5E /5G
The Multimec 5E and 5G series is the new generation
of the existing 3A, 3C, 3E, 3F, 4A and 4Fmultimec
switches. The 5E and 5G series is a narrower product
line, but the flexibility is more advanced. The switches
will be supplied in high temperature material only to
stand today’s advanced soldering processes. The
cap holding system is improved, by a superior snap
system.
The 5E and 5G series can be supplied with LED’s
integrated in the switch and also as a surface mount
switch. A high variety of aesthetic designed keycaps
is available for the multimec switches both as solid
caps, but also with excellent illumination possibilities.
The standard program will include three different
actuation forces: 2, 3.5, and 6.5N. The multimec
switches are known for their crisp audible tactile
feel although a quiet version is available for sensitive
applications such as audio, conference and military
equipment.
The switch can be used as through-hole or SMD
versions, and are designed to be used in a wide
variety of applications.
Distributor:
www.mec.dk
multimec®
5E/5G
Technical Data:
through-hole or SMD / 50mA/24VDC / single pole/momentary
10.000.000 operations life time / IP67 sealing / actuation force: 2.0, 3.5, 6.5 N
high temperature -40/+160º C
5GTH9 (through-hole)
0.8
Min 10.16
Max 12.5
0.3
7.62
Max 10.3
6.4
0.3
0.8
Min 10.16
Max 12.5
Min 10.16
Max 12.5
7.62
0.8
4
0.3
5ETH9 (through-hole)
6.4
8.5
5GTH9 (through-hole) 1+2 LED
7.62
10,16
-2
1
10.16
7,62
10.1
2
10.16
10.1
2
1
1
Max 10.3
10,16
- 2
7.62
3+
10.1
10.1
4
7.62
Ø0,9
ø 0.9
ø 0.9
4
1
3
7,62
G
R
4
3
Ø0,9
3+
4
5GSH9 (SMD) 1+2 LEDS
14
5ESH9 (SMD)
0.8
14.0
7.62
0.3
0.8
6.4
6.4
0.3
0.3
8.5
5GSH9 (SMD)
7.62
0.8
7.62
14.0
Max 10.3
12,5
-2
1
12.5
12,5
2-
7.62
1
2.5
4
2.5
7,62
G
R
1.2
1.2
1.2
Max 10.3
10.1
3+
7.62
10.1
7,62
1,2
4
2,5
12.5
10.1
10.1
3+
2.5
HOW TO ORDER
5 G
Switch Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Switch
5 G
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Switch Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
See colour codes on our website: www.mec.dk
Dimensions (mm) Unless otherwise specified, all tolerances +- 0,2
Ordering example: 5GSH96535
mec
Industriparken 23 . DK-2750 Ballerup . Denmark
Tel.: +45 44 97 33 66 . Fax: +45 44 68 15 14 . E-mail: danmec@mec.dk . www.mec.dk.
mec a/s dec. 2009
5 E
LED
01 blue / 22 green / 42 yellow / 61 white / 82 red / 2242 green/yellow /
8222 red/green / 8242 red/yellow
1A/1H/1M/1ZA
1A/1H/1M/1ZA series caps have a hinge-type
retention system which gives a rocker-action actuation when mounted on Multimec 5G switch.
Illumination can be provided with 1A in transparent colours or 1H with different colour lenses.
1A/1H, 1ZA and 1M caps offer three different dimensions, many solid and transparent colours as
well as lens colours. 1A has many legend options
in its standard offering; however, all caps can be
provided with custom legends.
*Letter legends on the picture are not standard
Distributor:
www.mec.dk
multimec®
5G + 1A/1H/1M/1ZA
Technical Data:
through-hole or SMD
50mA/24VDC
10.000.000 operations lifetime
IP67 sealing
temp. range: switch:-40/+160°C
LED: -30/+85°C
solid keycap: -40/+65°C
transparent keycap: -40/+85°C
+3
12,5
8 - 10
12,2
8 - 10
12,2
10,1
4
18,65
3
7,62
10,1
4
2
1
3
Ø 0,9
Ø 0,9
4
25,0
1
1,2
2,5
2
1
7,62
10,1
1,2
10,1
7,62
4
12,50
10,16
2
12,50
PCB layout
PCB layout
10,16
1
7,62
7,62
PCB layout
12,50
-2
Min. 10,16
Max. 12,5
7,62
PCB layout
0,8
14,0
7,62
Min. 10,16
Max. 12,5
0,8
0,3
0,8
7,62
Dimensions (SMD)
1M
0,3
0,3
0,8
14,0
Dimensions (through-hole)
1ZA
8 - 10
12,2
Dimensions (TH w/LED)
1H
8 - 10
0,3
12,2
Dimensions (SMD w/LED)
1A
2,5
3
HOW TO ORDER illuminated
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q**
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
1H
1A
Colour code
00 blue
06
02 green 08
03 grey 09
04 yellow
1H
white
red
black
Lens 1H
1 transparent
2 green
4 yellow
6 frosted white
8 red
Colour code 1A
10 frosted blue
16 frosted white
12 frosted green 18 frosted red
14 frosted yellow
HOW TO ORDER non-illuminated
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q**
Cap
**Quiet version is only available for actuation force 2.0N (20) and
the letter Q is added to the end of the switch part number. See
the ordering example.
1A
1ZA
1M
Colour code
30*ultra blue
00 blue
40*dusty blue
02 green
42*aqua blue
03*grey
32 mint green
04 yellow
33 tele grey
06*white
34 melon
08 red
38 noble red
09*black
50*metal dark blue
53*metal light grey
57*metal dark grey
58 metal bordeaux
* Colours for 1ZA
Dimensions (mm) Unless otherwise specified, all tolerances +/- 0,2
Ordering example: 5GSH93582 + 1H068 with illumination
5GTH965 + 1ZA57 without illumination
**5GTH92001Q with illumination or 5GSH920Q (quiet version)
For updates of products and/or changes of specifications please see www.mec.dk
MEC A/S Industriparken 23 • DK-2750 Ballerup • Denmark
Phone: +45 44 97 33 66 • Fax: +45 44 68 15 14 • E-mail: danmec@mec.dk • www.mec.dk.
MEC A/S September 2011
5 G
1B/1C+2C/2D
1B/1C cap and 2C/2D bezel series have a
award-winning design. The cap is connected to
the bezel with a hinge-type retention system and
the bezel snaps on to the switch.
The series provides many design options with its
solid and transparent colour range as well as different illumination option.
Illumination can be achieved by using 1B cap in
transparent colour, 1C cap with a lens or 2D bezel with a lens where LED is placed on the PCB.
Distributor:
www.mec.dk
multimec®
5G + 1B/1C + 2C/2D
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
LED: -30/+85°C
12,2
1B+2D
-2
4
7,62
9,5
7,62
3
Ø 0,9
3
Ø 0,9
12,6
1
1
15,1
2
15,1
4
12,6
12,5
10,16
1
7,62
9,5
15,1
1,2
7,62
9,5
3,81
15,1
10,16
2
15,1
PCB layout
15,1
12,5
7,62
PCB layout
15,1
2,5
0,8
14,0
7,62
PCB layout
PCB layout
15,1
12,6
0,8
Min. 10,16
Max. 12,5
7,62
3,81
Min. 10,16
Max. 12,5
4
1,2
0,3
0,8
0,3
7,62
0,3
0,8
14,0
9,5
0,3
8
8
12,2
1C+2C
8
8
12,2
1B+2C
12,2
Dimensions (SMD)
1B+2D
+3
2,5
12,6
5 G
Switch
1 C
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
2 C
Cap
solid
colour
Bezel
Colour Lens
code
Colour code
1 B
2 D
Bezel
Cap
Colour code
transparent
Colour Lens
code
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
1 B
Cap
solid
colour
Colour
code
or
2 C
Bezel
Colour
code
2 D
Bezel
Colour Lens
code
*Quiet version only available for actuation force 2.0N (20) and the letter Q is added to the end of the switch part number. See the orde-
Solid caps
00 blue
06 white
02 green 08 red
03 grey
09 black
04 yellow
For 1B and 2C only:
30 ultra blue
33 tele grey
40 dusty blue
34 melon
42 aqua blue
38 noble red
32 mint green
Ordering example: 5GTH93561+1C001+2C09 with illumination
5GSH954+1B08+2D081 without illumination
**5GSH92001Q or 5GTH920Q (quiet version)
50
53
57
58
metal dark blue
metal light grey
metal dark grey
metal bordeaux
Lenses
1 transparent
2 green
4 yellow
6 frosted white
8 red
COLOUR CODES
Transparent caps
10 frosted blue 16 frosted white
11 transparent 18 frosted red
12 frosted green
14 frosted yellow
1DS /1ES /1FS
The new caps for the Multimec switches 1DS /
1ES / 1FS is optimized with a “snap on” system
to ensure the cap to stay on the switch actuator
even under heavy vibrations or similar scenarios.
The 1DS cap is a solid cap which can be
supplied in different colours
The 1ES cap is a solid cap like 1DS, but with
a small round lens for intensive or smooth
illumination
The 1FS cap is a solid cap like 1DS, but with
a large round lens for intensive or smooth
illumination
Distributor:
www.mec.dk
multimec®
5G + 1DS/1ES/1FS
Technical Data
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED:-40/+85°C
solid cap +65°C
transparent +85°C
0.8
Min 10.16
Max 12.5
7.62
0.3
14.9
8.2
0.8
0.8
7.62
PCB layout
PCB layout
10.16
12.5
1
-2
1
7,62
7.62
10.1
PCB layout
10,16
4
+3
10.3
1.2
ø 0.9
4
10.1
7.62
-2
7.62
14.0
10.1
0.3
ø 11.0
ø 9.6
0.8
14.9
8.2
0.8
14.9
Min 10.16
Max 12.5
ø 11.0
ø 9.6
8.2
ø 11.0
ø 9.6
Dimensions (SMD)
Dimensions (w. LED)
0.8
+3
Ø0,9
10.1
2.5
HOW TO ORDER
5 G
Switch Mounting
TH9 through
-hole
SH9 surface
mount
Actuation
force
65
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
1ES with lens
1FS with lens
Colour code
00 blue
03 grey
08 red
09 black
Lens
1 transparent
6 frosted white
1DS
11 transparent
16 frosted white
Switch Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Cap
1DS solid colour
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
Ordering example: 5GTH935 + 1DS08
mec
Industriparken 23 .DK-2750 Ballerup . Denmark
mec a/s dec. 2009
5 G
1GAS/1GCS
The 1GAS/1GCS caps are optimised for use with
foil overlays.
Compared to conventional membrane panels it
provides an extremely rugged and a long-term
cost-effective solution with increased reliability,
enhanced product life and improved tactile feel.
The new caps have 9 standard colour options:
blue, green, grey, yellow, white, red, black, transparent and frosted white.
Even more, the under part of the new cap series
has been cleared, so the caps in transparent and
frosted white can provide excellent illumination.
When used with the 2SS variable height extender, the 1GAS/1GCS caps can be to any required
operating height between 17.5-22.5mm.
Distributor:
www.mec.dk
multimec®
5G + 1GAS/1GCS
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
LED: -30/+85°C
solid keycap: -40/+160°C
Dimensions (SMD w/LED) +
1GAS
P11
7,62
0,8
14,0
PCB layout
12,50
10,16
3
7,62
10,3
1,2
7,62
2,5
2
1
4
2,5
10,16
1
4
+3
7,62
PCB layout
2
7,62
-2
1
1,2
12,50
2
7,62
PCB layout
10,3
0,8
Min. 10,16
Max. 12,5
1
7,62
PCB layout
10,1
0,3
0,8
0,3
7,62
Min. 10,16
Max. 12,5
10,1
4
12,5
12,5
0,8
14,0
P15
P15
12,5
0,3
0,3
12,5
P11
Dimensions (TH w/LED) +
1GCS
Dimensions (through-hole) +
1GCS
12,5
Dimensions (SMD) +
1GAS
3
4
3
Ø 0,9
Ø 0,9
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
transparent colour
1GAS
Colour code
11 transparent
16 frosted white
1GCS
Switch
Mounting
TH9 through-hole
SH9 surface mount
Cap
solid colour
Actuation force
65
Q*
*Only available for actuation force 2.0N (20) and the letter Q is added
to the end of the switch part number. See the ordering example.
1GAS
1GCS
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
Ordering example: 5GSH935 + 1GAS09 without illumination
5GTH96501 + 1GCS16 with illumination
*5GSH920Q or 5GTH92061Q (quiet version)
MEC A/S May 2012
5 G
1JS
MEC’s exclusive snap-on keycap in 10.4 mm
total height. Optimized for use with foil overlays.
The 1JS keycaps are available in nine standard
colours: 00 blue/02 green/03 grey/04 yellow/06
white/08 red/09 black/11 transparent/16 frosted
white.
In combination with the switch the 1JS becomes
the lowest illuminated keycap possible;
especially designed for foil overlays and
featuring soft edges for extended foil overlay
lifetime. The 1JS 11 transparent/16 frosted white
has superior illumination potential when combined with the newest Multimec 5G switch. The
switch can be either surface mount or throughhole. Cap retention is optimized with an innovative “snap-on” system.
Distributor:
www.mec.dk
multimec®
5G + 1JS
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED: -30/+85°C
solid cap: +65°C
transparent: +85°C
12,50
2,4
2
7,62
10,4
10,4
0,7
2,4
2
0,3 Min. 10,16
Max. 12,5
PCB Layout SMD
R
0,7
R
14,0
0,8
1,20
7,62
2,50
7,62
PCB Layout TH
10,16
1,2
7,62
7,62
P9,6
0,8
Max 10,0
P9,6
10,0
12,50
Max 10,0
10,0
2,5
HOW TO ORDER
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
1 J S
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
Cap
1JS transparent
1 J S
Actuation force
65
Ordering example: 5GTH935+1JS08 without illumination
Cap
1JS solid colour
Colour code
11 transparent
16 frosted white
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
5GTH93501+1JS16 with illumination
For product updates and/or changes of specifications please see www.mec.dk
MEC A/S Feb 2011
5 G
1KS/KBS/KCS
The 1KS series is square caps with measurements of 14.3 x 14.3 mm and can be used with
the 2K bezel, which snaps into the front panel, or
alone without the bezel.
The 1KS is with a flat top, the 1KBS with a convex top and 1KCS with a concave top. All three
versions are designed for illumination with a nice
distribution of the illumination to the whole cap
surface. The caps also offer the designer the option of using interchangeable legends or standard
printed graphics. A legend can be printed on the
top lid surface or a foil with the legend is placed
between the transparent lid and the lens.
the 1KS/1KBS/1KCS caps can be to any required
operating height between 24.1-29.1mm.
Distributor:
www.mec.dk
multimec®
5G + 1KS/1KBS/1KCS
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
LED: -30/+85°C
Dimensions (SMD w/LED) + 1KCS
0,8
14,3
-2
4
3
17,75
4
Ø 0,9
14,3
14,3
1
1,2
3
1
7,62
14,3
1,2
7,62
2,5
12,50
2
7,62
1
14,6
PCB layout
10,16
2
2,1
7,62
PCB layout
12,50
14,6
0,8
14,0
7,62
PCB layout
14,3
20,1
0,3
0,3
16,4
11,6
11,6
7,62
Min. 10,16
Max. 12,5
4
19,1
20,2
19,1
11,6
19,1
0,3
0,8
14,0
R25
Dimensions
(Bezel)
(optional)
17,75
Dimensions (TH w/LED) + 1KBS
R18,7
5
Dimensions (SMD) + 1KS
2,5
+3
14,3
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
1 1 1 6
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap frosted white lens and
transparent lid
1 K S
2 K
Bezel
03 grey
06 white
08 red
09 black
1KS
1KBS
1KCS
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
Ordering example: 5GTH93501+1KCS1116+2K09 with illumination
5GSH965+1KS09+2K03 without illumination
*5GTH92082Q or 5GSH920Q (quiet version)
Cap
1KS
1 6
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
2 K
Bezel
03 grey
06 white
08 red
09 black
MEC A/S October 2011
5 G
1PS /1QS /1RS
The new caps for the Multimec switches 1PS /
1QS / 1RS is optimized with a “snap on” system
scenarios.
- The 1PS cap is a solid cap which can be
- The 1QS cap is a solid cap like 1PS, but with
a rectangular lens for intensive or smooth
illumination
- The 1RS cap is a solid cap like 1PS, but with
a round lens for intensive or smooth
illumination
Distributor:
www.mec.dk
multimec®
5E/5G + 1PS/1QS/1RS
Technical Data
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED:-40/+85°C
solid cap +65°C
transparent +85°C
6.5
Max 12.5
Min 10.16
Max 12.5
7.62
Min 10.16
Max 12.5
Dimensions (SMD)
Max 12.5
6.5
0.3
0.8
0.3
0.8
0.3
6.5
10.4
10.4
15.7
10.4
15.7
Max 12.5
Dimensions (w/LED)
15.7
0.8
7.62
7.62
PCB layout
12.5
1
10.3
-2
7.62
Max 10.1
10,16
1
1RS
ø 0.9
4
7.62
10.3
-2
1.2
10.16
PCB layout
10.1
1QS
PCB layout
Max 10.1
10.3
10.1
+3
2.5
4
+3
10.3
Ø0,9
HOW TO ORDER
5 G
Switch Mounting
TH9 through
-hole
SH9 surface
mount
Actuation
force
65
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
1QS with lens
1RS with lens
Colour code
00 blue
03 grey
08 red
09 black
Lens
1 transparent
6 frosted white
1PS
11 transparent
16 frosted white
5 E
5 G
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Ordering example: 5ETH935+1PS08
mec
Cap
1PS solid colour
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
Industriparken 23 . P.o. Box 26 . DK-2750 Ballerup . Denmark
mec a/s dec. 2009
Switch to be used: 5E or 5G
1SS/1LS/1IS
1SS/1LS/1IS are optimised with a “snap-on”
system to ensure the cap to stay on the switch
actuator even under heavy vibrations or similar
scenarios.
- The 1SS cap is solid cap which can be supplied in different colours
- The 1LS cap is a solid cap like 1SS, but with
a small round lens for intensive or smooth illumination
- The 1IS cap is a transparent or frosted white
cap like 1SS, for intensive or smooth illumination
Distributor:
www.mec.dk
multimec®
5E/5G + 1SS/1LS/1IS
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
LED: -30/+85°C
Dimensions (SMD w/LED) + 1IS
Dimensions (TH w/LED) + 1LS
10,16
10,3
10,3
4
0,8
2,5
P3
3
12,50
-2
1
7,62
10,3
4
1,2
0,8
2
1
PCB layout
10,3
3
Ø 0,9
1
4
1,2
PCB layout
12,50
7,62
10,1
0,3
PCB layout
2
7,62
14
7,62
Min 10,16
Max 12,5
10,1
6,4
12,0 - 22,5
8,0 - 22,5
0,3
0,8
0,3
7,62
14
10,4 - 22,5
P6,5
P6,5
P6,5
7,62
Dimensions (SMD) + 1SS
2,5
+3
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
Cap
Colour code
1LS with lens 00 blue
03 grey
08 red
09 black
1IS
11 transparent
transparent
16 frosted white
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Lens
1 transparent
2 green
4 yellow
6 frosted white
8 red
Height/1LS
12.0 19.0
15.0 22.5
16.0
Height/1IS
10.4 16.0
11.0 19.0
12.0 22.5
15.0
5 G
Mounting
Switch TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
Cap
1SS
solid colour
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
Height
16.0
08.0
19.0
09.5
22.5
10.4
11.0
12.0
15.0
Ordering example: 5ETH920+1SS0409.5 without illumination
5GSH93542+1IS1619.0 with illumination
*5ESH920Q or 5GTH9208222Q (quiet version)
MEC A/S February 2012
5 E
Panel sealed
1TS/1US/1VS
The sealings 1TW/1UW/1VW provide an opportunity of having the 1TS/1US/1VS caps with
panel sealing.
Level of sealing from front panel:
5G+1TS+1TW = IP67
5G+1US+1UW = IP67
5G+1VS+1VW = IP65
The solution is excellent for rough environment,
designed for outdoor, dusty and humid applications.
Distributor:
www.mec.dk
multimec®
5G+1TS/1US/1VS+1TW/1UW/1VW
Technical Data:
through-hole or surface mount
50mA/24VDC
Switch: IP67 sealing
LED: -30/+85°C
Dimensions (TH w/LED) 1US+1UW Dimensions (SMD w/LED) 1VS+1VW Recommended
5,3
panel cut-out
PCB layout
14,9
8,2
11
12,50
10,16
7,62
13,25
4
+3
4
12,0
14,65
2,5
Distance between
PCB and front panel
3
P22,0
4
P17,5
11
11
11
P21,0
1
Ø 0,9
4
P
13,65
2
10,8 B0,1
3
1
1,2
4
-2
7,62
1
10,4
2
7,62
12,0
10,6
5,5
PCB layout
Ø10,6
4
7,62
PCB layout
10,16
10,6
12,0
0,8
14
7,62
Min. 10,16
Max 12,5
1TS - 11x11mm
1US - Ø11mm
1VS
6,7
0,8
0,3
7,62
0,3
0,8
11,8
0,3
Min. 10,16
Max 12,5
0,8
14,9
8,2
0,8
8,2
0,8
14,9
6,7
6,7
Dimensions (TH) 1TS+1TW
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
1TS
Colour code
16 frosted white
Sealing
1TW
1US
1UW
1VS
1VW
Switch
Mounting
TH9 through-hole
SH9 surface mount
Cap
1TS
1US
1VS
Actuation force
65
Q*
Colour code
00 blue
03 grey
08 red
09 black
Sealing
1TW
1UW
1VW
Ordering example: 5GSH935 + 1TS03 + 1TW without illumination
5GTH96542 + 1US16 + 1UW with illumination
*5GSH920Q or 5GTH92082Q (quiet version)
MEC A/S November 2011
5 G
1ZW
“with panel seal”
Controlmec TM is a five position integrated
switch solution, designed for outdoor, dusty and
humid applications, to control a unit, navigate in
a display, operate auxiliary equipment on a
vehicle, boat or similar. The Controlmec is
sealed to IP67, and exist of:
- One complete solid cap, with recess on the
back site for the seal efficiency
- The unit panel plate (customers design)
- A gasket to seal between the cap, and the
panel.
- A support ring to ensure the right position of
sealing behind the front plate
- And then the PCB including the switches
The PCB with the switches, shall be assembled
according to the MEC datasheet, and mounted
to the back side of the front panel by bolts, to
ensure the right pressure for the sealing efficiency.
The Controlmec is an extension of the Navimec
system which includes the Multimec switches,
of excellent high quality and long lifetime.
Configurations can be made with through hole
or SMD switch versions, provided they are
accurately positioned.
Distributor:
www.mec.dk
controlmec®
1ZW “sealed”
Technical Data
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED:-40/+85°C
solid cap +65°C
transparent +85°C
Dimensions 1ZW
Mounting example
1ZW
_ 0.20
2.0 +
_ 0.05 with panel seal
6.9 +
Hole in front plate ø 30,3 +- 0,1
1 ZZ Seal
41.4
5.1
29.5
1ZY Seal support
1 pcs. 5GTH920 (+LEDs)
4 pcs. 5ETH935
Recommented PCB layout
PCB
7.62
25.4
10.16
ø 0.9
25.4
Panel seal
HOW TO ORDER
5 G
Switch Mounting
TH9 through
-hole
SH9 surface
mount
Actuation
force
65
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap for seal
1ZW
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
11 transparent
16 frosted white
Seal
1ZZ
Seal support
1ZY
Switch Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Ordering example (sealed version) 1ZW: 1 x 5GTH920 + 4 x 5ETH935 + 1ZW03 + 1ZZ + 1ZY
mec
mec a/s dec. 2009
5 E
1Z
“without panel seal”
Controlmec TM is a five position integrated switch
solution, designed for easy activations for indoor
and non-dusty applications, to control a unit,
navigate in a display, operate auxiliary equipment
indoor on a vehicle, boat or similar. The Controlmec
can also be supplied as an IP67 sealed solution.
The Controlmec exist of:
The PCB including the switches
according to the MEC datasheet, and mounted to
the back side of the front panel.
system which includes the Multimec switches, of
Configurations can be made with through hole or
SMD switch versions, provided they are accurately
positioned.
Distributor:
www.mec.dk
controlmec®
1Z “without sealing”
Technical Data
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED:-40/+85°C
solid cap +65°C
transparent +85°C
29.5
_ 0.10
7.2 +
5.1
_ 0.20
2.0 +
Dimensions 1Z
1Z
7.62
25.4
11.85
10.16
ø 0.9
10.16
7.6
25.4
Hole in Front Plate ø 30.3 +- 0.1
4 pcs. 5ETH935
35.4
25.4
25.4
35.4
HOW TO ORDER
5 G
Switch Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
Cap
1Z
Colour code
00 blue
02 green
03 grey
04 yellow
06 white
08 red
09 black
11 transparent
16 frosted white
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Ordering example (unsealed version)1Z: 1 x 5GTH920 + 4 x 5ETH935 + 1Z03
mec
mec a/s dec. 2009
5 E
Navimec
Navimec Module
Technical Data:
standard and illuminated
module should be attached to the
front plate with bolts (bolts not
supplied by MEC)
50mA/24VDC
switches sealed to IP67
temperature range:
switch body:-40/+160°C
LED: -30/+85°C
Dimensions illuminated Navimec module
Ø3,2 (x4) PCB 1,5
8-10 mm
40
32
Recommended panel cut-out:
ø = 35,0 - 35,5 Depending on application
PCB layout for Navimec solution
Ø3,2 (x4) PCB 1,5
SMD
4,7
9,6 (incl. housing)
25,00
33
46
33
50
Ø34,25
TH
25,00
7
25,00
40
32
3,5
8-10 mm
Dimensions Standard Navimec module
4,6
Ø34,25
*When the 1ZB is activated the diameter changes from 34,25mm to 35,0mm
HOW TO ORDER
Navimec Module ordering options:
Navimec Module excl. keycaps
Navimec Module incl. keycaps
Navimec Module incl. keycaps with legends
illuminated Navimec Module excl. keycaps
illuminated Navimec Module incl. keycaps with legends
Circuit diagram Navimec module
illuminated
CON20
SW3
17
19
SW4
SW2
SW1
3
2
1
4
3
2
1
4
3
2
1
4
Part no. for switches and caps:
Navimec Module has many customisation options regarding actuation
force, cap and LED colours and legends. Because of that ordering is
based on part numbers of separate parts instead of one specific part
number. MEC has the switches mounted on the module before delivery,
which is included in the module price.
See the other side for information on switch and cap options as well as
the examples below.
SW4-1
16
SW5
14
13
Part no. 9810120 - PCB and connector for Navimec Module
Part no. 9810125 - PCB and connector for illuminated Navimec Module
SW4-2
15
SW3-2
SW3-1
10
Standard
12
1
11
2
9
SW4
10
9
8
7
6
5
4
3
2
1
SW5-2
SW5-1
8
1
6
2
7
1
2
1
2
2
4
3
2
1
4
SW2-2
SW2-1
4
SW5
2
1
3
SW2
1
3
1
5
SW3
SW1-2
SW1-1
J1
2
SW1
For example:
9810120 + 4x 5GTH920 + 1x 5GTH920 (without caps)
9810120 + 4x 5GTH965+1ZB42 + 1x 5GTH965+1ZCS42 (with caps)
9810125 + 4x 5GTH93501+1ZB16LM136 + 1x 5GTH93501
+1ZCS16LM118 (painted caps with laser engraved legends)
The connector on the standard Navimec
module is JST SMT S108-PH-SM3-TB or
similar. We recommend using:
Cable socket: JST PHR-10 or similar
Contact: JST SPH-002T-P0.5S or similar
The connector on the illuminated Navimec
module is CI1120M1H or similar.
We recommend using:
Cable socket: Cvilux CI1120S0000 or similar
Contact: Cvilux CI11T011PP0 or similar
Distributor:
www.mec.dk
multimec®
5G + 1ZB/1ZCS
Technical Data:
through-hole or SMD
50mA/24VDC
IP67 sealing
temperature range:
LED: -30/+85°C
PCB layout
bicolour SMD
PCB layout SMD
Dimensions (SMD w/LED) + 1ZCS
R1
1,5
12,50
Min 10,16
Max 12,5
7,62
90°
PCB layout
PCB layout
-2
1
7,62
3
4
+3
3
10,16
2
Ø14,3
4
1
-2
1
4
+3
7,62
7,62
2,5
PCB layout
bicolour TH
10,16
1
7,62
4
2,5
PCB layout TH w/LED
12,50
1,2
R=7,4
1
2,50
7,62
R=17,5
(actuated)
4
7,62
10,16
2
1,2
0,8
14
-2
1
7,62
0,3
8
8
11,7
1,8
12,2
0,8
0,3
12,50
2
1,20
Dimensions (through-hole) + 1ZB
+3
4
Ø09
3
Ø 0,9
Ø 0,9
5 G
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
LED
01 blue
22 green
42 yellow
61 white
82 red
2242 green/yellow
8222 red/green
8242 red/yellow
1 Z B 1 6 L M
Cap
frosted white
with black soft
touch paint and
laser marking
Legend code
136
1 Z C S 1 6 L M
Legend code
118 OK
123
Cap
Switch
Mounting
TH9 through-hole
SH9 surface mount
Actuation force
65
Q*
1 Z B
Cap
1 Z C S
Cap
added to the end of the switch part number. See the ordering example.
Ordering example:
4x 5GTH93561+1ZB16LM136 + 1x 5GTH93561+1ZCS16LM118 (with illumination)
4x 5GSH920+1ZB09 + 1x 5GSH920+1ZCS09 (without illumination)
Colour code
02 green
03 grey
06 white
08 red
09 black
30 ultra blue
40 dusty blue
42 aqua blue
50 metal dark blue
53 metal light grey
57 metal dark grey
58 metal bordeaux
Legend code**
136
Legend code**
038 RESET
105 ENTER
118 OK
119 SET
120 MENU
121 FUNC
122 HOME
123
*5GTH92001Q or 5GSH920Q (quiet version)
** White legends on black caps are standard, other options
are available but considered custom products.
For product updates and further information see our website: www.mec.dk
MEC A/S July 2011
5 G
