JustBoom Amp
SKU: JBM-008
The JustBoom Amp is a standalone high quality audio power amplifier that is designed to either
stack on top of the JustBoom DAC / DAC HAT or alternatively take a line level input. We’ve designed
the JustBoom Amp to be simple to use – with no soldering required and all the mounting hardware
already provided, this is a true plug and play device
Description
The JustBoom Amp provides a 2x55W (peak) amplified stereo output. Just connect your JustBoom
Amp to a set of passive speakers and you can be up and running quickly, enjoying flawless high
quality audio playback within minutes of unboxing. Includes an advanced Class-D power amplifier
chip for a peak power output of 2 x 55 Watts. The JustBoom Amp outputs audio over two speaker
cable connector blocks that accept anything up to 14 AWG cable and will provide crystal clear audio
to either 4 or 8 Ohm passive speakers.
JustBoom Amp can either be used as a standalone amplifier, or it can be stacked on the JustBoom
DAC HAT or DAC boards to make a fully integrated DAC/Amp combo by means of a board to board
connector and mounting hardware. Give your audio an extra kick, and extra output options for a
more versatile and affordable high-quality audio experience!
The JustBoom Amp is designed with a 2.1mm DC jack power input which can accept an 8 to 24 Volt
power supply. When stacked on the JustBoom DAC it can backpower the DAC board, and when
stacked on the JustBoom DAC HAT it can backpower both the DAC HAT and the Raspberry Pi too
(at the 2.5A for full Pi3 compatibility) meaning you only need a single power supply for the entire
system…saving you time and money.
Need help understanding how this product works? Follow our product guide.
Setup Guide
Follow the JustBoom Amp setup guide to get started
Configure the JustBoom Player software
Use cases for the Amp
A standalone audio power amplifier card provides the perfect solution for a number of exciting
projects and applications where standard audio resolutions just won’t cut it, or where you want to
give an extra kick to your JustBoom DAC / DAC HAT boards. Here are some possible use cases for
the JustBoom Amp:
Compact standalone amplifier to pair with your existing DAC
Paired with the JustBoom DAC / DAC HAT to offer all in one DAC and amplifier for a compact highquality audio solution
Streaming (either from cloud or network storage) high-definition audio player
Multi-room audio player
Media centre / set-top box living room entertainment system
And many many more….
Features
Full high-quality audio – 192kHz / 24bit
Stereo amplified 2 x 55 Watt peak output at 8 ohms (2 x 30 Watt RMS)
Plug and play compatibility for ease of use – just connect to your passive speakers
Onboard, hardware jumpers for configuring output voltage and gain settings (jumpers could
optionally be changed with switches)
No soldering required
Compatible with the JustBoom DAC and DAC HAT or alternatively use as a standalone device
When stacked on the JustBoom DAC it can backpower the DAC board, and when stacked on the
JustBoom DAC HAT it can backpower both the DAC HAT and the Raspberry Pi too (at the 2.5A for
Mounting hardware included
Technical Information
Texas Instruments TPA3118D2DAP Class-D amplifier chip with maximum power output of 2 x 55 W (
2 x 30 W RMS)
On the JustBoom Amp there are five line input connections. For balanced inputs: L+ is hot line Lcold line for left channel; R+ hot line, R- cold line for right channel; middle is ground (or cable shield)
connection. For unbalanced L+ is left line, R+ right line, L-, R- and gnd are ground connections and
all three inputs should be shorted to same input ground.
Dual inductors on board for footprint efficiency
power supply. For 8 Ohm speakers, we recommend a 24 volt power supply with at least 75 Watt
output power (POWERPAX SW4527 or similar plus C5 cable). For 4 Ohm speakers we recommend a
15 to 19 volt power supply with at least 58 Watt output power (POWERPAX SW4520 or similar).
These power supply guidelines will ensure maximum output performance of the amplifier. However
there are other options which can be found in our power supply recommendation document. (Please
note: it is highly recommended to use an external power supply. If you power the JustBoom
Amp from the DAC 5v PSU or over the GPIO pins of the Raspberry Pi and do not use one of the
recommended power supplies, the maximum output power will be 2 x 3 Watts)
When stacked on the JustBoom DAC this board can backpower the DAC board, and when stacked on
the JustBoom DAC HAT it can backpower both the DAC HAT and the Raspberry Pi too (at the 2.5A
for full Pi3 compatibility) meaning you only need a single power supply for the entire system
Advanced ESD protection
Total harmonic distortion (THD+N) of 0.1 % at 25 W, 1 kHz, 21V. Signal to noise ratio (SNR) of 102
dB A-Wtd (Ref. to THD+N < 1%, f = 1 kHz, Gain = 20 dB)
Fully configurable onboard jumpers to adjust gain (20dB, 26dB, 32dB, 36dB) and output voltage (14V
and 21V)
Additional information
WEIGHT
0.075 kg
DIMENSIONS
13 x 7.5 x 2.5 cm
https://www.pi‐supply.com/product/justboom‐amp/ 2/6/18
很抱歉,暂时无法提供与“JBM-008”相匹配的价格&库存,您可以联系我们找货
