REFRIGERATION
NE
W
11338JE (113 X 38L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart
0.28
70
3,500
0.24
60
3,000
0.20
50
0.14
40
0.12
30
0.08
10M Ω or over with a DC500V Megger
Static Pressure
-40°C ~ +40°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
0.04
10
Expected Life
2,500
L Class
2,000
K Class
1,500
L Class
1,000
K Class
0.0
17.66
500
1.0
1.5
2.0
35.31
52.97
70.63
(m3/min)
CFM
Air Flow
70,000 Hours (L10)
Material
Outline
Casing : Plastic (Black) PBT UL94V-0
Impeller : Plastic (Green) UL94HB
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
0.18
(4−φ4.5± 0.3)
PLATE
3.54
(90.0± 0.5)
Water Drain
4.45
+1.0
(113.0 -1.5)
-20°C
Speed Curve
DC Axial Fans
(Pa)
Insulation Resistance:
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
In H2O
Speed
General Specifications
.18
(4- 4.5)
0.37
(9.5)
Water Drain
Water Drain
4.45
+1.0
(113.0 -1.0)
0.18
(4−φ4.5± 0.3)
1.02
+1.2
(26.0-0.5)
1.42
+2.0
(36.0-1.5)
4.45
+1.0
(113.0 -1.5)
NAME
PLATE
3.54
(90.0± 0.5)
3.54
(90.0)
( 4.1
10 7
6)
3.54
(90.0± 0.5)
.2
(5)
11.81
inch
Units: (mm)
± 15
Panel Cut-Outs
INLET
SIDE
Water
Drain
0.37
(9.5)
3.54
(90.0± 0.5)
Specifications
4.45
+1.0
(113.0 -1.0)
.2
(5)
11.81
(300± 15)
3.54
(90.0)
1.02
+1.2
(26.0-0.5)
ROTATION
1.42
+2.0
(36.0-1.5)
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
11338JE-12K-BA-F0
12
7.0 ~ 13.8
0.08
0.96
1920
33.20
0.94
.06
15.9
21.5
170
11338JE-12L-BA-F0
12
7.0 ~ 13.8
0.13
1.56
2900
52.47
1.50
.15
38.0
32.5
170
MODEL
Rotation: Clockwise
Current
Input
Speed
Power
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
*1: Average Values in Free Air
Mass
(g)
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“11338JE-12L-BA-F0”相匹配的价格&库存,您可以联系我们找货
