JustBoom DAC SKU: JBM-007
The JustBoom DAC is a standalone high-resolution digital-to-analog converter offering 108kHz/24bit
lossless audio playback for your projects. We’ve designed the JustBoom DAC to be simple to use –
with no soldering required and all the mounting hardware already provided, this is a true plug and
play device.
Description
Connect your JustBoom DAC to a set of powered speakers, headphones or an audio amplifier and
you can be up and running quickly, enjoying flawless, crystal-clear high quality audio playback within
minutes of unboxing. If you need amplification or additional outputs for passive speakers, the
JustBoom DAC is also compatible with the JustBoom Amp – just stack the Amp on top with the
mounting hardware and board to board connector and you will be good to go.
This affordable, standalone DAC has among the best value for money available on the market and
truly reduces the barriers to entry for versatile high quality audio playback. The digital (S/PDIF) inputs
include both optical (TOSLINK) and coaxial/RCA connector options. The onboard DAC chip offers a
384kHz/32 bit output (although this is limited due to the input S/PDIF receiver to 108kHz/24bit). The
JustBoom DAC additionally includes a 138mW headphone amplifier.
The board outputs line level audio over RCA and also offers a headphone amplified output over
3.5mm jack cable. The board is powered by a standard 5 volt microUSB power supply – this is a
common power supply in tablets and smartphones so many of you will already have one available or
can pick one up for a good price!
Need help understanding how this product works? Follow our product guide.
Setup Guide
Follow our full setup guide for assembling your JustBoom DAC and Case.
Configure the JustBoom Player software.
Use cases
A standalone audio DAC card provides the perfect solution for a number of exciting projects and
applications where standard audio resolutions just won’t cut it. Here are some possible use cases for
the JustBoom DAC:
Paired with the JustBoom Digi HAT / JustBoom Digi Zero as a receiver for your digital audio output
Paired with the JustBoom Amp to offer all in one DAC and amplifier for a compact high-quality audio
solution
High-quality headphone amplifier for your digital audio receiver
Streaming (either from cloud or network storage) high-definition audio player
Multi-room audio player
Media centre / set-top box living room entertainment system
And many many more….
Features
Full high quality audio – 108kHz / 24bit (uses 384kHz/32bit DAC chip but this is limited due to the
S/PDIF input)
Includes S/PDIF input using either optical (TOSLINK) or electrical (RCA/coaxial) connections
Includes both a DAC and headphone amplifier
Line-level RCA and headphone amplified 3.5mm jack outputs
Plug and play compatibility for ease of use
No soldering required
Powered by the 5v micro USB power supply – you probably already have one!
Compatible with the JustBoom Amp
Mounting hardware included
Technical Information
Burr-Brown / Texas Instruments PCM5102A DAC chip – 384kHz / 32 bit. Please note that due to
restrictions of the S/PDIF receiver the max quality is limited to 108kHz / 24 bit
Texas Instruments TPA6133A2 headphone amplifier – 138mW
112db SNR and -93db THD for best-in-class audio
Advanced ESD protection on both headphone and RCA outputs
Ultra low noise voltage regulator for the best audio output (LDO 10uVrms)
5v microUSB power input requires at least 100mA when using RCA connectors or at least 200mA
when using headphone connector. We recommend at least a 500mA power supply
Stacking with JustBoom Amp by way of board-to-board connector. All of the required mounting
hardware in order to do this is included with the two products for ease
Additional information
WEIGHT
0.065 kg
DIMENSIONS
13 x 7.5 x 2.5 cm
https://www.pi‐supply.com/product/justboom‐dac/ 1‐22‐18
很抱歉,暂时无法提供与“JBM-007”相匹配的价格&库存,您可以联系我们找货
