SFSA32GBV1BR4TO-I-NC-226-3V3 数据手册
Product fact sheet
Industrial
Slim-SATA SSD MO-297
X-200s Series
SATA II - 3.0Gb/s
up to UDMA6 / MDMA2 / PIO4
Standard and industrial
temperature grade
B U:
Sw i ss b it Gr ou p
Date :
De ce m be r 18 , 20 1 4
Re vi si o n: 1 .1 2
X - 2 00 s_ fa ct_ s he e t_ SA - V x BR_Re v 1 1 2 .d oc
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
Swissbit reserves the right to change products or specifications without notice.
www.swissbit.com
info@swissbit.com
Revision: 1.12
X-200s_fact_sheet_SA-VxBR_Rev112
Page 1 of 4
X-200s Series – Industrial Slim-SATA Solid State Drive
2GByte up to 64GByte (MO-297)
Feature summary
Form factor:
o
Full-sized mSATA form factor
o
JEDEC MO-297 sized Solid State Drive (SSD)
o
54mm x 39mm x 4mm
o
7+15 pin (SATA+power) SATA connector
o
Replacement of a standard SATA-compliant HDD
Interface:
o SATA Rev 2.6 - 3Gbit/s (1.5Gbit/s compatible)
Highly-integrated memory controller
o
max. UDMA6 supported
o
max. PIO mode 4, MDMA2 supported
o
SLC NAND Flash
o
Hardware BCH-code ECC (8 Bit correction per sector for SLC)
o
fix drive configuration
Low-power CMOS technology
5.0V ± 10% power supply (3.3V optional)
Low Power, less than 500mA
optional activity LED, write protect, Quick erase switch and conformal coating on request
No mechanical noise
Wear Leveling: active wear leveling of static and dynamic data
The wear leveling assures that dynamic data as well as static data is balanced evenly across the
memory. With that the maximum write endurance of the device is guaranteed.
High reliability
o
MTBF > 2,500,000 hours
o
Data reliability: < 1 non-recoverable error per 1014 bits read
o
Number of connector insertions/removals: >1,000
High performance
o
Up to 300MB/s burst transfer rate in SATA II - 3.0Gb/sec
o
Sustained Write performance: up to 95MB/s
o
Sustained Read Performance: up to 120MB/s
Available densities
o
2GByte up to 64GByte (SLC NAND Flash)
S.M.A.R.T., HPA, Security and 48bit feature set
2 Temperature ranges
o
Commercial Temperature range
0 … +70°C
o
Industrial Temperature range
-40 … +85°C
Life Cycle Management
Controlled BOM
RoHS compatible
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 1.12
Page 2 of 4
Pin out
The SLIM SATA connector is a standard SATA 7+15pin connector.
Table 1: Pin Assignment, name, and description
Pin
Signal Name
Description
S1
Ground
Signal Ground
S2
A+
+ Differential Receive signal
S3
A-
- Differential Receive signal
S4
Ground
Signal Ground
S5
B-
- Differential Transmit signal
S6
B+
+ Differential Transmit signal
S7
Ground
Signal Ground
P1…P3
3.3V
3.3V power (optional on request)
P4…P6
Ground
Power Ground
P7
5V
5V precharge
P8…P9
5V
5V power
P10
Ground
Power Ground
P11
Device activity
DA / LED (optional NC on request)
P12
Ground
Power Ground
P13…P15
12V
12V power (not used)
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 1.12
Page 3 of 4
Table 2: System Performance
System Performance
Data transfer Rate (SATA burst)
Sustained Read (max. measured)
Sustained Write (max. measured)
1.
2.
2GB
4GB
8...32GB
3.0 (1.5)
~110
~120
~47
~95
~60
~26
64GB
~110
~94
Unit
Gbit/s
MB/s
All values refer to modules with Toshiba or Micron Flash chips in UDMA mode 5, SATA 3.0Gbit/s, write/read data sequential
256 Sectors/Transfer command.
Sustained speed depends on flash type and number, file size, and burst speed
Table 3: Current consumption(1) at 5V ± 10%
Current Consumption
Write (UDMA6)
Read (UDMA6)
Standby
1.
typical
350
250
125
max
400
350
140
Unit
mA
All values are typical at 25° C and nominal supply voltage and refer to 16GByte SSD module.
Table 4: Environmental Specifications
Temperature (commercial)
Temperature (industrial)
Humidity (non-condensing)
Vibration (peak -to-peak)
Shock
Operating
Non Operating
0 to 70°C
-50 to 100°C
-40 to 85°C
-50 to 100°C
85% RH, at 85°C
max. 95% RH, at 85°C
20G Peak, 10…2000Hz
1500G, 0.5ms duration, half sine wave
Table 5: Physical Dimensions
Physical Dimensions
Unit
Width
Height
Thickness max.
Weight (typ.)
54.0
39.8 (with connector)
4 (connector)
7
mm
g
Table 6: SSD capacity specification
Capacity
2GB
4GB
8GB
16GB
32GB
64GB
Default_cylinders
3,886
7,732
15,498
16,383*)
16,383*)
16383*)
Default_heads
16
16
16
16
16
16
Default_sectors
63
63
63
63
63
63
Sectors_drive
3,896,928
7,793,856
15,621,984
31,277,056
62,586,880
125’313’024
Total addressable Bytes
1,995,227,136
3,990,454,272
7,998,455,808
16,013,852,672
32,044,482,560
64‘160‘268‘288
*) The CHS addressing is limited to about 8GB. Larger drives should be used in LBA mode.
Table 7: System Reliability and Maintenance
MTBF (at 25°C)
Data Reliability
> 2,500,000 hours
14
< 1 Non-Recoverable Error per 10 bits Read
(1) Dependent on final system qualification data.
For more information on MO-297 mechanical standard, please visit JEDEC at www.jedec.org.
For more information on Serial ATA Revision 2.6, please visit Serial ATA International Organization at
www.serialata.org
Why Swissbit?
Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled
in-house product research and development team. Swissbit maintains a marketing edge by continuing to
manufacture world-class high quality memory products and providing customers with both high value and
low cost of ownership achieved through efficient processes and procedures.
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 1.12
Page 4 of 4
