H-Bridge click
PID: MIKROE‐3031
Weight: 25 g
H‐Bridge click is a high-efficiency dual H-bridge driver Click board™, capable of
providing reasonably high current while driving the connected load with up to 7V. Since
the used driver IC has two full H-bridge channels, this Click board™ is an ideal solution
for driving smaller bipolar stepper motors. H-Bridge click provides driving in both
directions, with an addition of the brake mode, and the high impedance mode (Hi-Z).
Overshoot current suppression algorithm protects the output stages from being
damaged if both high-side and low-side MOSFETs on a single H-bridge channel become
conductive.
Four control input lines allow independent control of the two H-bridge channels via the
MCU. Featuring a set of protection and driving functions, this highly efficient Click
board™ can be used in a wide range of applications, where driving smaller bipolar step
motors or small brushed DC motors is required. It is an ideal solution for light 3D printer
elements driving, for precision actuators, an accurate positioning of various moving
elements by using stepper motors, and similar applications.
How does it work?
The Click board™ uses the MC34933, a dual H-bridge driver, from NXP. This IC is a highly
integrated device, which requires a minimal number of external elements. Each of the Hbridge channels features two high-side and two low-side MOSFETs, used to control the
current flow through the coils of the motor. The driver IC is produced by using the
Freescale's proprietary SMARTMOS process, which ensures high efficiency and low
power consumption. The total resistance across the output stage drivers is only 0.8Ω,
allowing peak currents up to 1.5A, and 1A for the normal operation at 25˚C.
Driving H-bridge channels (and the connected load) is implemented by using four
control input lines, two per channel. The truth table below illustrates how the control
inputs affect the output stages. H-Bridge click can be used to drive bipolar step motors
in full step or half-step mode, offering full control over the motor driving functions. The
H-Bridge click can also be used for driving DC brushed motors. Special cases are when
both control inputs of a single H-bridge channel are set to a HIGH or to a LOW logic
state. In the first case, the output stage will be set to a high impedance (Hi-Z) mode. In
the second case, both outputs of the H-bridge click will be tied up to the GND,
discharging the remaining coil current, performing so-called rheostatic (dynamic)
braking. The Hi-Z mode is also activated as a protection measure when the temperature
is too high, or when the power supply voltage drops under a certain threshold.
The control inputs are routed to the mikroBUS™ pins for an easy connection with the
MCU. IN1A and IN1B control pins of the MC34933 driver IC, used to control the first Hbridge channel, are routed to the PWM and CS pins of the mikroBUS™ respectively,
while the IN2A and IN2B control pins are routed to the AN and RST pins of the
mikroBUS™. These pins are labeled as I1A, I2A, I1B, I2B, on the Click board™.
The power supply for the logic section of the IC is provided by the mikroBUS™ power
rails. The ability of the driver IC to work with logic levels in the range of 3.3V to 5V
simplifies the interfacing to MCUs that work with both voltages: it is enough to move
the onboard SMD jumper labeled as VCC SEL, and select the desired logic voltage level
between 3.3V and 5V.
The motor coils are supplied with the power from either the external power supply, or
by the mikroBUS™ power rail, selected with the VCC SEL jumper. When working with
motors that consume more power than available at the mikroBUS™ power rail, it is
advisable to connect the external power supply and move the jumper labeled as VIN SEL
to the VIN position. By default, this jumper is set to use the mikroBUS™ power supply
(VCC position). The external DC power supply can be connected to the two-pole input
screw terminal, with its inputs labeled as GND and VIN. The stepper motor coils can be
connected to the four-pole screw terminal, with its inputs labeled as 1A, 1B, 2A, 2B.
These labels correspond to the H-bridge outputs from the driver IC itself: 1A is routed to
the OUT1A, 1B to the OUT1B, and so on.
The Click board™ can be easily driven via the GPIO pins of the host MCU. However,
MikroElektronika provides a library that contains functions compatible with the
MikroElektronika compilers, which can be used for simplified control of the H-Bridge
click. Library offers functions for setting the rotation speed with selectable acceleration
and deceleration, direction, half and full step driving mode, setting the output stages,
and more. The library also contains an example application, which demonstrates the use
of these functions. This example application can be used as a reference for custom
designs.
Truth table
I1A/I2A
I1B/I2B
1A/2A
1B/2B
H
L
H
L
L
H
L
H
H
H
HI-Z
HI-Z
L
L
L
L
Specifications
Type
Stepper
Driving of light 3D printer elements, for precision actuators, for an
Applications
accurate positioning of various moving elements by using stepper
On-board
MC34933, a dual H-bridge driver with 3V compatible logic inputs,
modules
from NXP.
Low power consumption, undervoltage protection, thermal
Key Features
protection, shoot-through current suppression, simple stepper
motor driving with four control pins, 3.3V and 5V compatible logic.
Interface
GPIO
Input Voltage
3.3V,5V
Click board
M (42.9 x 25.4 mm)
size
Pinout diagram
This table shows how the pinout on H‐Bridge click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Logic input control
2A
Logic input control
Pin
IN2A
1
AN
PWM
16
IN1A
IN2B
2
RST
INT
15
NC
Notes
Logic input control
1A
2B
Logic input control
IN1B
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
Power Supply
+3V3
7
3.3V
5V
10
+5V
Power Supply
Ground
GND
8
GND
GND
9
GND
Ground
1B
Onboard settings and indicators
Label
Name
Default
Description
JP1
VCC SEL
Left
JP2
VIN SEL
Right
LD1
PWR
Power LED indicator
TB1
1A 1B
Terminal for connecting OUT1A and OUT1B
TB2
2A 2B
Terminal for connecting OUT2A and OUT2B
TB3
VIN GND
Terminal for connecting input voltage VIN
Logic level voltage selection: left position 3.3V, right
position 5V
Power supply source selection: left position VIN, right
position VCC
H-Bridge click electrical specifications
Description
Min
Typ
Max
Unit
Voltage at the VIN terminal
2
3.3
7
V
Maximum load current (at 25°C)
1
A
2.0
2.2
2.4
V
VCC undervoltage threshold
Software support
We provide a library for H-Bridge click on our Libstock page, as well as a demo
application (example), developed using MikroElektronika compilers and mikroSDK. The
provided click library is mikroSDK standard compliant. The demo application can run on
all the main MikroElektronika development boards.
Library Description
The library carries everything needed for stepper motor control including speed
and acceleration setup. The library is also adjustable so that it's possible to work on
a different amount of ticks per second. Also, speed and acceleration can be provided in
float format. The buffer used for the movement calculation is defined by the user, so this
library can be adjusted for MCUs with very limited RAM resources. Check the
documentation for more details how to use it.
Key functions:
uint8_t hbridge_setSpeed( float minSpeed, float maxSpeed, float accelRatio,
T_HBRIDGE_OBJ obj ) - Setup motor speed.
uint8_t hbridge_setRoute( const uint8_t direction, uint32_t steps,
T_HBRIDGE_OBJ obj ) - Setup new route.
void hbridge_start( T_HBRIDGE_OBJ obj ) - Starts the motor movement.
void hbridge_setOutput( uint8_t state ) - Function puts the all four outputs in the
desired state.
Examples Description
The application is composed of three sections:
System Initialization - Initializes all GPIO pins found on H_Bridge Click and timer to 1ms
interrupt.
Application Initialization - The first segment initializes driver and stepper control. Second
segment setup movement limits, maximum and minimum speed, and acceleration ratio. The
third segment enables the motor and set up a new route which will be called from application
task.
Application Task - (code snippet) - Sequentially moves the motor. The first part of sequence
executes movement until the end. The second part stops the motor movement after one second
and continues the sequence after two seconds.
void applicationTask()
hbridge_start( (T_HBRIDGE_OBJ)&myStepper );
while( myStepper.status.running )
hbridge_process( (T_HBRIDGE_OBJ)&myStepper );
Delay_ms( 1000 );
The full application code, and ready to use projects can be found on our Libstock page.
Additional notes and information
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development systems
with no UART to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be
used to read the message.
mikroSDK
This Click board™ is supported by mikroSDK - MikroElektronika Software Development
Kit. To ensure proper operation of mikroSDK compliant Click board™ demo applications,
mikroSDK should be downloaded from the LibStock and installed for the compiler you
are using.
For more information about mikroSDK, visit the official page.
https://www.mikroe.com/h‐bridge‐click 6‐15‐18
