SS16F
SS16F
    NEXTGEN
    SMA(DO-214AC)
    DIODE SCHOTTKY 60V 1A SMAF
SS16F 数据手册
PART CODE: SMAFSS16F0S106 SPECIFICATION SHEET SPECIFICATION SHEET NO. P1105- SMAFSS16F0S106 DATE Nov. 05, 2022 REVISION A1 DESCRIPITION SMD High Efficiency Rectifier, 2 Pads, SMAF series, SS16F Type Reverse Voltage 60V Max. Forward Current 1.0A Max. Operating Temp. Range -50°C ~+150°C Package in Tape/Reel, 3000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER MDD SS16F PART CODE SMAFSS16F0S106 VENDOR APPROVE Issued/Checked/Approved DATE: Nov. 05, 2022 CUSTOMER APPROVE DATE: 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com SMAFSS16F0S106 PART CODE: SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES MAIN FEATURE • The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 • Low reverse leakage • Built-in strain relief, • High forward surge current capability • Ultra fast switching for high efficiency • High temperature soldering guaranteed: 250℃/ 10 seconds at terminals APPLICATION • For printed circuit board RFQ PART CODE GUIDE Request For Quotation SMAF SS16F0 S 106 1 2 3 4 1) SMAF: SMD High Efficiency Rectifier, 2 Pads, SMAF series 2) SS16F0: Type code for original part number SS16F 3) S: Package code, Tape/reel, 3000pcs/reel. 4) 106: Specification code for Reverse Voltage 60V Max. Forward Current 1.0A Max. MORE ITEMS AVAILABLE SMAFSS12F0S102 SMAFSS13F0S103 SMAFSS14F0S104 SMAFSS15F0S105 SMAFSS18F0S108 SMAFSS110FS110 SMAFSS1150S115 SMAFSS1200S120 SMAFSS22F0S202 SMAFSS23F0S203 SMAFSS24F0S204 SMAFSS25F0S205 SMAFSS28F0S208 SMAFSS210FS210 SMAFSS2150S215 SMAFSS2200S220 SMAFSS32F0S302 SMAFSS33F0S303 SMAFSS34F0S304 SMAFSS35F0S305 SMAFSS38F0S308 SMAFSS310FS310 SMAFSS3150S315 SMAFSS3200S320 SMAFSS52F0S502 SMAFSS53F0S503 SMAFSS54F0S504 SMAFSS55F0S505 SMAFSS58F0S508 SMAFSS510FS510 SMAFSS5150S515 SMAFSS5200S520 SMAFSS16F0S106 SMAFSS26F0S206 SMAFSS36F0S306 SMAFSS56F0S506 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES DIMENSION (Unit: Inch/mm) Image for reference Marking: SS16F SMAF Recommend Pad Layout 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com Symbol Unit (Inch) Unit (mm) A 0.071 1.80 B 0.063 1.60 C 0.150 3.80 D 0.087 2.21 E 0.213 5.40 www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES MECHANICAL DATA Case Terminals Polarity Mounting Position Weight per piece JEDEC SMAF molded plastic body Solder plated, Solderable per MIL-STD-750, Method 2026 Color band denotes cathode end Any 0.00095 Ounce, 0.027 grams MAX. RATING & CHARACTERISTICS Parameter SYMBOLS VALUE Min. Typical UNITS Max. Repetitive peak reverse voltage V RRM 60 Volts RMS voltage V RMS 42 Volts DC blocking voltage V DC 60 Volts Average forward output rectified current I AV 1.0 A at TL= 55°C I FSM Peak forward surge current 8.3ms single half 25 A sine-wave superimposed on rated load (JEDEC Method) Instantaneous forward voltage at 1.0A DC reverse current at rated DC blocking voltage VF 0.70 Volts IR 0.3 mA TA=25℃ 10.0 TA=100℃ Junction capacitance (Note 3) CJ 80 pF Thermal resistance (Note 4) R QJA 95 °C/W Operating junction temperature range Storage temperature range TJ -55 +150 °C T STG -55 +150 °C Note 1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. 2. Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 3. Measured at 1.0MHz and applied reverse voltage of 4.0Voltage 4. P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas. 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES RELIABILITY Number Experiment Items Experiment Method And Conditions Reference Documents 1 Solder Resistance Test Test 260°C± 5°C for 10 ± 2 sec. Immerse body into solder 1/16” ± 1/32" MIL-STD-750D METHOD-2031.2 2 Solderability Test 230°C ±5°C for 5 sec. MIL-STD-750D METHOD-2026.1 0 3 Pull Test 1 kg in axial lead direction for 10 sec. MIL-STD-750D METHOD-2036.4 4 Bend Test 0.5Kg Weight Applied To Each Lead, Bending Arcs 90 °C ± 5 °C For 3 Times MIL-STD-750D METHOD-2036.4 5 High Temperature Reverse Bias Test TA=100°C for 1000 Hours at VR=80% Rated VR MIL-STD-750D METHOD-1038.4 6 Forward Operation Life Test TA=25°C Rated Average Rectified Current MIL-STD-750D METHOD-1027.3 7 Intermittent Operation Life Test On state: 5 min with rated IRMS Power Off state: 5 min with Cool Forced Air. On and off for 1000 cycles. MIL-STD-750D METHOD-1036.3 8 Pressure Cooker Test 15 PSIG, TA=121°C, 4 hours MIL-S-19500 APPENOIXC 9 Temperature Cycling Test -55°C~+125°C; 30 Minutes For Dwelled Time 5 minutes for transferred time. Total: 10 cycles. MIL-STD-750D METHOD-1051.7 10 Thermal Shock Test 0°C for 5 minutes., 100°C for 5minutes, Total: 10 cycles MIL-STD-750D METHOD-1056.7 11 Forward Surge Test 8.3ms Single Sale Sine-wave One Surge. MIL-STD-750D METHOD-4066.4 12 Humidity Test TA=65°C, RH=98% for 1000 hours. MIL-STD-750D METHOD-1021.3 13 High Temperature Storage life Test 150°C for 1000 Hours MIL-STD-750D METHOD-1031.5 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES SUGGESTED REFLOW PROFILE (For Reference Only) Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 150℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. 11/5/2022 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES RATINGS AND CHARACTERISTIC CURVES (For Reference Only) 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-A and specifications. Item Symbol Tolerance SMAF Carrier width A 0.1 2.80 Carrier Length B 0.1 4.75 Carrier Depth C 0.1 1.42 Sprocket hole d 0.05 1.50 7”Reel outside diameter D 2.0 178.00 7”Reel inner diameter D1 Min. 54.40 Feed hole diameter D2 0.5 13.00 Sprocket hole position E 0.1 1.75 Punch hole position F 0.1 5.05 Punch hole pitch P 0.1 4.00 Sprocket hole pitch P0 0.1 4.00 Embossment center P1 0.1 2.00 Overall tape thickness T 0.1 0.30 Tape width W 0.3 8.00 Reel width W1 1.0 12.30 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SMAFSS16F0S106 SMD HIGH EFFICIENCY RECTIFIER SMAF SERIES PACKAGE For Reference Case Code SMAF Reel Size 7” Reel Size 178 mm MPQ/Reel 3000 pcs Qty. /Box 6000 pcs G.W/Box 1 lbs IMPORTANT NOTICE AND DISCLAIMER 1)NextGen Component, Inc. reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. 2)NextGen Component, Inc makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does NextGen Component, Inc assume any liability for application assistance or customer product design. 3)NextGen Component, Inc does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of NextGen Component, Inc 4)NextGen Component, Inc. products are not authorized for use as critical components in life support devices or systems without express written approval of NextGen Component, Inc. 11/5/2022 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
SS16F 价格&库存
很抱歉,暂时无法提供与“SS16F”相匹配的价格&库存,您可以联系我们找货
