SPLITTER,4-WAY PKGD
4-Way 1 GHz Splitter (1)
Cat No:
VS1-4
UPC No:
783310462439
Description
"Designed for digital broadcast television, digital cabletelevision, off-air antennas and RF
distribution
Bandwidth - 5 MHz to 1 GHz
Power Passive Port - designed to pass RF and DC power from one input to one output
Nickel-plated, zinc die-cast housing for excellent anti-corrosive protection
100% solder-sealed tin backplate provides EMI/RFI shielding > -120dB
Low insertion loss
Printed circuit board construction ensures consistent RFperformance and excellent port-to-port
isolation
Precision machine threaded?F"" ports for perfect connector fit
F-Ports spaced at 1"" on center to allow application of security sleeves and window filters
F-Ports comply with SCTE outdoor standards
Mounting screws included "
Specifications
Application : For Digital Broadcast Television, Digital Cable Television,Off-Air Antennas And RF
Distribution
Bandwidth : 1 GHZ
Connector : F-Type Female RF
Height : 0.600 IN
Housing : Nickel Plated Zinc Die Cast
Impedance : 75 OHM
Insertion Loss : 8.0 MAX DB At 47 - 470 MHZ, 8.5 MAX DB At 470 - 750 MHZ, 8.5 MAX DB At
750 - 1000 MHZ In-Out
Isolation : 20.0 MIN DB At 5 - 47 MHZ, 21.0 MIN DB At 47 - 470 MHZ, 20.0 MIN DB At 470 - 750
MHZ, 20.0 MIN DB At 750 - 1000 MHZ Out-Out
Length : 3.000 IN
Number Of Ways : 4
Return Loss : 15 DB At 5 - 47 MHZ, 17 DB At47 - 470 MHZ, 15 DB At 470 - 750 MHZ, 15 DB At
Type : VS1 Series
Width : 1.900 IN
很抱歉,暂时无法提供与“VS1-4”相匹配的价格&库存,您可以联系我们找货
