WCM 4532F2SF-142T20-HI
    TAI-TECH(台庆)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 1.5A DCR
WCM 4532F2SF-142T20-HI 数据手册
TAI-TECH P2 Wire Wound Type Common Mode Filter WCM1210F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent Halogen noise suppression performance. 2. WCM1210F2SF series realizes small size and low profile. 1.2x1.0x0.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension E C A Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 1210F2SF 1.2±0.2 1.0±0.2 0.9 max. 0.35±0.1 0.35±0.1 0.03 min. D D B 3. Part Numbering WCM 1210 A B F 2 S F C D E F - 900 T 02 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance 900=90Ω H: Packaging I: Rated Current T=Taping and Reel 02=250mA 4. Specification TAI-TECH Part Number DC Common mode Test Frequency Resistance Impedance (Ω) (MHz) (Ω) max. Rated Current Rated Volt. Withstand IR Volt. (Vdc) (Ω) min. (mA)max. (Vdc) max. max. WCM1210F2SF-600T02 60±25% 100 0.30 250 50 125 10M WCM1210F2SF-900T02 90±25% 100 0.30 250 50 125 10M WCM1210F2SF-121T02 120±25% 100 0.35 250 50 125 10M WCM1210F2SF-161T01 160±25% 100 0.43 160 50 125 10M WCM1210F2SF-201T01 200±25% 100 0.80 120 50 125 10M www.tai-tech.com.tw TAI-TECH WCM1210F2SF-600T02 1000 Common Mode 100 10 Normal Mode 1 WCM1210F2SF-900T02 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P3 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM1210F2SF-121T02 Common Mode 100 10 Normal Mode 1 0.1 10000 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 FREQUENCY(MHz) Common Mode 100 10 Normal Mode 1 0.1 1 10 100 10 100 FREQUENCY(MHz) WCM1210F2SF-201T01 1000 IMPEDANCE(Ohm) 1000 WCM1210F2SF-161T01 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P4 Wire Wound Type Common Mode Filter WCM1608F2SNF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise suppression performance. Halogen 2. WCM1608F2SNF series realizes small size and low profile. 1.6x0.8x1.1 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) Halogen-free 2. Dimension Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 1608F2SNF 1.60±0.15 0.85±0.15 1.10±0.15 0.30Typ. 0.30Typ. 0.03 min. 3. Part Numbering WCM 1608 A B F 2 SN F C D E F - 900 T 05 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance 900=90Ω H: Packaging T=Taping and Reel I: Rated Current 05=550mA 4. Specification TAI-TECH Part Number DC Common mode Test Frequency Resistance Impedance (Ω) (MHz) (Ω) max. Rated Current Rated Volt. Withstand IR Volt. (Vdc) (Ω) min. (mA)max. (Vdc) max. max. WCM1608F2SNF-220T05 22±25% 100 0.080 500 50 125 10M WCM1608F2SNF-450T05 45±25% 100 0.110 500 50 125 10M WCM1608F2SNF-900T05 90±25% 100 0.145 550 50 125 10M WCM1608F2SNF-121T05 120±25% 100 0.175 500 50 125 10M WCM1608F2SNF-181T05 180±25% 100 0.210 500 50 125 10M WCM1608F2SNF-251T04 250±25% 100 0.280 400 50 125 10M www.tai-tech.com.tw TAI-TECH WCM1608F2SNF-220T05 Common Mode 10 Normal Mode 1 WCM1608F2SNF-450T05 1000 IMPEDANCE(Ohm) 100 IMPEDANCE(Ohm) P5 100 Common Mode 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM1608F2SNF-900T05 Common Mode 100 10 Normal Mode 1 10000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM1608F2SNF-181T05 1000 IMPEDANCE(Ohm) Common Mode 10 Normal Mode 1 0.1 1 10 100 1000 10000 WCM1608F2SNF-251T04 1000 100 100 FREQUENCY(MHz) FREQUENCY(MHz) IMPEDANCE(Ohm) 1000 WCM1608F2SNF-121T05 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 1000 10000 Common Mode 100 10 Normal Mode 1 0.1 1 FREQUENCY(MHz) 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P6 Wire Wound Type Common Mode Filter WCM2012F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature -40~+125℃ (Including self - temperature rise) 2. Dimension A A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 2012F2SF 2.0±0.2 1.2±0.2 1.2±0.2 0.50±0.1 0.51±0.1 0.15±0.1 E C Series D D B 3. Part Numbering WCM 2012 A B F 2 S F C D E F - 900 T 04 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance 900=90Ω H: Packaging I: Rated Current T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Test Frequency Impedance Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand Rated Volt. IR Volt. (Vdc) (Ω) min. (Vdc)max. max. WCM2012F2SF-670T04 67±25% 100 0.25 400 50 125 10M WCM2012F2SF-900T04 90±25% 100 0.30 400 50 125 10M WCM2012F2SF-121T04 120±25% 100 0.30 400 50 125 10M WCM2012F2SF-161T03 160±25% 100 0.35 350 50 125 10M WCM2012F2SF-181T03 180±25% 100 0.35 350 50 125 10M WCM2012F2SF-201T03 200±25% 100 0.40 300 50 125 10M WCM2012F2SF-221T03 220±25% 100 0.40 300 50 125 10M WCM2012F2SF-261T03 260±25% 100 0.40 300 50 125 10M WCM2012F2SF-361T03 360±25% 100 0.50 300 50 125 10M www.tai-tech.com.tw TAI-TECH P7 Typical Impedance v.s. Frequency Curve WCM2012F2SF-670T04 Common Mode 100 10 Normal Mode 1 WCM2012F2SF-900T04 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM2012F2SF-121T04 Common Mode 100 10 Normal Mode 1 0.1 Common Mode 100 10 Normal Mode 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 1000 10000 WCM2012F2SF-201T03 1000 IMPEDANCE(Ohm) 1000 Common Mode 100 100 FREQUENCY(MHz) WCM2012F2SF-181T03 10000 IMPEDANCE(Ohm) 10000 0.1 1 10 Normal Mode 1 0.1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) IMPEDANCE(Ohm) 10 Normal Mode 1 1000 10000 WCM2012F2SF-261T03 1000 Common Mode 100 100 FREQUENCY(MHz) WCM2012F2SF-221T03 1000 IMPEDANCE(Ohm) 1000 WCM2012F2SF-161T03 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P8 WCM2012F2SF-361T03 10000 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 FREQUENCY(MHz) 3. Part Numbering WCM 2012 A B F 2 S F C D E F - 801 - N G H A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance H: Category Code 801=800Ω N=DR-N45 材&SP-N45 材 4. Specification TAI-TECH Part Number WCM2012F2SF-801-N DC Common mode Test Frequency Impedance Resistance (MHz) (Ω) (Ω) max. 800±25% 100 Rated Current (mA)max. 0.88 Withstand Rated Volt. IR Volt. (Vdc) (Ω) min. (Vdc)max. max. 300 50 Typical Impedance v.s. Frequency Curve WCM2012F2SF-801-N 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 1000 100 10 Normal Mode 1 1 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 125 10M TAI-TECH P9 Wire Wound Type Common Mode Filter WCM3216F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM3216F2SF series realizes small size and low profile. 3.2x1.6x2.0 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension C A Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3216F2SF 3.2±0.2 1.6±0.2 2.0±0.2 0.5±0.1 0.5±0.1 0.15±0.1 E Units: mm D D B 3. Part Numbering WCM 3216 A B A: Series B: Dimension C: Material D: Number of Lines E: Type F: Lead free type G: Impedance H: Packaging I: Rated Current F 2 S F C D E F - 900 T 04 G H I Ferrite Core 2=2 lines S=Shielded , N=Unshielded 900=90Ω T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand IR Rated Volt. (Vdc)max. Volt. (Vdc) (Ω) min. Max. WCM3216F2SF-900T04 90±25% 100 0.30 400 50 125 10M WCM3216F2SF-121T03 120±25% 100 0.30 350 50 125 10M WCM3216F2SF-161T03 160±25% 100 0.40 350 50 125 10M WCM3216F2SF-221T03 220±25% 100 0.45 300 50 125 10M WCM3216F2SF-261T03 260±25% 100 0.50 300 50 125 10M WCM3216F2SF-361T03 360±25% 100 0.60 300 50 125 10M WCM3216F2SF-601T03 600±25% 100 0.80 300 50 125 10M WCM3216F2SF-102T02 1000±25% 100 1.00 200 50 125 10M WCM3216F2SF-222T02 2200±25% 100 1.20 200 50 125 10M www.tai-tech.com.tw TAI-TECH P10 Typical Impedance v.s. Frequency Curve WCM3216F2SF-900T04 Common Mode 100 10 Normal Mode 1 WCM3216F2SF-121T03 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SF-161T03 Common Mode 100 Normal Mode Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SF-261T03 Common Mode 100 1000 10000 WCM3216F2SF-361T03 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) Normal Mode 10 1 Common Mode 100 Normal Mode 10 1 0.1 0.1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 1000 10000 WCM3216F2SF-102T02 10000 IMPEDANCE(Ohm) Common Mode 1000 100 FREQUENCY(MHz) WCM3216F2SF-601T03 10000 IMPEDANCE(Ohm) 10000 1000 10 1 1000 WCM3216F2SF-221T03 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 10 Normal Mode 1 Common Mode 1000 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P11 WCM3216F2SF-222T02 IMPEDANCE(Ohm) 10000 Common Mode 1000 100 10 Normal Mode 1 1 10 100 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw TAI-TECH P12 Wire Wound Type Common Mode Filter WCM3225F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM3225F2SF series realizes small size and low profile. 3.2x2.5x2.2 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension C A Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3225F2SF 3.2±0.2 2.5±0.2 2.2±0.2 0.8±0.1 0.9±0.1 0.15±0.1 E Units: mm D D B 3. Part Numbering WCM 3225 A B F 2 S F C D E F - 102 T 04 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free type G: Impedance 102=1000Ω H: Packaging T=Taping and Reel I: Rated Current 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Withstand IR Rated Volt. Impedance Test Frequency Resistance Rated Current (Vdc)max. Volt. (Vdc) (Ω) min. (MHz) (mA)max. (Ω) max. (Ω) max. WCM3225F2SF-900T10 90±25% 100 0.050 1000 50 125 10M WCM3225F2SF-261T10 260±25% 100 0.15 1000 50 125 10M WCM3225F2SF-601T10 600±25% 100 0.20 1000 50 125 10M WCM3225F2SF-102T04 1000±25% 100 0.30 400 50 125 10M www.tai-tech.com.tw TAI-TECH WCM3225F2SF-900T10 1000 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 WCM3225F2SF-261T10 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P13 Common Mode 100 10 Normal Mode 1 0.1 10000 1 10 FREQUENCY(MHz) WCM3225F2SF-601T10 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 Common Mode 1000 100 10 Normal Mode 1 1000 WCM3225F2SF-102T04 10000 Common Mode 1000 100 FREQUENCY(MHz) 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P14 Wire Wound Type Common Mode Filter WCM4532F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM4532F2SF series realizes small size and low profile. 4.5x3.2x2.8 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension A A(mm) B(mm) C(mm) D1(mm) D2(mm) 4532F2SF 4.5±0.2 3.2±0.2 2.8±0.2 1.0±0.1 1.2±0.1 C Series B D D Units: mm D D 3. Part Numbering WCM 4532 A B F 2 S F C D E F - 900 T 30 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Lead free G: Impedance 900=90Ω H: Packaging T=Taping and Reel I: Rated Current 30=3000mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA) max. IR Rated Volt. Withstand Volt. (Vdc) (Ω) min. (Vdc) max. max. 80±25% 100 0.05 3000 50 125 10M WCM4532F2SF-900T30 90±25% 100 0.05 3000 50 125 10M WCM4532F2SF-121T30 120±25% 100 0.05 3000 50 125 10M WCM4532F2SF-201T15 200±25% 100 0.10 1500 50 125 10M WCM4532F2SF-601T15 600±25% 100 0.24 1500 50 125 10M WCM4532F2SF-801T10 800±25% 100 0.24 1000 50 125 10M WCM4532F2SF-800T30 www.tai-tech.com.tw TAI-TECH WCM4532F2SF-800T30 1000 IMPEDANCE(Ohm) 10 Normal Mode 1 WCM4532F2SF-900T30 1000 Common Mode 100 IMPEDANCE(Ohm) P15 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM4532F2SF-121T30 Common Mode 100 10 Normal Mode 1 10000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM4532F2SF-601T15 10000 10000 Common Mode IMPEDANCE(Ohm) 1000 100 10 Normal Mode 1 1000 WCM4532F2SF-801T10 10000 Common Mode 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) IMPEDANCE(Ohm) 1000 WCM4532F2SF-201T15 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P16 Reliability and Test Condition (WCM1210, 1608, 2012, 3216, 3225, 4532) Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) DCR Keysight E4991B + Keysight 16197A Refer to standard electrical characteristics list. Agilent-34420A Agilent-4338B I.R. Chroma 19073 Temperature Rise Test 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ΔT 40℃Max Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature:125±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity:85±3% R.H, Load Humidity Temperature:85℃±2℃ Duration : 1000hrs Min. Bead : with 100% rated current , Inductance: with 10% rated current Measured at room temperature after placing for 24 hrs. Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:125±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24 hrs. Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw TAI-TECH P17 Item Performance Bending Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Shock Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg , =0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg , =0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
WCM 4532F2SF-142T20-HI 价格&库存
很抱歉,暂时无法提供与“WCM 4532F2SF-142T20-HI”相匹配的价格&库存,您可以联系我们找货
