TAI-TECH
KBM01-230200181 P2.
High Current Ferrite Chip Bead(Lead Free)
HCB-SERIES
1.Features
Halogen
1. Monolithic inorganic material construction.
2. Closed magnetic circuit avoids crosstalk.
Halogen-free
3. Suitable for reflow soldering.
4. Shapes and dimensions follow E.I.A. spec.
5. Available in various sizes.
6. Excellent solder ability and heat resistance.
7. High reliability.
8.100% Lead(Pb) & Halogen-Free and RoHS compliant.
9. Low DC resistance structure of electrode to prevent wasteful electric power consumption.
10. Operating Temperature: -55~+125℃(Including self-temperature rise)
2.Dimensions
Chip size
Size
A(mm)
B(mm)
C(mm)
D(mm)
1005
1.00±0.10
0.50±0.10
0.50±0.10
0.25±0.10
1608
1.60±0.15
0.80±0.15
0.80±0.15/0.60±0.15
0.30±0.20
2012
2.00±0.20
1.25±0.20
0.85±0.20
0.50±0.30
3216
3.20±0.20
1.60±0.20
1.10±0.20
0.50±0.30
4516
4.50±0.20
1.60±0.20
1.60±0.20
0.50±0.30
4532
4.50±0.20
3.20±0.20
1.50±0.20
0.50±0.30
3.Part Numbering
HCB
1608
KF
A
B
C
A: Series
B: Dimension
C: Material
D: Impedance
E: Packaging
F: Rated Current
121
T
D
E
F
LxW
Lead Free Material
121=120Ω
T=Taping and Reel, B=Bulk(Bags)
20=2000mA
4.Specification
Tai-Tech
Part Number
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB1005MF-100T25
10±25%
100
0.05
2500
HCB1005KF-600T30
60±25%
100
0.04
3000
HCB1005KF-800T20
80±25%
100
0.10
2000
HCB1005KF-121T20
120±25%
100
0.095
2000
HCB1005KF-221T15
220±25%
100
0.15
1500
HCB1005PF-330T30
33±25%
100
0.022
3000
HCB1005PF-600T25
60±25%
100
0.032
2500
HCB1005PF-800T23
80±25%
100
0.038
2300
Rated current: based on temperature rise test
In compliance with EIA 595
www.tai-tech.com.tw
TAI-TECH
Tai-Tech
Part Number
KBM01-230200181 P3.
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB1606ZF-260T60
26±25%
100
0.01
6000
HCB1608KF-300T30
30±25%
100
0.04
3000
HCB1608KF-300T60
30±25%
100
0.01
6000
HCB1608KF-600T30
60±25%
100
0.04
3000
HCB1608KF-800T30
80±25%
100
0.04
3000
HCB1608KF-121T20
120±25%
100
0.10
2000
HCB1608KF-121T30
120±25%
100
0.04
3000
HCB1608KF-151T20
150±25%
100
0.10
2000
HCB1608KF-181T20
180±25%
100
0.10
2000
HCB1608KF-221T20
220±25%
100
0.10
2000
HCB1608KF-301T10
300±25%
100
0.20
1000
HCB1608KF-301T20
300±25%
100
0.10
2000
HCB1608KF-471T10
470±25%
100
0.20
1000
HCB1608KF-601T10
600±25%
100
0.20
1000
HCB1608KF-601T20
600±25%
100
0.10
2000
HCB1608KF-102T10
1000±25%
100
0.20
1000
HCB2012KF-300T30
30±25%
100
0.04
3000
HCB2012KF-300T60
30±25%
100
0.01
6000
HCB2012KF-600T30
60±25%
100
0.04
3000
HCB2012KF-800T30
80±25%
100
0.04
3000
HCB2012KF-800T50
80±25%
100
0.02
5000
HCB2012KF-101T30
100±25%
100
0.04
3000
HCB2012KF-121T20
120±25%
100
0.10
2000
HCB2012KF-121T30
120±25%
100
0.04
3000
HCB2012KF-121T50
120±25%
100
0.02
5000
HCB2012KF-151T20
150±25%
100
0.10
2000
HCB2012KF-221T20
220±25%
100
0.10
2000
HCB2012KF-221T30
220±25%
100
0.04
3000
HCB2012KF-301T10
300±25%
100
0.20
1000
HCB2012KF-301T30
300±25%
100
0.04
3000
HCB2012KF-471T10
470±25%
100
0.20
1000
HCB2012KF-601T10
600±25%
100
0.20
1000
HCB2012KF-601T20
600±25%
100
0.10
2000
HCB2012KF-102T15
1000±25%
100
0.15
1500
www.tai-tech.com.tw
TAI-TECH
Tai-Tech
Part Number
KBM01-230200181 P4.
Impedance (Ω)
Test Frequency
(MHz)
DC Resistance
(Ω) max.
Rated Current
(mA) max.
HCB3216KF-300T30
30±25%
100
0.04
3000
HCB3216KF-310T60
31±25%
100
0.01
6000
HCB3216KF-500T30
50±25%
100
0.04
3000
HCB3216KF-500T60
50±25%
100
0.01
6000
HCB3216KF-800T30
80±25%
100
0.04
3000
HCB3216KF-121T20
120±25%
100
0.10
2000
HCB3216KF-121T30
120±25%
100
0.04
3000
HCB3216KF-121T50
120±25%
100
0.02
5000
HCB3216KF-151T20
150±25%
100
0.10
2000
HCB3216KF-301T10
300±25%
100
0.20
1000
HCB3216KF-471T10
470±25%
100
0.20
1000
HCB3216KF-501T30
500±25%
100
0.04
3000
HCB3216KF-601T20
600±25%
100
0.10
2000
HCB3216KF-601T30
600±25%
100
0.04
3000
HCB4516KF-600T60
60±25%
100
0.01
6000
HCB4516KF-800T30
80±25%
100
0.04
3000
HCB4532KF-800T60
80±25%
100
0.01
6000
HCB4532KF-800T90
80±25%
100
0.01
9000
HCB4532KF-121T50
120±25%
100
0.02
5000
HCB4532KF-131T30
130±25%
100
0.04
3000
HCB4532KF-151T50
150±25%
100
0.02
5000
HCB4532MF-681T40
680±25%
100
0.03
4000
HCB4532MF-132T30
1300±25%
100
0.06
3000
www.tai-tech.com.tw
TAI-TECH
KBM01-230200181 P5.
5. Reliability and Test Condition
Item
Series No.
Performance
FCB
FCM
HCB
Test Condition
GHB
FCA
-55~+125℃
-55~+125℃
(on board)
Transportation
Storage Temperature
--For long storage conditions, please see the
Application Notice
Agilent4291
Agilent E4991
Impedance (Z)
Agilent4287
Refer to standard electrical characteristics list
Agilent16192
DC Resistance
Agilent 4338
Rated Current
DC Power Supply
Over Rated Current requirements, there will be
some risk
Temperature Rise Test
Rated Current < 1A ΔT 20℃Max
Rated Current ≧ 1A ΔT 40℃Max
Life test
Appearance: no damage.
Impedance: within±15%of initial value.
RDC:within ±15% of initial value and shall not exceed the specification value
Load Humidity
Thermal shock
Vibration
Bending
1. Applied the allowed DC current.
2. Temperature measured by digital surface
thermometer.
Preconditioning: Run through reflow for 3
times.( IPC/JEDEC J-STD-020E Classification
Reflow Profiles)
Temperature: 125±2℃
Applied current: rated current.
Duration: 1000±12hrs.
Measured at room temperature after placing
for 24±2 hrs.
Reflow Profiles)
Humidity: 85±2%R.H.
Temperature: 85±2℃.
Duration:1000hrsMin.Bead:with100%ratedcurr
ent , Inductance: with 10% rated current
for 24±2 hrs..
Reflow Profiles)
Condition for 1 cycle
Step1: -55±2℃
30±5 min.
Step2: +125±2℃
≦0.5min
Step3: +125±2℃
30±5min.
Number of cycles: 500
for 24±2 hrs.
Appearance:No damage.
Impedance:within±15% of initial value
Reflow Profiles)
Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz
for 20 minutes
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles
each of 3 orientations)。
Impedance:within±10% of initial value
Shall be mounted on a FR4 substrate of the
following dimensions:
>=0805inch(2012mm):40x100x1.2mm
=0805inch(2012mm):1.2mm
0805inch(2012mm):1kg
很抱歉,暂时无法提供与“HCB 1005KF-221T15”相匹配的价格&库存,您可以联系我们找货
