SparkFun LumiDrive LED Driver
DEV-14779
The LumiDrive LED Driver is SparkFun’s foray into all things Python on micro-controllers. With the
SparkFun LumiDrive you will be able to control and personalize a whole strand of APA102s directly
from the board itself. We’ve broken out a number of analog and digital pins from the on board
SAMD21G-AU microcontroller to incorporate your own external buttons, switches, and other
interfaces to interact with your addressable LED strip.
It feels like Arduino, but without the need to upload and compile code. Because the LumiDrive opens
up like a USB drive on your computer when you plug it in and the code you write lives directly inside
the drive it feels very much like an Arduino-device. The fact that you don’t need to upload and
compile code makes it a great transitionary LED driver from your traditional Arduino!
The SparkFun LumiDrive has been equipped with a USB-C connector which is capable enough to
supply up to 1.5 Amps from a 3.1 USB port, a LiPo connector and charge circuit for portable power,
as well as two poke-home connectors to allow you to plug in wires without the need for solder.
https://www.sparkfun.com/products/14779/1‐21‐19
很抱歉,暂时无法提供与“DEV-14779”相匹配的价格&库存,您可以联系我们找货
