QLSP05YD_B
QLSP05YD_B
    QUELIGHTING
    黄色 591nm LED 指示 - 分立 2V 1411(3528 公制)
QLSP05YD_B 数据手册
QLSP05YD_B PLCC 4 Blackface QLSP05YD_B PLCC 4 V1.0 Product Outline: This high output reflector type 3528 LEDs are available in Yellow color. This special package is ideal for customer’s application in traffic signal and sign boards. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • • Yellow color High brightness output @ 50mA Package Dimension = 3.5mmX2.8mmX1.9mm PLCC-4 black face RoHS compliant Custom Bin available upon special request Application: • • • Sign board backlighting Emergency vehicle lighting Traffic signal lighting Compliance and Certification: 1 QLSP05YD_B PLCC 4 V1.0 Mechanical Property: (Dimension) Units: mm Recommended Solder footprint: Units: mm 2 QLSP05YD_B PLCC 4 V1.0 Electrical / Optical Characteristic (T=25 oC) λD (nm) VF(V) Product QLSP05YD_B Color Iv(mcd) IF(mA) Yellow 50 Typ. max Min. Typ. Max. min typ. 2.0 2.8 588 591 594 1440 1800 (1) The Forward Voltage tolerance is ±0.1V (2) The λD tolerance is ±1nm (3) The Iv tolerance is ± 7% Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) TSOL (oC)** All Yellow 210 70 100 5 -40 – 85 -40 - 100 260 *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder 3 QLSP05YD_B PLCC 4 V1.0 Forward Voltage (VF) Bin: VF rank @ 50mA Code name A B C D E Min. 1.6 1.8 2.0 2.2 2.4 Max. 1.8 2.0 2.2 2.4 2.6 Unit V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Iv rank @ 50mA Code name Min. Max. X5 1440 1800 X6 1800 2250 Unit mcd luminous intensity tolerance is ± 7% Dominant Wavelength Bin: λD @ IF=50mA Code name Min. Max. A1 588 591 A2 591 594 Unit nm 4 QLSP05YD_B PLCC 4 V1.0 Characteristic Curves Forward Voltage vs. Forward Current Forward current vs. Relative luminous intensity Radiation Pattern 5 QLSP05YD_B PLCC 4 V1.0 Spectrum Distribution 6 QLSP05YD_B PLCC 4 V1.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 7 QLSP05YD_B PLCC 4 V1.0 Taping & Packing: Unit : mm 8 QLSP05YD_B PLCC 4 V1.0 9 QLSP05YD_B PLCC 4 V1.0 Labeling Ordering Information: Part # QLSP05YD_B Multiple Quantities Quantity per Reel 1000, 2000 pcs 10 QLSP05YD_B PLCC 4 V1.0 Revision History: Revision Date: Changes: 09-27-2016 Initial release 10-10-2020 Update performance Version #: 1.0 11
QLSP05YD_B 价格&库存
很抱歉,暂时无法提供与“QLSP05YD_B”相匹配的价格&库存,您可以联系我们找货
QLSP05YD_B
  • 1000+1.283071000+0.15555
  • 2000+1.176152000+0.14259
  • 5000+1.069225000+0.12962
  • 10000+0.9979410000+0.12098
  • 25000+0.9623025000+0.11666
  • 50000+0.9266650000+0.11234
