12040
    MAKEBLOCK(创客工场)
    MEGAPI ENCODER/DC MOTOR DRIVER V
12040 数据手册
  MegaPi Encoder/DC Motor Driver  SKU: 12040 Weight: 5.00 Gram Description: This encoder motor is capable of driving two DC motors or one encoder motor. It has 16 pins, allowing you to connect with MegaPi by simply plugging in. The motor driver IC on the board is TB6612, which is a high efficiency MOSFET driver with low heat dissipation. Overcurrent protection included to prevent the driver IC from burning out. Features: • 6 V to 12 V motor supply range; • 1 A maximum continuous current per motor (2 A peak); • Over-current protection; • Capable of driving one encoder driver (white interface) or two DC motors (green interface); • Color-code male and female pins ensure connecting with MegaPi correctly; • TVS protection included in the interface for driving encoder motors; • Small size for easy connecting with MegaPi; Specification: • Motor driver: TB6612FNG • Motor channels: 2 • Minimum operating voltage: 6 V • Maximum operating voltage: 12 V • Logic voltage: 5V • Continuous output current per channel: 1 A • Peak output current per channel: 2 A Dimensions: • 1.5cm x 3.0cm                                                 http://store.makeblock.com/megapi‐encoder‐dc‐motor‐driver 11‐16‐17
12040 价格&库存
很抱歉,暂时无法提供与“12040”相匹配的价格&库存,您可以联系我们找货
