REFRIGERATION
NE
W
12539JE (125 X 39L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart
In H2O
(Pa)
.24
60
P-Q Curve
Speed Curve
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-40°C ~ +40°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
-20°C
.20
50
.16
40
3,000
L Class
2,500
2,000
K Class
.12
30
.08
10
1,500
L Class
1,000
500
K Class
70,000 Hours (L10)
0.8
1.2
28.25 42.38
1.6
2.0
2.4
(m3/min)
56.50
70.63
84.76
CFM
Air Flow
Material
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Green) UL94VHB
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
.18
4.5)
4.45
(113.0± 0.5)
4.92
+1.0
(125.4-1.5)
(4-
Panel Cut-Outs
.18
(4- 4.5)
.47
(12)
4.45
(113.0± 0.5)
.79
(20± 0.5)
1.54
(39± 1.5)
4.86
(123.4)
4.92
+1.0
(125.4-1.5)
4.45
(113.0)
( 5.1
13 2
0)
inch
Units: (mm)
NAME
4.45
(113.0)
PLATE
ROTATION
.2
(5)
INLET SIDE
11.81
(300± 15)
4.86
(123.4)
Specifications
MODEL
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
12539JE-12K-BA-F0
12
7.0 ~ 14.0
0.16
1.92
2080
62.15
1.76
.10
25.4
32.0
190
12539JE-12L-BA-F0
12
7.0 ~ 13.2
0.24
2.88
2300
74.87
2.12
.15
36.3
34.0
190
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
Speed
General Specifications
很抱歉,暂时无法提供与“12539JE-12L-BA-F0”相匹配的价格&库存,您可以联系我们找货
