SparkFun Ambient Light Sensor Breakout APDS-9301
SEN-14350 RoHS
The APDS-9301 Ambient Light Sensor Breakout is an I2C-compatible luminosity sensor board that
converts light intensity to a digital output signal. This breakout is fairly simple and has been
specifically designed with only a few ancillary passive components in addition to the ADPS-9301 IC
itself. All readings are returned to your chosen microprocessor in lux, providing precise Illuminance
measurement under diverse lighting conditions.
On top of each board breaking out our standard I2C pin-out of SCL, SDA, 3.3V and GND, we’ve also
provided an INT pin so the APDS-9301 can be programmed to generate an interrupt under certain
conditions. It is important to note that this breakout is non-instantaneous, so it will require some
integration time to take a measurement.
Typical Operating Voltage: 3.0V
Maximum Operating Voltage: 3.6V
16-Bit Digital Output with I2C Fast-Mode at 400kHz
Programmable Analog Gain and Integration Time
50/60-Hz Lighting Ripple Rejection
Programmable Interrupt Pin and Function
I2C Pull-up Resistors
https://www.sparkfun.com/products/14350 9‐18‐17
很抱歉,暂时无法提供与“SEN-14350”相匹配的价格&库存,您可以联系我们找货
