QLIR01BYGM
QLIR01BYGM V1.1
Product Outline:
QLIR01BYGM is an infrared LED, package dimension is Ø5mm lamp ,860nm emitting diode in
AlGaAs/Si with high speed and high radiant power.
Features:
Infrared 860nm led
With Black resign
Infrared 5mm round lamp
20° Viewing angle (± 10°)
RoHS compliant
Custom Bin available upon special request
Application:
Electronic signs and electronics board
General purpose indicator application
Smoke-automatic fire detectors
Lighting application
Compliance and Certification:
1
QLIR01BYGM V1.1
◼ Mechanical Property:
(Dimension)
SING: 1. CATHODE
2. ANODE
Tolerance is ±0.25mm unless otherwise specified
ELEMENT APPEARANCE
Model No.
Material
Lighting Color
Resin Color
QLIR01BYGM
AlGaAs
Non-Visible
Black
◼ ABSOLUTE MAXIMUM RATINGS AT Ta=25℃
Characteristic
Forward direct current
Symbol
Rating
Unit
IFM
200
mA
1
A
Ta=50℃, pulsed operation tp = 34us
at D= 1/100
Reverse voltage
VRM
5
V
Operating temperature
Topr
-40 to +85
Storage temperature
Tstg
-40 to +100
Pd
380
mW
Power dissipation
2
QLIR01BYGM V1.1
◼ ELECTRO-OPTICAL CHARACTERISTICS AT Ta=25℃
Characteristic
Symbol
Condition
Min.
Radiant Intensity
Ie
IF=100mA
250
Forward Voltage
Vf
IF=100mA
Reverse current
Ir
Vr=5V
Peak emission wavelength
λp
IF=100mA
860
nm
Spectral band width @ 50%
▲λ
IF=100mA
40
nm
Tr/Tf
IF=100mA
25/15
ns
2θ 1/2
IF=100mA
Deg
Rise time / Fall time
Viewing angle
Typ.
Max.
Unit
mW/sr
1.5
2.0
V
10
μA
*Radiant Intensity Measurement allowance is ±15%
** Forward voltage Measurement allowance is ±0.05V
*** Peak emission wavelength Measurement allowance is ±1nm
Dominate Wavelength (nm) Bin:
Wd (nm)
Color
Code name
Min.
Max.
IR
R850
840
870
Measurement tolerance is +/- 2nm
Radiometric power Bin:
Rank @100mA (mW/sr)
Color
Code name
IR
2
3
4
5
Low
250
325
430
580
High
325
430
580
750
luminous flux tolerance is ± 7%
3
QLIR01BYGM V1.1
◼ Characteristic Curves
4
QLIR01BYGM V1.1
◼ Reliability test:
No
Item
Condition
Time/Cycle
Criteria
Ac / Re
Sample size
260℃
5 sec
Open / Short
0/1
60 pcs
0 (5min) ℃ ~100
(5min) ℃
20 cycle
Open / Short
0/1
60 pcs
1
Soldering Heat Test
2
Thermal Shock
3
High Temp. Storage
100℃
1000 Hrs
Open / Short
0/1
60 pcs
4
Low Temp. Storage
-40℃
1000 Hrs
Open / Short
0/1
60 pcs
5
Temperature Cycle Test
-40 ~85 ℃
100 Cycles ,
200Hrs
Open / Short
0/1
60 pcs
6
High Temp.
High Humidity Test
60 , 90% RH ℃
1000 Hrs
Open / Short
0/1
60 pcs
7
DC Operation Life Test
IF=100mA
1000 Hrs
Power decay
≦30%
60 pcs
5
QLIR01BYGM V1.1
◼ Solder Profile:
-The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface
of the LED resin):
6
QLIR01BYGM V1.1
◼ Taping & Packing:
Per Bag
Labeling
Ordering Information:
Part #
QLIR01BYGM
Multiple Quantities
Quantity per bag
500pcs
7
QLIR01BYGM V1.1
Revision History:
Revision Date:
Changes:
Version #:
02-11-2019
Initial release
1.0
03-07-2019
Revise pulse and Radiant Intensity to min.
250mW
1.1
8
很抱歉,暂时无法提供与“QLIR01BYGM”相匹配的价格&库存,您可以联系我们找货
