SLU-100-ASD
SLU-100-ASD
    MUELLERELECTRIC
    相序 208 ~ 480VAC
SLU-100-ASD 数据手册
SLU-600 Series The ATC-Diversified Electronics SLU-600-ASTDS Universal Phase Monitor protects 3-phase motors up to 700VAC. The RAPID CYCLING feature prevents motors cycling due to load-induced line fault conditions. Powered by 120VAC, this reliable motor protection relay is unaffected by transients and disturbances from the monitored power source. The SLU-600 Series is UL Listed under UL File Number E55826. SPECIFICATIONS IND. CONT. EQ 496Y Universal Phase Monitor AUTO Frequency RANGING SCALES 60Hz 50Hz 3Ø VOLTAGE BAND Nominal Line-to- Line Voltages 208, 220, 240 380, 415, 440, 460, 480, 575, 600 208, 220, 240 346, 380, 415 Drop-out Pick-up Adjustable Range 200-250 360-500 550-630 200-250 330-430 ±10% of Range Setting (Under/Over) ±7% of Range Setting (Under/Over) PHASE VOLTAGE MONITORS CONTROL VOLTAGE 120 VAC ±10%, 50/60Hz • Monitors up to 700 VAC PROTECTS AGAINST: • DIN Rail or Surface Mount • Rapid Cycling • Operating Range 200-630 VAC • Phase Loss • Manual or Automatic Reset • Phase Unbalance • Adjustable Restart Delay • Phase Shift • Adjustable Fault Delay 700 VAC (Line-to-Line) PHASE SEQUENCE ABC (Will Not Operate On CBA Sequence) POWER REQUIRED 90VA Max. PHASE UNBALANCE 2% to 10%, Adjustable Drop-out Hysteresis 10% of Setting PHASE SHIFT 13° Drop-out, 12° Pick-up (Ø-Loss) • Over/Under Voltage FREQUENCY SHIFT 50/60 Hz Drop-out Pick up • Over/Under Frequency RAPID CYCLING 5 Cycle Lockout, 30-Min. Cycle Count Reset RESET Automatic or Manual Mode Clears Rapid Cycle Count RELAY OUTPUT DPDT, 10A @ 240 VAC Resistive • Phase Reversal ORDERING INFORMATION MODEL NUMBER DESCRIPTION SLU-600-ASTDS MAXIMUM VOLTAGE Universal Phase Monitor/Relay ± 4% ± 3% LED'S Normal (Green LED) Fault (Red LED) Over (Red LED) Unbal / Ø Loss (Red LED) Flashing Continuous Fault Delay Relay Active Energized Restart Delay Relay Active De-energized Restart Delay Relay Active De-energized Restart Delay Relay Active De-energized RESPONSE Power Up Fault Delay Severe Fault Restart 2.5 S Minimum 0.1 to 25 S, Adjustable 100mS (Ø-Loss, Unbalance or Ø Reversal) 0.5 to 300 S, Adjustable (Auto Reset) TEMPERATURE RATINGS 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) Operate Storage REPEAT ACCURACY 1% @ Fixed Condition 150 Diversified Electronics TERMINALS Plug and Socket Term Block with Spring Pressure Wire Retention, 12 AWG Max. ENCLOSURE 35mm DIN Rail or Surface Mount, Polycarbonate Housing WEIGHT 1.10 lbs. 800.727.5646 atcdiversified.com SLU-600 Series (INCHES/MILLIMETERS) TOP LABEL LED STATUS CHART = OFF = ON = FLASHING Unbal & Ø Normal Under Red Over Red Loss Red Green LED LED LED LED Powering Up/First 3 Sec Powered Up/Normal Voltages Relay ON/Under Voltage Detected/FAULT DELAY active PHASE VOLTAGE MONITORS DIMENSIONS Relay ON/Over Voltage Detected/ FAULT DELAY active Relay ON/Unbal or Ø Loss Detected/FAULT DELAY active Relay OFF/Under Voltage Failure Relay OFF/Over Voltage Failure Relay OFF/Unbal or Ø Loss Failure Relay OFF/Under Voltage Corrected/RESTART DELAY active Relay OFF/Over Voltage Corrected/RESTART DELAY active Relay OFF/Unbal or Ø Loss Corrected/RESTART DELAY active Diversified Electronics 800.727.5646 atcdiversified.com 151
SLU-100-ASD 价格&库存
很抱歉,暂时无法提供与“SLU-100-ASD”相匹配的价格&库存,您可以联系我们找货
