QLSP05RG
QLSP05RG
    QUELIGHTING
    红色 623nm LED 指示 - 分立 2.2V 1411(3528 公制)
QLSP05RG 数据手册
QLSP05RG (3528 PLCC 6 LED) QLSP05RG PLCC 6 V1.0 Product Outline: This is the small TOP LED with reflector type with single color led. This special package is ideal for customer’s application in traffic signal and sign boards. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • • • • • Red color LED High brightness output @ 140mA, High driving current to 200mA. Package Dimension = 3.4mmX3.3mmX1.9mm MSL level 2 RoHS compliant Custom Bin available upon special request View angel >110° AEC-Q101 Application: • • • • • Architecture Lighting Sign board backlighting Emergency vehicle lighting Traffic signal lighting Automotive lighting Compliance and Certification: 1 QLSP05RG PLCC 6 V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP05RG PLCC 6 V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 200 mA Power Dissipation Pd 0.75 W Pulse Forward Current Ifp 500 mA Storage Temperature Tstg -40 ~ 105 ℃ Operation Temperature Topr -30 ~ 105 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ ESD (HBM) ESD(HBM) 2000 V (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition Forward Voltage Vf (Ta=25 oC) Min. Typ. 1.9 Max. Unit 2.65 V 140mA θ View Angle 120 deg (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product QLSP05RG Color Red Vf(V) IF=140mA Dominant Wavelength (nm) 2.2 612~630 Luminous intensity IF=140mA (mcd) Min. Typ. 4500 7300 *Tolerance = +/- 10% 3 QLSP05RG PLCC 6 V1.0 ◼ Groups Dominate Wavelength (nm) Bin: Wd Rank (nm) @ 50mA Color Red Condition Code name Low High A1000 612 616 A2000 616 620 A3000 620 624 A4000 624 630 A5000 630 635 Unit nm Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank (V) @ 50mA Color Red Condition Code name Low High A 1.9 2.05 B 2.05 2.2 C 2.2 2.35 D 2.35 2.5 E 2.5 2.65 unit V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Intensity Rank (mcd) @ 50mA Code name Min. Max. R1 4500 5600 R2 5600 7100 R3 7100 9000 R4 9000 11200 Units mcd Luminous intensity tolerance is ± 7% 4 QLSP05RG PLCC 6 V1.0 ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLSP05RG PLCC 6 V1.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLSP05RG PLCC 6 V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 140 mA △Vf< 10% Luminous Flux Iv 140 mA △Iv< 30% 7 QLSP05RG PLCC 6 V1.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLSP05RG PLCC 6 V1.0 ◼ Taping & Packing: 9 QLSP05RG PLCC 6 V1.0 10 QLSP05RG PLCC 6 V1.0 ◼ Labeling ◼ Ordering Information: Part # QLSP05RG PLCC 6 Multiple Quantities Quantity per Reel 500, 1000, 2000pcs 11 QLSP05RG PLCC 6 V1.0 ◼ Revision History: Revision Date: 10-10-2020 Changes: Initial release Version #: 1.0 12
QLSP05RG 价格&库存
很抱歉,暂时无法提供与“QLSP05RG”相匹配的价格&库存,您可以联系我们找货
