TAI-TECH
P2
High Current Ferrite Bead
BPH322521W5-350T
1. Features
1. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Operating temperature -40~+125℃ (Including self - temperature rise)
Halogen
2. Dimension
Halogen-free
CORE SIZE
A(mm)
B(mm)
C(mm)
D(mm)
3.10±0.15
2.50±0.15
2.10±0.15
0.90±0.15
PRODUCT SIZE
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
F(mm)
G(mm)
3.10±0.15
2.50±0.15
2.15±0.15
0.85±0.20
1.20±0.20
0.00~0.10
0.70±0.10
3. Part Numbering
BPH
322521 W5
A
B
C
350
T
D
E
A: Series
B: Dimension
C: Material
Ferrite Core
D: Impedance
350=35Ω
E: Packaging
T=Taping and Reel
4. Specification
TAI-TECH
Part Number
BPH322521W5-350T
ELECTRICAL
REQUIREMENTS 1
ELECTRICAL
REQUIREMENTS 2
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
25
25
±25
35
Note:
Rated Current:
(1) : Chroma high current test fixture.
www.tai-tech.com.tw
±25
100
DCR
(mΩ) Max.
Rated
Current(A)
△T=40℃
TYP.
0.60
21.0
TAI-TECH
P3
Typical Impedance v.s. Frequency Curve
IMPEDANCE(Ohm)
100
10
1
1
10
100
1000
FREQUENCY(MHz)
5. Material List
No.
Description
Specification
a.
Core
Ferrite Core
b.
Wire
Electroplated nickel-tin flat copper wire
6. Recommended PC Board Pattern
www.tai-tech.com.tw
10000
TAI-TECH
P4
BPH323023W5-400T
1. Features
Halogen
2. Operating temperature-40~+125℃ (Including self - temperature rise)
Halogen-free
2. Dimension
PRODUCT SIZE
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
F(mm)
G(mm)
2.90±0.10
2.20±0.10
0.80±0.20
1.20 Min.
0.00~0.11
0.85±0.10
3.08
+0.10/-0.15
3. Part Numbering
BPH
323023 W5
A
B
400
T
D
E
C
A: Series
B: Dimension
C: Material
Ferrite Core
D: Impedance
E: Packaging
400=40Ω
T=Taping and Reel
4. Specification
ELECTRICAL
REQUIREMENTS 1
TAI-TECH
Part Number
BPH323023W5-400T
ELECTRICAL
REQUIREMENTS 2
Rated Current(A)
Test
Test
Impedance Tolerance
Impedance Tolerance
Frequency
Frequency
(Ω)
(Ω)
(MHz)
(MHz)
23
±25
25
40
±25
Note:
Rated Current :
(2) :PCB test fixture ( 30x45mm copper pattern , 50um copper thickness).
www.tai-tech.com.tw
100
DCR
(mΩ) Max.
△T=40℃ △T=60℃
TYP.
TYP.
0.60
21.0(1)
15.0(2)
26.0(1)
18.0(2)
TAI-TECH
P5
IMPEDANCE(Ohm)
100
10
1
1
10
100
1000
10000
FREQUENCY(MHz)
5. Material List
No.
a.
Description
Core
Specification
Ferrite Core
a
b.
Wire
(0.8W X 0.25T)mm
b
L(mm)
G(mm)
H(mm)
3.70
1.10
1.10
www.tai-tech.com.tw
TAI-TECH
P6
BPH403022R5-400T-G
1. Features
Halogen
Halogen-free
2. Dimension
PRODUCT SIZE
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
3.90~4.50
3.00±0.15
2.20 Max
1.00±0.20
1.25±0.15
3. Part Numbering
BPH
403022 R5
A
B
400
T
D
E
C
G
F
A: Series
B: Dimension
C: Material
Ferrite Core
D: Impedance
400=40Ω
E: Packaging
T=Taping and Reel
F: Control S/N
4. Specification
TAI-TECH
Part Number
BPH403022R5-400T-G
ELECTRICAL
REQUIREMENTS 1
ELECTRICAL
REQUIREMENTS 2
Test
Impedance Tolerance
Frequency
(Ω)
(Hz)
Test
Impedance Tolerance
Frequency
(Ω)
(Hz)
24
25M
±25
40
±25
Note:
Rated Current :
(2) : DCR is measured on a micro-ohmmeter at points indicat in the diagram.
www.tai-tech.com.tw
100M
DCR
(mΩ)
Max.
0.7
Rated Current(A)
△T=40℃
TYP.
△T=60℃
TYP.
20.0
28.0
TAI-TECH
P7
IMPEDANCE(Ohm)
100
10
1
1
10
100
1000
10000
FREQUENCY(MHz)
5. Material List
No.
Description
a.
Core
b.
Wire
Specification
a
Ferrite Core
(1.25W X 0.21T)m/m
b
L(mm)
G(mm)
H(mm)
4.8
2.0
1.5
www.tai-tech.com.tw
TAI-TECH
P8
BPH403025R5-530T
1. Features
Halogen
2. Dimension
Halogen-free
CORE SIZE
A(mm)
B(mm)
C(mm)
D(mm)
4.00±0.25
3.10±0.15
2.50±0.15
1.50±0.15
PRODUCT SIZE
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
4.30~5.10
3.10±0.15
2.70~3.1
1.35±0.20
1.35±0.15
3. Part Numbering
BPH
403025 R5
A
B
530
T
D
E
C
A: Series
B: Dimension
C: Material
Ferrite Core
D: Impedance
530=53Ω
E: Packaging
T=Taping and Reel
4. Specification
TAI-TECH
Part Number
BPH403025R5-530T
ELECTRICAL
REQUIREMENTS 1
ELECTRICAL
REQUIREMENTS 2
Test
Test
Impedance Tolerance
Impedance Tolerance
Frequency
Frequency
(Ω)
(Ω)
(MHz)
(MHz)
35
±25
25
53
±25
100
Note:
Rated Current :
www.tai-tech.com.tw
DCR
(mΩ)
Max.
0.60
Rated Current(A)
△T=40℃
TYP.
△T=60℃
TYP.
35.0(1)
15.0(2)
45.0(1)
18.0(2)
TAI-TECH
P9
IMPEDANCE(Ohm)
100
10
1
1
10
100
1000
10000
FREQUENCY(MHz)
5. Material List
No.
Description
a.
Core
b.
Wire
Specification
a
Ferrite Core
(1.25W X 0.21T)m/m
b
L(mm)
G(mm)
H(mm)
4.8
1.4
1.5
www.tai-tech.com.tw
TAI-TECH
P10
BPH403025MN5-470TP
1. Features
Halogen
2. Dimension
Halogen-free
CORE SIZE
A(mm)
B(mm)
C(mm)
D(mm)
4.00±0.25
3.10±0.15
2.50±0.15
1.50±0.15
PRODUCT SIZE
A(mm)
B(mm)
4.30~5.10
3.10±0.15
C(mm)
D(mm)
2.70~3.10 1.35±0.20
E(mm)
1.35±0.15
3. Part Numbering
BPH
403025 MN5 -
A
B
470
T
P
D
E
F
C
A: Series
B: Dimension
C: Material
MnZn Core
D: Impedance
470=47Ω
E: Packaging
T=Taping and Reel
F: Surface coating
Parylene coating
4. Specification
TAI-TECH
Part Number
ELECTRICAL
REQUIREMENTS 1
ELECTRICAL
REQUIREMENTS 2
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
BPH403025MN5-470TP
±25
1
47
±25
Note:
Rated Current :
www.tai-tech.com.tw
Rated Current(A)
10
DCR
(mΩ) Max.
0.75
△T=40℃
TYP.
△T=60℃
TYP.
24.0(1)
10.0(2)
28.0(1)
13.0(2)
TAI-TECH
P11
BPH403025MN5-470TP
60
IMPEDANCE (Ω)
50
40
0amp
30
1amp
2amp
3amp
4amp
5amp
10
10
100
1000
FREQUENCY(MHz)
BPH403025MN5-470TP
60
IMPEDANCE (Ω)
50
40
30
10
100
1000
10000
FREQUENCY(MHz)
R
X
Z
c
5. Material List
No.
Description
a.
Core
b.
Wire
Specification
a
MnZn Ferrite Core
(1.25W X 0.21T)m/m
c
b
Surface coating Parylene coating
L(mm)
G(mm)
H(mm)
4.8
1.4
1.5
www.tai-tech.com.tw
TAI-TECH
P12
BPH853025R5-101T
1. Features
Halogen
Halogen-free
2. Dimension
CORE SIZE
A(mm)
B(mm)
C(mm)
D(mm)
8.50±0.25
3.00±0.15
2.50±0.15
1.50±0.15
PRODUCT SIZE
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
9.00±0.40
3.00±0.15
2.80±0.25
1.50±0.50
1.25±0.20
3. Part Numbering
BPH
A
853025 R5
B
C
101
T
D
E
A: Series
B: Dimension
C: Material
Ferrite Core
D: Impedance
E: Packaging
101=100Ω
T=Taping and Reel
4. Specification
TAI-TECH
Part Number
BPH853025R5-101T
ELECTRICAL
REQUIREMENTS 1
ELECTRICAL
REQUIREMENTS 2
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
Test
Impedance Tolerance
Frequency
(Ω)
(MHz)
65
25
±25
100
±25
Note:
Rated Current :
www.tai-tech.com.tw
100
DCR
(mΩ)
Max.
1.00
Rated Current(A)
△T=40℃
TYP.
△T=60℃
TYP.
30(1)
13(2)
40(1)
18(2)
TAI-TECH
P13
IMPEDANCE(Ohm)
1000
100
10
1
1
10
100
1000
10000
FREQUENCY(MHz)
5. Material List
No.
Description
a.
Core
b.
Wire
Specification
a
Ferrite Core
(1.25W X 0.21T)m/m
b
L(mm)
G(mm)
H(mm)
10.7
4.5
1.5
www.tai-tech.com.tw
TAI-TECH
P14
Reliability and Test Condition
Item
Performance
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z( Impedance)
Agilent E4991A + Keysight 16092A
Refer to standard electrical characteristics list.
DCR
Agilent-34420A
Heat Rated Current (Irms) will cause the coil temperature rise △
T(℃) without core loss.
Approximately △T≦40℃
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through reflow for 3 times.( IPC/JEDEC
J-STD-020E Classification Reflow Profiles)
Temperature: 125±2℃(Inductor)
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24 hrs.
Humidity:85±3% R.H,
Load Humidity
Temperature:85℃±2℃
Duration : 1000hrs Min. Bead : with 100% rated current ,
Inductance: with 10% rated current
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep
3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25 ℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:125±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration
www.tai-tech.com.tw
TAI-TECH
Item
P15
Performance
Bending
Shock
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg ,
BPH 403022R5-400T-G 价格&库存
很抱歉,暂时无法提供与“BPH 403022R5-400T-G”相匹配的价格&库存,您可以联系我们找货
