VLM-520-60 LPO
VLM-520-60 LPO
    QUARTONINC.(夸顿)
    圆柱型(10.0mm 直径)
    激光二极管 520nm 0.39mW 3V 60mA 圆柱型(10.0mm 直径)
VLM-520-60 LPO 数据手册
Green Dot Laser Module VLM-520-60 Series FEATURES:          Extremely small circular laser dot within 1 meter. Robust stainless steel housing. Built with high precision glass lens. Customized focus within 1 meter available please direct contact us. Two laser power output level: LPO - Class I laser product LPT - Class II laser product Dimensions : Ø 10 x 40 mm (Ø 0.39" x 1.575") Wavelength : 515~530 nm 3~6 VDC operation. Connection type : Lead wire APPLICATIONS: ideal for        Machine vision. Automation industry. Image processing. Medical & Science. Scanning. Counting. Measurement. @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com VLM-520-60 Series OUTLINE DIMENSIONS (UNITS: mm) Outline (Lead Wire type) SPECIFICATIONS Part Number VLM-520-60 LPO VLM-520-60 LPT < 1mm, From 0 to 50cm 1 Spot Size < 2mm, From 50cm to 90cm 2 Dimensions Ø 10 x 40 mm (Ø 0.39" x 1.575") 3 Weight 15±1g 4 Operating voltage (Vop) 5 Operating current (Iop) 6 Laser power output 7 Laser class 8 Wavelength (λp) 3~6 VDC Less than 60mA Less than 150mA Less than 0.39mW Less than 1mW Class I Class II 515~530nm 9 Collimating lens / Line generating lens Aspherical glass lens 10 Output aperture 0.6mm 11 Beam shape Circular 12 Divergence (Half Angle) 13 Beam alignment Less than 0.4 mRad Less than 3° 14 Operating temp. range* -20°C ~+60°C 15 Storage temp. range -20°C ~+85°C 16 Housing material Stainless steel @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com VLM-520-60 Series 17 Potential of housing Insulated 18 Electrostatic discharge (ESD) 30KV / Arc protection 19 Moisture sensitivity level (MSL) Level 1 - acc to JEDEC J-STD-020E. 20 Wire type 2464 2-WIRE CABLE 26 AWG 21 Cable length 330±30mm 22 Mean time to failure (MTTF) 25°C 10000 hrs 23 International Protection Marking IP67 24 Application Industrial alignment 25 Suggestion work distance 0~0.9 meters / 0~3 feet * Operation temperature means within this temperature range, the laser spot/line will not be affected to change the spot size/line width. It can still work over this range, but the laser spot size or laser line width will be larger. ORDER CODE Order Code Wavelength Laser Power Output Laser Class Connection Type VLM-520-60 LPT 520 nm Less than 1mW Class II Lead Wire VLM-520-60 LPO 520 nm Less than 0.39mW Class I Lead Wire SAFETY LABEL LPO: LPT: @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com Optional Accessories Quarton offers mounts, power supply boards, battery pack and USB cable switch to help you running as quickly as possible. For more information, please visit www.quarton.com, www.quarton.com/contact or email contact@quarton.com. QLM-1125 - Laser Module Mount/Holder for diameter 6mm to 12.5mm, it’s an ideal choose for mounted onto optical tables. Feature:  4 directions adjustable.  Can be mounted onto the optical table with screws (Screws not included).  Engraved scale for precision adjustable. LMPS-MP1 - Multi-function Laser Module Power Supply Board. Four input : USB, micro USB, DC Power Jack(5.5 x 2.1), and terminal block. Two channel output : 7 VDC 500mA and 5 VDC 1A. Three switches-toggle switch, remote switch and TTL signal. Feature:  Allow four kinds of power input: USB, micro USB, DC Power Jack(5.5x2.1) and terminal block.  Two Channel output: 7 VDC 500mA and 5 VDC 1A.  Built-in three switches: toggle switch, terminal block remote switch and TTL signal switch by on-board connect point.  7 VDC output work for all Quarton Laser Modules with 7-12 V operation Voltage (Vop).  5 VDC output work for all Quarton Laser Modules with 3-6 V operation Voltage (Vop).  Three LED indicators: Input power indicator, 7V output indicator and 5V output indicator. @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com Optional Accessories LMPS-MP2 - DC converter, In: 9-36V, Out: 5V 1A. LMPS-mUSB1 - Laser Module Power Supply Board, Input: micro USB, Output: 5 VDC 500mA. Feature:  Micro USB connector power input.  Output 5 VDC 500mA with alligator clips.  For all Quarton Laser Modules that require 3-6V operation Voltage. LMPS-DC1 - Laser Module Power Supply Board, Input: DC Power Jack(5.5 x 2.1), Output: 5 VDC 500mA. Feature:  DC Power Jack(5.5 x 2.1) power input.  Output 5 VDC 500mA with alligator clips.  For all Quarton Laser Modules that require 3-6V operation voltage. @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com Optional Accessories CLM-BP4N3 - Battery pack (4* AA batteries) *** AA Batteries are NOT included in package. Feature:  USB Output Voltage: 5 VDC.  Color: Black. CLM-USBSW - USB Cable Switch. Feature:  Length: 28cm.  Color: Black. CLM-UM3M - USB to micro USB Cable. Feature:  Length: 3 meters.  Color: Black. @Copyright 2021 Quarton inc.All Rights Reserved. www.quarton.com
VLM-520-60 LPO 价格&库存
很抱歉,暂时无法提供与“VLM-520-60 LPO”相匹配的价格&库存,您可以联系我们找货
