VLM-520-ML200
VLM-520-ML200
    QUARTONINC.(夸顿)
    Laser Line Generator Measurements
VLM-520-ML200 数据手册
ML-100 / ML-200 FEATURES Used as a guideline for use in alignment, machine vision systems, construction, and process control and is ideal for most large-field cutting applications, even under a bright surrounding condition and at extreme temperatures. Built-in tempered glass window and waterproof feature to be protected under all weather and sawdust damage from sawmill. The INFINITER ML-100/ML-200 is a tool for professionals that enable you to project a visible red/green laser line, a line up to 100 feet long (at the distance of 29 feet) - suitable for large work surfaces indoor. OPERATION Laser line position adjustment 90° Laser line rotation 360° Plug in with the USB cable and adaptor Magnet Screws not included When in heavy shock/vibration environments, users can place the rubber buffer between bottom chassis and surface. Magnet Four magnets are installed in the bottom chassis of ML-100/ML-200. It will have magnetic attraction when it's on metal surface with iron. SPECIFICATIONS Model name Dimension(L X W X H) ML-100 ML-200 4.60” x 2.13” x 2.32” (11.7 x 5.4 x 5.9 cm) Switch cable : 67.5±1cm Weight 200±5g / 7.05±0.17 oz. Wavelength 635 nm (Red) 520 nm (Green) Width of laser line
VLM-520-ML200 价格&库存
很抱歉,暂时无法提供与“VLM-520-ML200”相匹配的价格&库存,您可以联系我们找货
