VSE1E470MCB6357
VSE1E470MCB6357
    CHINSAN(金山)
    Radial, Can - SMD
    CONDUCTIVE POLYMER SOLID CAPACIT
VSE1E470MCB6357 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS 7 CAPACITOR Aluminum Solid Capacitor VSE      Series 2021 Change series code SE → VSE Super low ESR at a high frequency range High ripple current capability 5,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 35Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% ESR (at 25℃ and 120Hz) See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 105°C Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS ◆Marking Code  PART NUMBER SYSTEM Case Size ФD L α A B C W P 5.7 0.3 6.6 6.6 7.3 0.5~0.8 2.1 6.3 9 0.5 6.6 6.6 7.3 0.7~1.1 2.1 8 6.7 0.3 8.3 8.3 9 0.7~1.1 3.2 8.3 6357 6.3×5.7 6.3 6309 6.3×9 0867 8×6.7 08C7 8×12.7 8 12.7 0.5 8.3 9 07~1.1 3.2 10C4 10×12.4 10 12.4 0.5 10.3 10.3 11 0.7~1.1 4.6 ≦6.3Ф ≧8Ф CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor VSE ◆ Series Standard Rating Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) 25(1E) 35(1V) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 560 6.3×5.7 16 3500 0.10 300 VSE0E561MCB6357 560 6.3×5.7 10 3500 0.10 500 VSE0E561MCB6357E Part Number 560 8×6.7 22 3220 0.10 448 VSE0G561MCB0867 220 6.3×5.7 15 3160 0.10 300 VSE0J221MCB6357 220 6.3×5.7 10 3900 0.10 500 VSE0J221MCB6357E 330 6.3×5.7 15 3160 0.10 416 VSE0J331MCB6357 390 8×6.7 22 3220 0.10 491 VSE0J391MCB0867 120 6.3×5.7 22 2600 0.10 300 VSE1A121MCB6357 270 8×6.7 22 3220 0.10 540 VSE1A271MCB0867 68 6.3×5.7 40 2450 0.10 544 VSE1C680MCB6343 100 6.3×5.7 24 2490 0.10 320 VSE1C101MCB6357 270 6.3×9 9 5800 0.1 864 VSE1C271MCB6309ER 270 8×9.7 16 4070 0.10 864 VSE1C271MCB0897 270 8×12.7 11 4070 0.10 864 VSE1C271MCB08C7 560 8×12.7 16 3800 0.10 1792 VSE1C561MCB08C7 560 10×12.4 16 3800 0.10 1792 VSE1C561MCB10C4 47 6.3×5.7 30 2500 0.10 588 VSE1E470MCB6357 100 8×9.7 24 3300 0.10 500 VSE1E101MCB0897 120 10×12.4 32 2400 0.10 840 VSE1V121MCB10C4 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 0557 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor SMD CARRIER TAPE DUMENTIONS Item Dimension Code 5057 (5x5.7) 6343 (6.3x4.3) 6357 (6.3x5.7) 6377 (6.3x7.7) 6309 (6.3x9) 0867 (8x6.7) 0897 (8x9.7) 08C7 (8x12.7) 1077 (10x7.7) 10C4 (10x12.4)  W ±0.3 16 16 16 16 16 24 24 24 24 24 A ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 B ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 F ±0.1 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 P ±0.1 12 12 12 12 12 12 16 16 16 16 T ±0.2 6.2 4.7 6.2 8.2 10.0 7.2 10.3 13.2 8.3 13.0 SMD REEL DIMENTIONS AND PACKING QUANTITY Case Code Quantity per reel Quantity per Box※ 5057 1200 12000 6343 1500 15000 6357 1200 12000 6377 1000 10000 6309 800 8000 0867 1000 7000 0897 500 3500 08C7 400 2800 1077 500 3500 10C4 400 2800 ※ This may change according to a delivered quantity W 17.5 25.3
VSE1E470MCB6357 价格&库存
很抱歉,暂时无法提供与“VSE1E470MCB6357”相匹配的价格&库存,您可以联系我们找货
