Flick Large Case
SKU: PIS-0557
Spice up your Flick Large and I2C device with a stylish white and orange Flick Large case! This vibrant
and durable case is made up of thwo parts; an orange base and a slide-on white lid.
This lid can be used in two different setups in either an open or closed position, allowing you to hide
your I2C device and Flick Large, or keep it visible to the world. Flick can work through materials such
as acrylic, wood and glass so our plastic case (even when the lid is in the closed position) will not
negatively impact any of the fun you can have with Flick
Description
Spice up your Flick Large board with a stylish white and orange Flick Large case! This vibrant and
durable case is made up of two parts; an orange base and a slide-on white lid.
This lid can be used in two different setups in either an open or closed position. This allows you to
hide your I2C device and Flick Large, or keep it visible to the world. Flick works through materials
such as acrylic, wood and glass so our plastic case (even when the lid is in the closed position) will
not negatively impact any of the fun you can have with Flick!
GPIO access and suction cups
The Flick Large case features four suction cups for installation in the bottom four corners of the case.
Use the suction cups to mount the case onto many different surfaces such as glass, plastic, or wood
and still be removed easily.
The Flick Large board comes with 1 x female-to-female jumper cable and 1 female-to-male jumper
cable which connects into the bottom section of the case on the back panel.
Perhaps you want to set up your Flick Large & I2C device to only allow entry through a door if you
swipe the right pattern – with this case, you could mount it right next to the door without the need
to drill any holes or hammer any nails.
Features:
4 x suction cups
1 x orange base
1 x white lid
Dimensions:19cm x 12.5cm x 1cm
Case assembly guide
Need help assembling your Flick Large case? Check out our quick start and FAQ page here that will
guide you through the process of piecing it together.
Flick Software
Visit our Flick GitHub page and acquire all the software you need to get up and running with your
brand new Flick Large and case.
Additional information
WEIGHT
0.110 kg
DIMENSIONS
19 x 12.5 x 1 cm
http s://www.pi-supply.com/product/flick-large-case/2/9/18
很抱歉,暂时无法提供与“PIS-0557”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+36.712831+4.44234
