REFRIGERATION
NE
W
12539JA (125 X 39L)
NMBTC.COM / 248.919.2250
Characteristic Curves
Motor Protection:
Auto Restart
In H2O
Insulation Resistance:
10M Ω or over with a DC500V Megger
Static Pressure
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
.20
50
.16
40
.12
30
.08
10
Speed Curve
2,500
2,000
M
L
1,500
1,000
500
M
Expected Life
25°C
100,000 Hours (L10)
Material
0.8
1.2
1.6
2.0
(m3/min)
28.25
42.38
56.50
70.63
CFM
Outline
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL1007, AWG26, +Red, -Black
(4 .16
-R
5)
4.45
(113.0 -1.0)
ROTATION
4.92
+1.0
(125.4-1.5)
Panel Cut-Outs
inch
Units: (mm)
NAME
PLATE
NO SOLDER
.16 4.5
(4-
.18 4.5 )
4
4.45
(113.0)
4.45
(113.0)
4.45
(113.0)
4.82
(122.4)
4.86
(123.4)
INLET SIDE
OUTLET SIDE
11.81
min (300)
4.92
+1.0
(125.4-1.5)
(122.4)
4.45
(113.0)
13
0.
14
4.45
+0.5
(113.0 -1.0)
4.86
(123.4)
.16 4.5
(4-
L
(10)
.79
(20± 0.5)
1.54
(39± 1)
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
(A)*1
(W)*1
12539JA-12L-BA-00
12
7.0 ~ 13.8
0.06
0.72
1600
46.97
1.33
.08
20.4
22.0
240
12539JA-12M-BA-00
12
7.0 ~ 13.8
0.09
1.08
1950
57.26
1.62
.12
30.2
26.5
240
MODEL
Rotation: Clockwise
Current
Input
Speed
Power
Airflow Outlet: Air Out Over Struts
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
*1: Average Values in Free Air
Mass
(g)
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
P-Q Curve
(Pa)
Speed
General Specifications
很抱歉,暂时无法提供与“12539JA-12M-BA-00”相匹配的价格&库存,您可以联系我们找货
