125) 6.35 (0.250) 0.84 (0.033) 100 250 550 28S2023-0M0 1 M 38.10 (1.500) 26.67 (1.050) 25.40 (1.000) 6.35 (0.250) 0.84 (0.033) 115 250 520 28S2827-210 1 NA 21.00 (0.827) 17.00 (0.669) 12.01 (0.473) 3.99 (0.157) 0.94 (0.037) 43 120 270 ** The “D” & “E” dimensions for 28S, split, two piece cores must be doubled for total assembled dimensions. “D” & “E” dimensions shown for hinged case parts are for a complete assemby. @ 100 MHz @ 300 MHz *Broadband ( 28 ) ribbon and flex cable cores are sorted by slot width on page 20 and sorted by impedance on page 21. (side view) Plastic Clip Diagram 18 Metal Clip Diagram Split Ferrite Cores for Ribbon & Flex Cables ** To determine total inside slot gap (I.D.) of an assembled split ferrite ribbon core, multiply the “E” dimension by 2. Both the “D” and “E” dimensions must be doubled for assembled core dimensions. B B E E D A D A C Figure 1 C Figure 2 A E D B C Figure 3 Part #28S2001-2A2 split ferrite core assembly with hinged black plastic case Split ferrite cores for flat / ribbon cables are sold as single sides. It is necessary to order two sides to form one set. [Except 28S2001-2A2 (Figure 3) which is sold assembled] Plastic Clip Assemblies: To specify one core side and one white plastic clip together, replace the second ferrite core part number character after the dash with the letter “P” (example: 28S2022-0P0). One complete assembly of two ferrite core sides (28 material) with two plastic clips would be specified as follows: 2 of part # 28S2022-0P0. Attachment ears are standard. Metal Clip Assemblies: To specify one core side and one metal clip together, replace the second ferrite core part number character after the dash with the letter “M” (example: 28S2022-0M0). One complete assembly of two ferrite cores (28 material) with two metal clips would be specified as follows: 2 of part # 28S2022-0M0 Clips for Bulk Shipment: To order white plastic end clips (with attachment ears) separately in bulk, specify part number ASSE001-2. To order metal end clips separately in bulk, specify part number ASSE017-2. No standard clips are available for 28S2827-210. Split Core with white Plastic Clips Split Core with Metal Clips visit www.lairdtech.com for product additions and more product details 19 QUICK REFERENCE CHART - SORTED BY SLOT WIDTH ( B ) Broadband 28 Material Parts Only One Piece (28R) & Split (28S) Cores for Ribbon & Flex Cables DIMENSIONS in mm Slot DIMENSIONS in mm Slot E** PART NUMBER Sorted by Slot Width A B C D** E** 2.70 0.70 28R1128-200 28.58 24.00 14.00 5.38 0.80 12.00 3.00 0.70 28R1227-100 31.12 24.77 13.30 8.26 1.91 8.00 18.00 5.50 1.00 28R1261-200 32.00 25.10 9.70 7.75 0.90 11.50 8.00 20.00 3.00 0.70 28R1261-100 32.00 25.10 35.00 7.75 0.90 28R0492-100 12.50 8.30 12.00 5.50 1.00 28R1262-000 32.00 26.00 30.00 7.00 1.00 28R0546-000 13.90 9.40 18.00 5.30 0.80 28R1417-000 36.00 26.00 40.00 11.00 1.00 28R0592-010 15.01 10.00 22.86 7.49 1.50 28R1517-000 38.10 26.67 25.40 12.07 1.91 28S0670-000** 17.02 12.50 14.99 3.40 0.51 28S2023-0M0** 38.10 26.67 25.40 6.35 0.84 28R0669-000 17.00 13.00 12.00 3.50 0.75 28R1518-000 38.50 26.80 25.40 12.09 1.91 28R0610-000 15.50 13.50 10.00 3.40 1.40 28R1141-010 37.00 27.00 18.25 8.00 1.50 28R0614-100 15.60 13.60 12.00 2.80 0.70 28R1340-100 34.00 28.00 12.00 7.00 1.00 28R0825-000 20.95 14.00 19.05 7.75 0.80 28R1340-200 34.00 28.00 25.00 7.00 1.00 28R0880-000 22.35 14.00 19.05 7.75 1.50 28R1450-100 36.83 29.58 10.00 7.75 0.75 28R0756-000 19.20 15.00 10.00 5.35 1.15 28R1496-000 38.00 30.00 25.00 9.25 1.25 28R0756-200 19.20 15.00 16.00 5.35 1.15 28R1418-000 36.00 33.00 10.00 4.00 1.00 28S2827-210** 21.00 17.00 12.01 3.99 0.94 28R1457-400 37.01 33.00 13.46 4.50 0.51 28R0984-200 25.00 18.00 16.00 7.70 0.90 28R1775-000 45.08 34.42 28.58 12.45 1.52 28R0984-000 25.00 18.00 24.00 7.70 0.90 28S2022-0*0** 45.09 34.42 28.58 6.35 0.84 28R0898-100 22.80 18.70 12.00 2.80 0.70 28R1800-010 45.72 35.05 27.94 12.70 1.52 28R0898-200 22.80 18.70 16.00 2.80 0.70 28R1799-010 45.60 37.00 18.40 7.90 1.40 28R0945-000 24.00 19.00 10.00 6.25 1.25 28R1654-010 42.00 37.50 5.00 5.00 0.70 28R1024-000 26.00 20.50 10.00 6.00 0.80 28R1862-000 47.70 39.00 31.00 15.00 3.00 28R1025-000 26.00 21.40 10.00 5.00 0.75 28R2000-010 50.80 40.60 15.20 12.20 2.00 28R1101-000 27.97 22.94 14.66 7.75 1.50 28R2000-200 50.80 40.60 28.00 12.20 2.00 28R1102-000 28.00 23.00 15.00 5.80 0.80 28R2170-100 55.12 43.69 12.70 12.70 1.27 28R1236-000 31.40 23.00 19.00 7.75 1.50 28R2170-000 55.12 43.69 25.40 12.70 1.27 28R1102-100 28.00 23.00 20.00 5.80 0.80 28R1953-000 49.61 44.00 12.00 7.62 1.45 28R1240-010 31.40 23.00 21.00 7.75 1.00 28R1779-100 63.50 52.07 12.98 12.70 1.68 28R1103-000 28.00 23.00 27.00 6.10 1.10 28R1779-000 63.50 52.07 28.58 12.70 1.68 28R1127-500 28.58 23.50 9.70 7.70 1.70 28S2001-0*0** 63.50 52.07 28.58 6.35 0.84 28R1127-400 28.58 23.50 17.00 7.70 1.70 28S2001-2A2** 63.50 52.07 24.38 6.35 0.84 28R1127-200 28.58 23.50 24.89 7.70 1.70 28S2011-0*0** 76.20 65.28 28.58 6.35 0.84 28R1128-100 28.58 23.50 26.00 5.88 0.80 28R3149-000 79.98 68.58 12.70 11.99 1.91 28R1127-000 28.58 23.50 31.00 7.70 1.70 28S2012-0M0** 88.90 78.23 28.58 6.48 0.84 PART NUMBER Sorted by Slot Width A B C D** 28R0315-200 8.00 6.00 12.00 28R0453-200 11.50 8.00 28R0480-000 12.20 28R0453-300 ** The “D” & “E” dimensions for 28S split, two-piece cores must be doubled for total assembled dimensions Refer to pages 15, 16, 17, & 18 for more data. 20 Custom Parts are also available QUICK REFERENCE CHART - SORTED BY IMPEDANCE @ 100 MHz Broadband 28 Material Parts Only One Piece (28R) & Split (28S) Cores for Ribbon & Flex Cables TYPICAL IMPEDANCE ( Z ) IN OHMS ( W ) PART NUMBER Sorted by Impedance @ 25 MHz 28R0610-000 29 80 28R1654-010 27 28R1025-000 TYPICAL IMPEDANCE ( Z ) IN OHMS ( W ) PART NUMBER Sorted by Impedance @ 25 MHz 216 28R1779-100 65 170 375 84 200 28R2000-010 63 170 380 24 97 242 28R1799-010 57 172 388 28R0614-100 36 98 245 28R0880-000 93 187 356 28R0315-200 48 102 250 28R0480-000 100 190 320 28R1418-000 34 104 245 28R0825-000 96 190 363 28R0453-200 43 104 260 28R1127-200 85 191 410 28R0756-000 40 107 258 28R1102-100 75 192 380 28R0898-100 38 110 266 28R0546-000 91 193 419 28R1127-500 40 110 265 28R1128-100 79 204 399 28R0669-000 41 110 270 28R1240-010 84 211 440 28R0945-000 43 112 269 28R0984-000 100 220 430 28S2827-210 43 120 270 28R1127-000 100 220 430 28R0898-200 43 127 280 28R1340-200 86 220 449 28R1953-000 45 127 300 28R0592-010 121 227 370 28R1024-000 48 128 299 28S2001-2A2 80 230 480 28R1227-100 52 128 300 28R1103-000 95 230 480 28R1450-100 48 130 290 28R1517-000 110 230 520 28R1261-200 50 135 310 28R1518-000 105 235 478 28R3149-000 51 135 318 28R1496-000 91 239 479 28R1340-100 50 139 315 28S2012-0M0 80 240 630 28R1101-000 55 140 300 28S2023-0M0 115 250 520 28R0756-200 57 140 308 28S2022-0*0 100 250 550 28R1457-400 44 140 310 28R2000-200 103 252 545 28R1128-200 52 145 312 28R1262-000 110 260 520 28R0492-100 68 150 290 28R1775-000 115 260 530 28S0670-000 60 150 310 28R1800-010 110 260 555 28R1127-400 60 150 330 28R1862-000 116 261 561 28R0453-300 65 153 335 28R2170-000 110 280 550 28R1102-000 61 154 340 28S2001-0*0 100 280 590 28R1236-000 78 162 370 28S2011-0*0 100 280 600 28R1141-010 67 168 380 28R1779-000 114 298 588 28R2170-100 62 170 370 28R1261-100 140 350 700 28R0984-200 70 170 370 28R1417-000 187 393 734 @ 100 MHz @ 300 MHz Refer to pages 15, 16, 17, & 18 for more data. @ 100 MHz @ 300 MHz All chart data can be sorted on www.Lairdtech.com visit www.lairdtech.com for product additions and more product details 21 Ferrite EMI Disks and Plates Ferrite Disks and Plates provide a simple, cost-effective solution for radiated and inductively-coupled electromagnetic interference. After the PC board soldering process, a ferrite disk or plate can be installed directly on the source of EMI (such as active devices or unwanted antennas). Features: • Easy installation • Each part for volume production is provided with permanent, double sided 3,5 mil acrylic adhesive with 218 oz./inch2 adhesion. • Samples and sample kits are available with removable and reusable adhesive for "trial and error" testing • Variety of sizes offered • For frequencies above 250 MHz, H series material is generally better than M series material • Custom parts also available. Applications: • Ferrite disks and plates can be utilized either as inductively-coupled components or EMI shields on PC board components and traces. (Inductive coupling occurs when the ferrite affects the conducted wave form leaving the active component. The rise time of the wave form is effectively slowed by the ferrite, and the overshoot and associated ringing are attenuated. EMI shielding occurs when the ferrite absorbs the radiated emissions from active components, effectively protecting other boards or components in the vicinity from radiated contamination). • Can be used to locate unwanted EMI antennas. • Flat Flex & Ribbon cables. • Can also provide retrofit, auxiliary EMI attenuation. HM1400-200 HM1400-300 MM0650-100 MM0787-100 MM0787-200 MM1400-200 MM1400-300 HP1040-100 HP1040-200 MP0315-200 MP0350-000 MP0433-000 MP0512-200 MP0590-200 MP0591-200 MP0760-100 MP1040-100 MP1040-200 MP1040-300 MP1496-000 22 26.42 (1.040) 26.42 (1.040) 8.00 (0.315) 8.89 (0.350) 11.00 (0.433) 13.00 (0.512) 15.00 (0.591) 15.00 (0.591) 19.30 (0.760) 26.42 (1.040) 26.42 (1.040) 26.42 (1.040) 38.00 (1.496) C mm (inches) 1.27 (0.050) 1.91 (0.075) 1.91 (0.075) 2.54 (0.100) 1.27 (0.050) 1.27 (0.050) 1.91 (0.075) 1.91 (0.075) 2.54 (0.100) 1.27 (0.050) 1.91 (0.075) 2.00 (0.079) 1.27 (0.050) 1.96 (0.077) 2.00 (0.079) 2.00 (0.079) 2.00 (0.079) 1.27 (0.050) 1.27 (0.050) 1.91 (0.075) 2.25 (0.089) 2.00 (0.079) PART NUMBER SYSTEM EXAMPLE H M 0787 100 H - Material M - Material M - Disk P - Plate Part Size Indentification Thickness Code Disk Plate EXAMPLE APPLICATION 1 ADHESIVE HM0787-200 B mm (inches) ADHESIVE HM0787-100 A mm (inches) 19.99 (0.787) 19.99 (0.787) 35.56 (1.400) 35.56 (1.400) 16.51 (0.650) 20.00 (0.787) 20.00 (0.787) 35.56 (1.400) 35.56 (1.400) 26.42 (1.040) 26.42 (1.040) 8.00 (0.315) 26.42 (1.040) 11.00 (0.433) 13.00 (0.512) 21.00 (0.827) 15.00 (0.591) 19.30 (0.760) 26.42 (1.040) 26.42 (1.040) 26.42 (1.040) 38.00 (1.496) dB down (relative to baseline noise) PART NUMBER MP 1040-100 HP 1040-100 MP1040-100 and HP1040-100 0 -1 HP -2 -3 MP -4 -5 -6 1 10 Frequency MHz 100 1000 Example Application Graph Explanation: The zero line on the graph represents the base line noise recorded for an unprotected microprocessor. The curves (dB down) represent the performance of the Laird Technologies’ ferrite plates relative to the baseline. The addition of the ferrite plates to the top of the processor in this specific application exhibits up to a 5 dB EMI reduction relative to the unprotected part. In the example application graph above, the ferrite plate MP1040-100 exhibits up to a 1 dB advantage over the HP1040-100 from 1-100 MHz, while the HP1040-100 exhibits a 0,5 dB advantage between 200 and 400 MHz. Performance can vary with different sizes, materials, processors and applications. Visit NORTH AMERICA USA toll-free telephone number +1-800-843-4556 U.S.A. ASIA China Guangzhou, China 1200 East 36th Street P.O. Box 510 Chattanooga, TN., 37401-0510 Phone: +1-423-308-1690 Fax: +1-423-308-1622 Unit 1311, Main Tower Guangdong International Hotel No. 339, Huan Shi Dong Lu Guangzhou City, Guangdong Province P.R. China, 510098 Phone: +86-20-8331-2186 Fax: +86-20-8331-2196 Schaumburg, Illinois, USA Shunde, China Chattanooga, Tennessee 1751 Wilkening Court Schaumburg, IL., 60173 Phone: +1-847-839-6000 Fax: +1-847-519-9682 St. Louis, Missouri, USA 3481 Rider Trail South St. Louis, MO., 63045 Phone: +1-314-344-9300 Fax: +1-314-344-9333 San Jose, California, USA 2030 Fortune Drive, Suite 100 San Jose, CA, 95131 Phone: +1-408-544-9500 Fax: +1-408-577-0691 Lot 15-2 Fuan Industrial Zone Leliu Town, Shunde District Foshan City, Guangdong Provice P.R. China 528322 Phone: +86-757-2563-8860 Fax: +86-757-2563-8862 Beijing, China No. 14, Jin Xiu Street, BDA Beijing, 100176, P.R. China Phone: +86-10-6780-5500 Fax: +86-10-6787-6384 Kunshan, China 1825 Diamond Street San Marcos, CA, 92078 Phone: +1-408-544-9500 Fax: +1-408-577-0691 28 Huanghe South Road Kunshan Economic & Tech Development Zone Kunshan City, Jiangsu Province, P.R. China, 300457 Phone: +86-512-5737-6767 Fax: +86-512-5737-6766 Mexico Tianjin, China San Diego, California, USA Hermosillo, Mexico Obrero Mundial #9 Parque Industrial Dynatech Hermosillo, Sonora, 84170 Phone: +52-662-260-48-32 Fax: +52-662-216-12-02 Reynosa, Mexico Industrial Cntr #5 Parque Industrial Reynosa Calle Brecha E-99 Norte, Lote 23 Reynosa, Tamaulipas, 88780 Phone: +52-889-921-9000 Fax: +52-899-921-9038 Building C3 /C4 Hongtai Industrial Park No. 87 Taifeng Road TEDA, P.R. China 201108 Phone: +86-512-5737-6767 Fax: +86-512-5737-6766 Shanghai, China No. 398, Lane 3088 Hua Ning Road Xin Zhuang Indutrial Zone Shanghai City, P.R. China 201108 Phone: +86-21-6442-8018 Fax: +86-21-6442-8018 Shenzhen, China Bld. 1, Dejin Industrial Park Fuyuanyi Road, Heping Community Fuyong Town, Bao An distric Shenzhen City, Guangdong Provice P.R. China 518103 Phone: +86-21-6442-8018 Fax: +86-21-6442-8018 Suzhou, China No. 228 Tongyuan Road Suzhou Industry Park Suahou, P.R. China 215006 Phone: +86-512-6252-6590 Fax: +86-512-6252-7226 Taiwan San Chung City, Taiwan 3F, 94 Shi-West St. San Chung City, Taipei Hsien, ROC 24152 Phone: +886-2-2287-4187 Fax: +886-2-2287-4173 Korea Singapore Chai Chee, Singapore 750E Chai Chee Road #03-07/08 Technopark, Chai Chee 469005, Singapore Phone: +65-6-243-8022 Fax: +65-6-243-8021 EUROPE Germany Rosenheim, Germany Äußere Oberaustraße 22. 83026 Rosenheim, Germany Phone: +49-8031-2460 Fax: +49-8031-2460-50 Czech Republic Liberec, Czech Republic Prumyslová 497, 462 11 Liberec, Czech Republic Phone: +00420-488-575-111 Fax: +00420-488-575-303 Bucheon-si, Korea 160-1 4F, Dodang-dong, Wonmi-gu Bucheon-si, Gyeonggi-do, Korea 420-805 Phone: +82-32-684-1370 Fax: +82-32-684-1360 Seoul, Korea A-4th Floor, Woorim Lion’s Valley, 371-28 Gasan-Dong, Gumcheon, Seoul, 153-786, Korea Phone: +82-2-830-2095 Fax: +82-2-830-2095 Japan Shin Yokohama, Japan Shin Yokohama Business Center Bldg 7F, 2-6 Shin Yokohama 3-chome, Kohoku-Ku, Yokohama-shi, Kanagawa, 222-0033 Japan Phone: +81-45-473-6808 Fax: +81-45-473-6162 NOTICE: Although the information and recommendations set forth herein (hereinafter “information”) are presented in good faith and believed to be correct as of the date hereof, Laird Technologies makes no representation or warranties as to the completeness or accuracy thereof. Information is supplied upon the condition that the persons receiving same will make their own determination as to its suitability for their purposes prior to use. In no event will Laird Technologies be responsible for damages of any nature whatsoever resulting from the use or reliance upon information or the product to which information refers. Nothing contained herein is to be construed as a recommendation to use any product, process, equipment or formulation in conflict with any patent, and Laird Technologies makes no representation or warranty, expressed or implied, that the use thereof will not infringe any patent. The data set forth in all tables, charts, graphs and figures herein are based on samples tested and are not guaranteed for all samples or applications. Such data are intended as guides and do not reflect product specifications for any particular product. NO REPRESENTATION OR WARRANTIES, EITHER EXPRESSED OR IMPLIED, OR MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR OF ANY OTHER NATURE ARE MADE HEREUNDER WITH RESPECT TO INFORMATION OR THE PRODUCT TO WHICH INFORMATION REFERS. www global solutions : local support .lairdtech.com for more information on Laird Technologies engineered EMI, antenna and thermal interface product lines. ™ global solutions : local support ™ Laird Technologies is the world-leader in the design and supply of customized performance-critical products for wireless and other advanced electronic applications. Laird Technologies partners with its customers to help find solutions for applications in various industries such as Aerospace, Automotive Electronics, Computer, Consumer Electronics, Data Communications, Medical Equipment, Military, Network Equipment and Telecommunication industries. www.lairdtech.com SIP-CAT-CABLECORE#46-0208
TYS4020100M-10 价格&库存
很抱歉,暂时无法提供与“TYS4020100M-10”相匹配的价格&库存,您可以联系我们找货
