SparkFun Qwiic Joystick
COM-15168
Now, you can easily add an HID/controller to your project! The SparkFun Qwiic Joystick combines
the convenience of the Qwiic connection system and an analog joystick that feels reminiscent of the
thumbstick from a PlayStation 2 controller and for that reason it's become a favorite of ours. The only
thing that could make it better is a "smart" version, so we made one! With the pre-installed firmware,
the ATtiny85 is acts as an intermediary (microcontroller) for the analog and digital inputs from the
joystick. This allows the Qwiic Joystick to report its position over I2C. Utilizing our handy Qwiic
system, no soldering is required to connect it to the rest of your system. However, we still have
broken out 0.1"-spaced pins in case you prefer to use a breadboard.
The joystick is similar to the analog joysticks on PS2 (PlayStation 2) controllers. Directional
movements are simply measured with two 10 kΩ potentiometers, connected with a gimbal
mechanism that separates the horizontal and vertical movements. This joystick also has a select
button that is actuated when the joystick is pressed down. The SparkFun Qwiic Joystick's I2C
address is also software selectable so you can plenty of them to the same bus without any risk of
collision!
The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
Qwiic Compatible
Software Selectable Slave Address
Low Power ATtiny85 controller
Reports X and Y Joystick position + button press
https://www.sparkfun.com/products/15168/3‐7‐19
很抱歉,暂时无法提供与“COM-15168”相匹配的价格&库存,您可以联系我们找货
