CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
UPC
Series
Super low ESR at a high frequency range
High ripple current capability
2,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
6.3 ~ 22Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
(at 25℃ and 120Hz)
ESR
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C (Part code “F3” for 3000 “F5” for 5000 hours)
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆ DIMENSIONS (mm)
◆ Lead
ФD
Фd
PART NUMBER SYSTEM
◆ Marking
5
5.5
6.3
0.45 0.45 0.45 0.45
8
9
10
8
10
0.6
0.6
0.6
0.6
0.6
0.6
8
11
12
11
9
12
L
8
α
1
1
1
1
1
1.5
1.5
1.5
1.5
1.5
F
2
2.5
2.5
2.5
2.5
2.5
2.5
3.5
5.0
5.0
UPC
Series
Standard Ratings
Rated
Voltage
(Vdc)
6.3(0J)
6.8(6K)
7.5(7H)
10(1A)
12(1B)
16(1C)
Rated
Capacitance
(μF)
Case Size
ΦD×L
(mm)
ESR
100~300KHz
(mΩmax)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tanδ
max
Leakage
Current
(μA max)
220
5.5×8
12
3,600
0.12
300
UPC0J221MNN5508
330
5.5×8
12
4,050
0.12
500
UPC0J331MNN5508
390
5.5×8
11
3,700
0.12
491
UPC0J391MNN5508
470
5.5×8
12
4,200
0.12
592
UPC0J471MNN5508
560
6.3×8
8
4,700
0.12
706
UPC0J561MNN6308
680
6.3×8
10
4,300
0.12
857
UPC0J681MNN6308
Part Number
820
6.3×8
8
4,700
0.12
1033
UPC0J821MNN6308
1500
8×11
9
5650
0.12
1890
UPC0J152MNN0811F5U
390
5×8
11
3,100
0.12
530
UPC6K391MNN0508
470
5×8
11
3,700
0.12
639
UPC6K471MNN0508
560
6.3×8
8
4,700
0.12
761
UPC6K561MNN6308
680
6.3×8
8
4,700
0.12
925
UPC6K681MNN6308
820
6.3×8
8
4,700
0.12
1115
UPC6K821MNN6308
1000
6.3×12
8
5,000
0.12
1360
UPC6K102MNN6312
390
5.5×8
11
3,100
0.12
175
UPC7H391MNN5508
470
5.5×8
10
3,700
0.12
705
UPC7H471MNN5508
470
6.3×8
10
4700
0.1
705
UPC7H471MNN6308F5
500
5.5×9
10
3100
0.12
750
UPC7H501MNN5509
560
6.3×8
8
4,700
0.12
840
UPC7H561MNN6308
1000
8×11
10
6100
0.12
2000
UPC1A102MNN0811U
330
5.5×9
12
2700
0.12
300
UPC1B331VNN5509V
330
6.3×8
8
4,700
0.12
792
UPC1B331MNN6308
470
6.3×11
8
4,700
0.12
1128
UPC1B471MP26311
560
6.3×11
12
4,700
0.12
1344
UPC1B561MNN6311
820
6.3×12
14
3300
0.12
1968
UPC1B821MNN6312V
180
5.5×10
0.12
576
UPC1C181MNN5510
220
5.5×10
0.12
704
UPC1C221MNN5510
270
5.5×10
0.12
864
UPC1C271MNN5510
330
6.3×11
15
3800
0.12
1056
UPC1C331MNN6311
330
6.3×11
15
3800
0.12
1056
UPC1C331MNN6311F3
680
8×11
14
4900
0.12
2176
UPC1C681MNN0811U
680
8×11
14
4900
0.12
2176
UPC1C681MNN0811F3U
820
10×9
11
5600
0.12
2624
UPC1C821MNN1009U
270
6.3×12
16
3800
0.12
1080
UPC1D271MNN6312
20(1D)
330
6.3×11
16
3800
0.12
1320
UPC1D331MNN6311
330
6.3×12
16
3800
0.12
1320
UPC1D331MNN6312 (U)
22(1P)
330
6.3×12
18
3800
0.12
1452
UPC1P331MNN6312
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6316
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×16
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F5
L
T
Description
High Rated ripple current
Endurance 5000 hrous
Low Leakage Current
Terminal strength
Code
U
E
X
S
Description
Convex Rubber
Low ESR
Pitch 2.5mm
Limit high
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
S
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“UPC6K391MNN0508”相匹配的价格&库存,您可以联系我们找货
