QLIR05DYAM
QLIR05DYAM
    QUELIGHTING
    4-PLCC
    红外(IR) 发射器 940nm 1.5V 100mA 10mW/sr @ 100mA 4-PLCC
QLIR05DYAM 数据手册
QLIR05DYAM PLCC 4 940nm QLIR05DYAM V1.1 Product Outline: This is PLCC-4 series with high output reflector type 3528 LEDs are available in Infrared Emitter. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • High brightness output @ 100mA Package Dimension = 3.5mmX2.8mmX1.9mm PLCC-4 940nm LED RoHS compliant Custom Bin available upon special request Application: • • • • • Mechanically and spectrally matched to the phototransistor Infrared Illumination for cameras Sensor technology Gesture Recognition Surveillance Compliance and Certification: 1 QLIR05DYAM V1.1 Mechanical Property: (Dimension) Units: mm Recommended Solder footprint: Units: mm 2 QLIR05DYAM V1.1 Electrical / Optical Characteristic (T=25 oC) λp (nm) VF(V) Product Color QLIR05DYAM Iv(mW) IF(mA) Infrared 100 Typ. max 1.5 2.0 Min. Typ. Max. 940 min typ. 10 16 (1) The Forward Voltage tolerance is ±0.1V (2) The λD tolerance is ±1nm (3) The Iv tolerance is ± 7% Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) TSOL (oC)** Infrared 200 100 100 5 -40 – 85 -40 - 100 260 *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder Forward Voltage (VF) Bin: VF rank @ 100mA Code name Min. Max. Unit L6 1.4 2.0 V The forward voltage tolerance is ± 0.1V Radiant Intensity Bin: Po (mW/sr) rank @ 100mA Code name Min. Max. P0010 10 20 P0020 20 30 Unit mW luminous intensity tolerance is ± 7% 3 QLIR05DYAM V1.1 Characteristic Curves Forward Voltage vs. Forward Current Forward current vs. Relative luminous intensity Radiation Pattern 4 QLIR05DYAM V1.1 Spectrum Distribution Relative Luminous Intensity vs Ambient Temperature 5 QLIR05DYAM V1.1 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): - When soldering LEDs, - Do not solder/reflow the same LED over two times. - Recommend soldering conditions: Hand soldering: 300 ℃ max , 3 sec. max. Reflow soldering: Pre-heat 150 max , 180 sec. max. ℃ Peak Temp. 260 C Max 10 Sec Max. 260 Temperature ( C) - Peak 260 ma ℃ x , 5 sec. max. Reflow temperature profile as below: (lead-free solder) 220 200 Gradual Cooling 160 Preheat Zone Soldering Zone Time 90 ~ 220 Sec 60 Sec Max. 6 QLIR05DYAM V1.1 Taping & Packing: Unit : mm 7 QLIR05DYAM V1.1 8 QLIR05DYAM V1.1 Labeling Ordering Information: Part # QLSP05DYAM Multiple Quantities Quantity per Reel 1000pcs, 2000 pcs 9 QLIR05DYAM V1.1 Revision History: Revision Date: Changes: Version #: 01-18-2020 Initial release 1.0 08-05-2020 Updated the electrode polarity 1.1 10
QLIR05DYAM 价格&库存
很抱歉,暂时无法提供与“QLIR05DYAM”相匹配的价格&库存,您可以联系我们找货
