M.2 to MiniPCIe Adapter:
SKU: OP3008250
The adapter converts a 3042 B-Key M.2 module into
a Mini Card form factor with MiniPCIe interface.
The adapter includes a MicroSD slot for extra
memory. The MicroSD is visible as a USB device on
the PCIx interface. There is a USB hub on the
interposer card that connects to two USB devices:
the modem and the MicroSD card.
Revision 2
Image: Front side and back side of the M.2 to MiniPCIe adapter
GetWireless
10250 Valley View Road, Suite 139
Eden Prairie, MN 55344
www.getwirelessllc.com
support@getwirelessllc.com
952-890-6669
Pinouts:
PCIe Minicard Edge connector
Pin nr Signal
Connects to
M2 Edge connector
Pin nr Signal
Connects to
1 WAKE#
WAKE#
2 +3.3V
+3.3V module
Pin nr Signal
75 CONFIG_2
Connects to
Pin nr Signal
3 COEX1
+3.3V uSD card
4 GND
GND
73 GND
GND
74 +3.3V
+3.3V module
71 GND
GND
72 +3.3V
+3.3V module
70 +3.3V
+3.3V module
5 COEX2
6 +1.5V
7 CLKREQ#
8 UIM_PWR
UIM_PWR
69 CONFIG_1
10 UIM_DATA
UIM_DATA
67 RST#1
11 REFCLK-
12 UIM_CLK
UIM_CLK
65 ANTCTL3
66 SIM_DETECT
13 REFCLK+
14 UIM_RST
UIM_RST
63 ANTCTL2
64 COEX_1
61 ANTCTL2
62 COEX_2
9 GND
GND
15 GND
GND
16 UIM_VPP
PERST#
59 ANTCTL0
57 GND
STOOK_EN
18 GND
GND
53 REFCLK-
19 UIM_IC_DP
+3.3V uSD card
20 W_DISABLE#
W_DISABLE
51 GND
21 GND
GND
22 PERST#
PERST#
49 PERP0
23 PERn0
24 +3.3Vaux
+3.3V module
47 PERN0
25 PERp0
26 GND
GND
45 GND
27 GND
GND
28 +1.5V
43 PETP0
29 GND
GND
30 SMB_CLK
41 PETN0
31 PETn0
32 SMB_DATA
39 GND
33 PETp0
34 GND
GND
37 SSRX+
35 GND
GND
36 USB_D-
USBDU_DM
35 SSRX-
37 GND
GND
38 USB_D+
USBDU_DP
33 GND
39 +3.3Vaux
+3.3V module
40 GND
GND
41 -3.3Vaux
+3.3V module
43 GND
GND
68 SUSCLK (32KHz)
60 COEX_3
GND
55 REFCLK+
17 UIM_IC_DM
Connects to
58
56
54
GND
52
50
48 GPIO_4
GND
46 GPIO_3
44 GPIO_2
42 GPIO_1
GND
40 GPIO_0
38 DEVSLP
36 UIM_PWR
UIM_PWR
34 UIM_DATA
UIM_DATA
31 SSTX+
32 UIM_CLK
UIM_CLK
42 LED_WWAN# LED_WWAN#
29 SSTX-
30 UIM_RST
UIM_RST
44 LED_WLAN#
27 GND
45 Reserved
46 LED_WPAN#
25 GPIO12
47 47 Reserved
48 +1.5V
23 GPIO11
49 Reserved
50 GND
GND
51 Reserved
52 +3.3Vaux
+3.3V module
PN OP3008250
Custom versions available
28 GPIO_8
26 W_DISABLE2#
WAKE#
24 GPIO_7
22 GPIO_6
20 GPIO_5
GND
9 USB_D-
USBDN_DM
7 USB_D+
USBDN_DP
8 W_DISABLE1#
5 GND
GND
6 CARD_PWR_OFF
3 GND
GND
4 +3.3V
+3.3V module
2 +3.3V
+3.3V module
1 CONFIG_3
GND
21 CONFIG_0
11 GND
Ordering Information:
GND
10 GPIO_9
LED_WWAN#
W_DISABLE
很抱歉,暂时无法提供与“OP3008250”相匹配的价格&库存,您可以联系我们找货
