ROB-14339
ROB-14339
    SPARKFUNELECTRONICS
    CIRCULAR ROBOTICS CHASSIS KIT
ROB-14339 数据手册
      Circular Robotics Chassis Kit (Three-Layer) ROB-14339 DESCRIPTION The three-layer Circular Robotics Chassis Kit is a sturdy, miniature robotics kit designed for beginners and experienced roboticists alike. The chassis plates are made from three 1.5mm aluminum alloy frames milled with plenty of mounting points for sensors, servos, controllers, power and more. Assembly is simple; with just a few included screws needed for construction, you will have a reliable 2WD robotics chassis. The Circular Robotics Chassis Kit does not include any motors or motor controllers, allowing you to choose your own. The kit, however, does include wheels, frames, a ball caster and all assembly materials like screws, bolts and standoffs. In our opinion, this is one of the most durable and economical chassis we have used in quite some time, and it works amazingly well with a Raspberry Pi, the SparkFun moto:bit or our Wireless Motor Driver Shield. Note: The Circular Robotics Chassis Kit does NOT include motors, a motor controller or a power source. These items will need to be purchased separately. INCLUDES      3x Aluminum Alloy Plate 2x Aluminum Alloy DC Motor Bracket 2x Wheel 1x Ball Caster 1x Assembly Material Bag FEATURES 100mm x 80mm x 65mm (Assembled) https://www.sparkfun.com/products/14339 9-8-17
ROB-14339 价格&库存
很抱歉,暂时无法提供与“ROB-14339”相匹配的价格&库存,您可以联系我们找货
