JBM-028
JBM-028
    PISUPPLY
    箱 红色 分叉式双侧 2.717" 长 x 1.496" 宽(69.00mm x 38.00mm) X 1.378"(35.00mm)
JBM-028 数据手册
JustBoom Digi Zero Case Black SKU: JBM-013 Red SKU: JBM-028 The Digi Zero Case is a sleek and durable enclosure for the Pi Zero and Digi Zero pHAT. Removing or installing the Pi Zero or Digi Zero pHAT board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom Digi Zero pHAT and Pi Zero. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! Description The Digi Zero Case is a sleek and durable enclosure for the Pi Zero and Digi Zero pHAT. Removing or installing the Pi Zero or Digi Zero pHAT board is quick and simple; all without the need for tools. The two piece case is incredibly easy and straight forward to use. This is currently the only case to perfectly accommodate the JustBoom Digi Zero pHAT and Pi Zero. We’ve designed the case to allow enough clearance around all connectors so thick, high-end cables can fit securely. Get setup within minutes and start enjoying high quality audio! • • • • • • • • • Digi Zero pHAT Case Features: Supports and protects your JustBoom Digi Zero and Pi Zero Easy to open case allows for quick access to your Digi Zero and Pi Zero Smooth black finish that blends in with any audio setup Leaves all ports accessible Compatible with the Pi Zero No tools are needed for assembly or disassembly Designed and made in the UK from high quality material 4 x rubber feet included Access to micro SD port Setup Guide Follow our full setup guide for assembling your JustBoom Digi Zero and Case. Additional information WEIGHT 0.049 kg DIMENSIONS 6.9 x 3.8 x 3.5 cm https://www.pi-supply.com/product/justboom-digi-zero-case/2/9/18
JBM-028 价格&库存
很抱歉,暂时无法提供与“JBM-028”相匹配的价格&库存,您可以联系我们找货
JBM-028
    • 1+17.95432
    库存:67
