PWM 2 click
PID: MIKROE‐3148
Weight: 29 g
PWM 2 click offers 48 independently controlled PWM channels, available over
the onboard headers, perfectly suited for driving LEDs. Each channel has a
12-bit PWM register associated to it, with the addition of the 6-bit correction
register, also known as the dot correction register. PWM 2 is able to detect
both synchronization errors and open LED errors, signaling the error via the
dedicated pin and the status frame. The Click board™ fully supports
cascading, exposing all the necessary pins on the onboard headers, so it can
support a large array of LED elements.
The possibility to cascade more devices, as well as the ability to additionally
fine-tune each PWM channel separately, compensating the brightness
differences between the LED elements (dots), make PWM 2 click an ideal
solution for building both small-scale and large-scale LED matrices and
displays. Although it is targeted toward driving LEDs, the Click board™ can
also be used for other purposes, such as the motor control, industrial
control, robotics, and similar applications that can benefit from having
compact 48 channel PWM driver.
How does it work?
The main component of the PWM 2 click is the LT8500, a 48-Channel LED
PWM generator with 12-Bit resolution and 50MHz serial interface, from
Linear Technology division of Analog Devices. This IC has 48 independent 12bit PWM channels, each with 6-bit correction up to 50% of the original duty
cycle. The LT8500 IC is clocked by a clock signal at the PWMCK pin. The
frequency of the clock signal can go up to 25MHz, generating the PWM
output frequency of up to 6.1kHz, which is sufficient for most purposes. The
maximum speed of the LT8500 serial interface goes up to 50MHz in theory,
but in practice, it will depend on many factors.
The clock signal at the PWM pin of the mikroBUS™ is triggering an internal
counter register (PWMCK). This register is compared with the content of the
PWMRSYNC register, associated with each channel. Whenever the counter
value is less than the value written in a specific channel PWMRSYNC register,
the PWM output of that channel goes to a HIGH logic level. The frequency of
the output PWM signal is therefore determined by the frequency the clock
signal at the PWMCK pin. This represents the basic operating principle of the
LTC8500 IC. The PWMCK pin is routed to the PWM pin of the mikroBUS™.
The device uses an industry-standard SPI interface for the communication.
The LDI pin acts as the normal Chip Select, latching the SPI data in, but it
has an additional function if held to a HIGH logic level for more than 50µs. In
that case, the IC will be reset, and all outputs will be blanked. Therefore, a
care should be taken not to hold this pin to a HIGH logic level, for more than
5µs. The LDI pin is routed to the CS pin of the mikroBUS™ and it is labeled
as LDI.
Besides the usual SPI interface lines, the LT8500 PWM generator IC provides
a serial interface clock output signal (SCKO), allowing additional devices to
be connected in the parallel 5-wire topology (LDI, SCKI, SDI, SDO, and
SCKO). This allows large-scale cascading, without the need for the skew
balancing or buffering the signals. These additional pins are available at the
standard 2.54 pitch headers on board. These additional pins on the header
are described in a table, below. More information about cascading and using
the SCKO feature of the IC can be found in the LT8500 datasheet.
The device is controlled by sending commands via the SPI interface,
embedded in a command frame. There are eight different commands which
are used to control the following parameters: PWM outputs update
(synchronously or asynchronously to PWM period), the dot correction factor,
self-test initialization, phase shifting between banks (groups of 16 channels),
enabling/ disabling of the PWM output drivers, and enabling/disabling of the
dot correction . A frame consists of a 12-bit data field for each of the 48
PWM channels, followed by an 8-bit command field, which contains one of
the eight command codes. The status frame is clocked on the SDO pin,
providing the host MCU with the frame information: LED fault status, phase
shifting status, correction status, synchronization status, and so on. This
information can be used either for troubleshooting or for other purposes by
the host MCU application.
As already mentioned, additional functionalities of the LT8500 IC are offered
via the onboard headers, along with the 48 PWM channel outputs. The
outputs are not meant to drive devices with high current, so PWM 2 click is
best used as the driver for additional circuitry, whether it is a simple
MOSFET LED driver, or a more complex ICs, such as the LT3595A LED
driver, for which a special input pin is reserved, allowing open LED
conditions to be detected, even on the externally connected LT3595 IC.
Onboard headers also offer fixed 5V output from the mikroBUS™ for the
auxiliary purposes.
The Click board™ offers an operating voltage level selection between 3.3V
and 5V by switching an SMD jumper labeled as the PWR SEL to an
appropriate position. This allows both 3.3V and 5V MCUs to be interfaced
with this Click board™.
Specifications
Type
PWM
Applications
This Click board™ can be used for driving up to 48 independent
channels with the PWM signal of the programmable duty cycle, and
can be used for driving LED matrices and displays, but it can also be
used for the motor control, industrial control, robotics, and similar
applications
On-board
modules
LT8500, a 48-Channel LED PWM generator with 12-Bit resolution
and 50MHz serial interface, from Linear Technology division of
Analog Devices
Key Features
A complete pinout required for cascading available on the 2.54mm
pin headers, along with the 48 independent PWM channels, each
with programmable duty cycle, dot brightness correction for
brightness uniformity, and error reporting for open LED via the
status frame response
Interface
PWM,SPI
Input
Voltage
3.3V or 5V
Click board
size
L (57.15 x 25.4 mm)
Pinout diagram
This table shows how the pinout on PWM 2 click corresponds to the pinout on
the mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
NC
1
AN
PWM
16
PWM
NC
2
RST
INT
15
NC
Latch Data
In/Blank
LDI
3
CS
RX
14
NC
SPI clock
SCK
4
SCK
TX
13
NC
SPI Data OUT
SDO
5
MISO
SCL
12
NC
SPI Data IN
SDI
6
MOSI
SDA
11
NC
Power supply
3.3V
7
3.3V
5V
10
5V
Ground
GND
8
GND
GND
9
GND
Notes
Clock Signal
IN
Power supply
Ground
Onboard jumpers and settings
Label
LD1
J1
Name
Default
Description
PWR
Power LED indicator
PWR SEL
Right
Power Supply voltage selection: left
position 3.3V , right position 5V
OnBoard connectors
Label
Description
1 - 48
Channel 1 to Channel 48 PWM outputs
LD
Latch Data In/Blank pin (shared with the mikroBUS™)
SO
SPI Serial Data Out (shared with the mikroBUS™)
C
SPI Serial Clock In (shared with the mikroBUS™)
CO
SPI Serial Clock Out
OL
#OPENLED pin used to detect an external open LED condition
5V
5V power supply from the mikroBUS™ power rail
GND
Ground
Software support
We provide a demo application for PWM 2 click on our Libstock page, as well
as a demo application (example), developed using
MikroElektronika compilers. The demo can run on all the main
MikroElektronika development boards.
Library Description
The library carries all necessary functions for complete control over PWM 2
click.
Key functions:
void pwm2_togglePhaseShift() - Functions for toggle phase shift
uint8_t pwm2_setChannel(uint8_t nChannel, uint16_t width,uint8_t correction) -
void pwm2_Inits() - Function for initialization of the chip
Function for set channel
Example description
The application is composed of three sections:
System Initialization - PWM, SPI and CS pin are initialized PWM is used as a PWMCK signal
for the PWM2 click board. SPI is used as a serial data in. CS pin is used as a LDIBLANK signal.
Application Initialization - (code snippet) - PWMCK signal is set to 15mhz and to give a 50%
duty cycle. The PWM2 click channels are initialized to 75% duty cycle, and the phase shift is
toggled on.
Application Task - the first 10 PWM2 click channels are switched back and forth from 25% duty
cycle to 100% duty cycle every second.
void applicationInit()
uint8_t i;
pwm2_spiDriverInit( (T_PWM2_P)&_MIKROBUS1_GPIO, (T_PWM2_P)&_MIKROBUS1_SPI );
Delay_ms( 100 );
//PWMCK setup:
period_PWM = PWM_TIM2_Init(_PWM2_CLOCK_15_MHZ);
PWM_TIM2_Set_Duty(period_PWM/2,_PWM_NON_INVERTED,_PWM_CHANNEL1);
PWM_TIM2_Start(_PWM_CHANNEL1, &_GPIO_MODULE_TIM2_CH1_PA0);
//end of PWMCK setup
dutyMode = 1;
pwm2_Inits();
//setting all 48 PWM2 channels on the PWM2 click to 75% duty
for(i = 1; i
