MINI GLO STIX KIT - 8'
Glo Stix Kit: 3/16 x 8' long with bullet & J hook nose tips
Cat No:
540-8M
UPC No:
783310129189
Description
Luminescent fiberglass rodsglow in the dark to make fishing voice, data and video wires easier in
dark spaces, such as above ceilings, in walls, and below sub-floors
More flexible for fishing in walls through outlet box holes
Sturdy, steel-threaded connectors are interchangeable with Greenlee 1/4 IN (6.4 mm) Fish Stix
Clear, non-metalic storagetube keeps Glo Stix charged and ready to use
200 lbs. (0.9 kN) maximum pulling strength
Optional Whisk Nose Tip isavailable for fishing over obstacles, and can be used to guide
extended Glo Stix sidewaysabove ceilings by rotating. Can also be used to fish longerlengths by
providing a tip that can be snagged from the opposite direction with another extended Fish or Glo
Stix with a hook nose tip
Specifications
Accessory : 10497 Hook Nose Tip, 10498 Bullet Nose Tip, 11426 Whisk Nose Tip
Diameter : 3/16 IN (4.700 MM)
Includes : "Bullet And ?J"" Hook Nose Tips "
Length : 8.000 FT
Minimum Bend Radius : 4-1/4 IN (108.000 MM)
Replacement Part : 11583 1/4 IN X 4 FT Fish StixSection, 11584 1/4 IN X 6 FT Fish Stix Section,
12920 3/16 IN X 20 IN Glo Stix Section, 11585 3/16 IN x 3 FT Glo Stix Section, 11427 3/16 IN x 5
FT Glo Stix Section, 12922 5/32 INX 4 FT Glo Stix Section, 89803 5/32 IN X 6 FT
Section Length : 20.000 IN (0.500 M)
Sections : 5
Sub Brand : Glo Stix
Tensile Strength : 200.000 LB (0.900 KN) MaximumPulling Strength
Weight : 0.800 LB (0.400 KG)
很抱歉,暂时无法提供与“540-8M”相匹配的价格&库存,您可以联系我们找货
