FIBER OPTIC
1xN SWITCH
coaxial design
FEATURES
OVERVIEW
sercalo's fiber optic 1xN switches are bidirectional optomechanical switches based on a coaxial design where a
single MEMS mirror redirects light from a common fiber to
one of N ports. The MEMS technology results in low
insertion loss and low crosstalk between channels while
keeping a constant switching performance over life.
Low insertion loss
Reliable
Up to 1x36 optical ports
UART, I2C/SMBus and parallel
interface
Ethernet interface available on
request
RoHS compliant
The switch is available in several different variants to
simplify integration in existing systems and reduce
development cost. The miniature packages withstands APPLICATIONS
rugged environments and is well suited for direct mounting
• Optical network switching
on printed circuit boards.
• Instrumentation
The hermetically sealed MEMS and the laser welded fiber
• Test and measurement
collimator guarantee broad temperature range and
superior long-term stability. No epoxy is present in the
optical path.
The component is compliant to Telcordia 1221 reliability
standards and RoHS requirements 2015/863/EU.
Contact:
Sercalo Microtechnology Ltd.
Landstrasse 151
9494 Schaan - Principality of Liechtenstein
Tel. +423 237 57 97
Fax. +423 237 57 48
www.sercalo.com e-mail: info@sercalo.com
ORDERING INFORMATION
- SC
Package type
none = standard package
bc = bare component
m = miniature
r = industry compatible
1x4 -
Switch Ports
type
1x4
SC
1x8
1x12
1x16
1x24
1x32
up to
1x36
9
R
Fiber type
9 = SMF28ULTRA
9PM = PM15-U40A
(Corning Panda fiber)
7 = SM980 for 1050nm
4 = SM600 for 630nm
Other fiber types and
wavelengths upon
request
05
Fiber sleeve type
B = 250mm bare fibers
R = 8-fibers or
12-fibers ribbon
N = 900 mm sleeve
(on rSC only)
FP
Pigtail length
Expressed in
decimeters
e.g.:
05 = 50 cm
10 = 100 cm
Information in this datasheet is believed to be correct but Sercalo reserves the right to change specifications without notice at any time. [90-1180-15]
Connectors type
none = no connectors
FP = FC-PC
FA = FC-APC narrow key
LP = LC-PC
SA = SC-APC
SP = SC-PC
sercalo
sercalo’s COAXIAL TYPE 1xN switch is non-latching: at power-off it breaks the optical connection
and routing of the common port is not defined. The component is bidirectional, the common port can
be used as input or output. The PM Panda version is offered up to 1x4 ports.
The switch is available in four different variants:
SC: standard size – ribbon fibers
mSC: miniature size – small driver board: 7x40 mm
rSC: compatible with industry pinout
bcSC: bare optical component
TECHNICAL SPECIFICATIONS
Optical Specifications
Wavelength range
Insertion loss up to 1x41
Insertion loss up to 1x161
Insertion loss up to 1x241
Insertion loss up to 1x361
Crosstalk
Polarization dependent loss
Return loss
Wavelength dependent loss (one band)
Wavelength dependent loss (1250–1670 nm)
Temperature dependent loss
Maximum optical power level2
Switching time
Cycle rate
Repeatability3
Durability
Optical Specifications (PM fiber - up to 1x4)
Polarization extinction ratio
Electrical Specifications (SC, mSC, rSC)
Supply voltage
Power consumption, normal mode
Power consumption, standby
UART speed
SMBus/I2C bus speed
Input logic level low
Input logic level high
Output logic level low
Output logic level high
Reset inactive voltage4
Reset active voltage
Reset pulse duration
Electrical Specifications (bcSC)
Driving voltage
Driving voltage damage threshold
Electrostatic discharge tolerance5
Package
Operating temperature
Storage temperature
Operation humidity (non condensing)
Pigtail length
Dimensions
SC
mSC
rSC
bcSC
ROHS Compliance
Unit
Min
nm
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
mW
ms
Hz
dB
cycles
1250
dB
V
mW
mW
baud
kbps
V
V
V
V
V
V
ms
4.75
Typ
50
0.4
0.8
1.0
1.2
60
50
55
Max
1670
1.0
1.2
1.5
2.0
0.1
0.5
5
10
No wear out
9600
2.4
2.6
2.4
15
V
V
V
˚C
˚C
% r.h.
cm
mm
mm
mm
mm
-10
-40
5
40
5
1.0
0.2
500
10
50
0.01
5.25
150
115200
400
0.6
0.6
0.9
45
50
70
85
95
100
40 x 21 x 7
40 x 7 x 7.5
68 x 30 x 9
6 x 35
2015/863/EU (no exceptions)
Values at 25 ˚C at 1550 nm, without connectors. For operation over several bands 1250 to 1670 add 0.5 dB. 2 It is recommended
to turn off the laser during switch transients when switching optical power above 100 mW. 3For constant temperature and
polarization. 4Through onboard pull-up resistor. 5 The bare optical component is not protected against ESD.
1
sercalo
FUNCTIONAL BLOC DIAGRAM
SC STANDARD SIZE – DIMENSIONS AND PINOUT
mSC MINIATURE – DIMENSIONS AND PINOUT
Pin
number
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Pin
number
1
2
3
4
5
6
7
8
9
10
Description
Parallel PD3
Parallel PD4
Parallel PD1
Parallel PD2
Parallel STROBE/ENABLE
Parallel PD0
Ground (GND)
Supply voltage (VDD)
Reserved
UART TX
Reserved
UART RX
System reset (RST)
SMBus/I2C SDA
SMBus/I2C SCL
Ground (GND)
Description
I/F mode
System reset (RST)
Ground (GND)
SMBus/I2C A0
SMBus/I2C A2 / UART RX
SMBus/I2C A1 / UART TX
SMBus/I2C SCL
SMBus/I2C A3
SMBus/I2C SDA
sercalo
rSC INDUSTRY COMPATIBLE – DIMENSIONS AND PINOUT
Pin
number
1
2
3
4
5
6
7
8
9
10
11
12
13
14
Description
I/F mode 1
Parallel strobe
Ground (GND)
Parallel D0 / SMBus/I2C A0
SMBus/I2C SDA / UART TX
SMBus/I2C SCL / UART RX
I/F mode 0
Parallel D2 / SMBus/I2C A2
Done
Ground (GND)
Parallel D1 / SMBus/I2C A1
Parallel D3 / SMBus/I2C A3
System reset (RST)
bcSC BARE OPTICAL COMPONENT – DIMENSIONS AND PINOUT
Pin
number
1
2
3
4
5
Description
Axis XAxis YAxis X+
Axis Y+
Common
Insertion Loss [dB]
INSERTION LOSS vs. TEMPERATURE (SC 1x8)
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
-10
40
50
60
70
80
Temperature [˚C]
sercalo
Insertion Loss [dB]
WAVELENGTH DEPENDENT LOSS (SC 1x4)
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
1510 1520 1530 1540 1550 1560 1570 1580 1590 1600 1610 1620 1630 1640
Wavelength [nm]
OPTICAL RESPONSE TIME
CONTINUOUS SWITCH OPERATION
Optical power on
target channel
Optical power
on channel #1
Optical power
on channel #2
500 ms/div
10 ms/div
sercalo
很抱歉,暂时无法提供与“RSC1X8-9N-10-FA”相匹配的价格&库存,您可以联系我们找货
