UPC6K391MPZ0508
UPC6K391MPZ0508
    CHINSAN(金山)
    径向,Can
    390 µF 6.8 V 铝聚合物电容器 径向,Can 11 毫欧 105°C 时为 2000 小时
UPC6K391MPZ0508 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPC Series  Super low ESR at a high frequency range  High ripple current capability  2,000 hours at 105℃  SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 6.3 ~ 22Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% (at 25℃ and 120Hz) ESR See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C (Part code “F3” for 3000 “F5” for 5000 hours) Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆ DIMENSIONS (mm) ◆ Lead ФD Фd  PART NUMBER SYSTEM ◆ Marking 5 5.5 6.3 0.45 0.45 0.45 0.45 8 9 10 8 10 0.6 0.6 0.6 0.6 0.6 0.6 8 11 12 11 9 12 L 8 α 1 1 1 1 1 1.5 1.5 1.5 1.5 1.5 F 2 2.5 2.5 2.5 2.5 2.5 2.5 3.5 5.0 5.0 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor UPC ◆ Series Standard Ratings Rated Voltage (Vdc) 6.3(0J) 6.8(6K) 7.5(7H) 10(1A) 12(1B) 16(1C) Rated Capacitance (μF) Case Size ΦD×L (mm) ESR 100~300KHz (mΩmax) Rated Ripple Current 105℃,100KHz (mArms max) Tanδ max Leakage Current (μA max) 220 5.5×8 12 3,600 0.12 300 UPC0J221MNN5508 330 5.5×8 12 4,050 0.12 500 UPC0J331MNN5508 390 5.5×8 11 3,700 0.12 491 UPC0J391MNN5508 470 5.5×8 12 4,200 0.12 592 UPC0J471MNN5508 560 6.3×8 8 4,700 0.12 706 UPC0J561MNN6308 680 6.3×8 10 4,300 0.12 857 UPC0J681MNN6308 Part Number 820 6.3×8 8 4,700 0.12 1033 UPC0J821MNN6308 1500 8×11 9 5650 0.12 1890 UPC0J152MNN0811F5U 390 5×8 11 3,100 0.12 530 UPC6K391MNN0508 470 5×8 11 3,700 0.12 639 UPC6K471MNN0508 560 6.3×8 8 4,700 0.12 761 UPC6K561MNN6308 680 6.3×8 8 4,700 0.12 925 UPC6K681MNN6308 820 6.3×8 8 4,700 0.12 1115 UPC6K821MNN6308 1000 6.3×12 8 5,000 0.12 1360 UPC6K102MNN6312 390 5.5×8 11 3,100 0.12 175 UPC7H391MNN5508 470 5.5×8 10 3,700 0.12 705 UPC7H471MNN5508 470 6.3×8 10 4700 0.1 705 UPC7H471MNN6308F5 500 5.5×9 10 3100 0.12 750 UPC7H501MNN5509 560 6.3×8 8 4,700 0.12 840 UPC7H561MNN6308 1000 8×11 10 6100 0.12 2000 UPC1A102MNN0811U 330 5.5×9 12 2700 0.12 300 UPC1B331VNN5509V 330 6.3×8 8 4,700 0.12 792 UPC1B331MNN6308 470 6.3×11 8 4,700 0.12 1128 UPC1B471MP26311 560 6.3×11 12 4,700 0.12 1344 UPC1B561MNN6311 820 6.3×12 14 3300 0.12 1968 UPC1B821MNN6312V 180 5.5×10 20 3,100 0.12 576 UPC1C181MNN5510 220 5.5×10 20 3,100 0.12 704 UPC1C221MNN5510 270 5.5×10 20 3100 0.12 864 UPC1C271MNN5510 330 6.3×11 15 3800 0.12 1056 UPC1C331MNN6311 330 6.3×11 15 3800 0.12 1056 UPC1C331MNN6311F3 680 8×11 14 4900 0.12 2176 UPC1C681MNN0811U 680 8×11 14 4900 0.12 2176 UPC1C681MNN0811F3U 820 10×9 11 5600 0.12 2624 UPC1C821MNN1009U 270 6.3×12 16 3800 0.12 1080 UPC1D271MNN6312 20(1D) 330 6.3×11 16 3800 0.12 1320 UPC1D331MNN6311 330 6.3×12 16 3800 0.12 1320 UPC1D331MNN6312 (U) 22(1P) 330 6.3×12 18 3800 0.12 1452 UPC1P331MNN6312 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6316 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×16 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 5057 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F5 L T Description High Rated ripple current Endurance 5000 hrous Low Leakage Current Terminal strength Code U E X S Description Convex Rubber Low ESR Pitch 2.5mm Limit high CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V S RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE  LEAD FORMING TYPE Dimensions (Unit: mm) Part Number ΦD F ι 3 4 U 7 D X R B E G 2 M T 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 Cut 2 ---- 6.3 2.5 ---- 8 3.5 ---- 10 5 ---- ±0.2 ±0.3 D ±0.5 5 (Part number for lead length and pitch for taping) F Type L C L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  TAPING Figure 1 Ф8 Фd ±0.05 0.45 0.45/0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 3.85 3.85 3.85 P2 ±1.0 6.35 6.35 6.35 5 5 5 PS P5 0.8 -0.2 H ±0.5 H0 ±0.5 17.5 18.5 PS P5 17.5 16 18.5 PS P5 17.5 16 18.5 16 W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45/0.6 0.6 0.6 P ±0.1 12.7 12.7 12.7 P0 ±0.2 12.7 12.7 12.7 P1 ±0.5 5.1 4.6 3.85 P2 ±1.0 6.35 6.35 6.35 2.5 3.5 5 F Figure 3 Ф 6.3 Tolerance F Figure 2 Ф5 Symbol +0.8 -0.2 Ф 6.3 P2 H ±0.5 118.5 H0 ±0.5 - Ф8 P3 18.5 H3 20 - Ф 10 P7 17.5 P5 18.5 H5 20 - W ±0.5 18 18 18 W0 Minimum 12.5 12.5 12.5 D0 ±0.2 4 4 4 t ±0.2 0.7 0.7 0.7 Symbol Tolerance Фd ±0.05 0.45 P ±0.1 12.7 P0 ±0.2 12.7 P1 ±0.5 5.35 P2 ±1.0 6.35 F +0.8 -0.2 Ф5 PZ 2.0 H ±0.5 18.5 H0 ±0.5 - W ±0.5 18 W0 Minimum 12.5 D0 ±0.2 4 t ±0.2 0.7 J5 21
UPC6K391MPZ0508 价格&库存
很抱歉,暂时无法提供与“UPC6K391MPZ0508”相匹配的价格&库存,您可以联系我们找货
