VSG1E270MCB6357L
VSG1E270MCB6357L
    CHINSAN(金山)
    径向,Can-SMD
    27 µF 25 V 铝聚合物电容器 径向,Can - SMD 40 毫欧 105°C 时为 2000 小时
VSG1E270MCB6357L 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor VSG      Series 2021 Change series code SG → VSG Low ESR at a high frequency range High ripple current capability 2,000 hours at 105°C SPECIFICATIONS Item Performance Characteristics Category Temperature Range -55 ~ +105℃ Working Voltage Range 2.5 ~ 50Vdc Surge Voltage Rated Voltage x1.15 Capacitance Tolerance M: ±20% (at 25℃ and 120Hz) ESR See the standard ratings table (at 25℃, 100~300KHz) Dissipation Factor (Tanδ) See the standard ratings table (at 25℃, 120Hz) Leakage Current ※1 See the standard ratings table (Impress the rated voltage for 2 minutes) Low Temperature Characteristics Impedance Ratio Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C (Part code “F5” for 5000 hours) Endurance Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 60℃ 90 to 95% RH Damp Heat (Steady State) Capacitance change ≦ ±20% of the initial value ESR ≦ 150% of the specified value Dissipation factor(tanδ) ≦ 150% of the specified value Leakage current ≦ specified value ※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C ※2 ESR should be measured at both of the terminal ends closest to the capacitor body ◆DIMENSIONS (mm) ◆Marking L α A B C W P 0557 5×5.7 5 5.7 0.3 5.3 5.3 5.9 0.5~0.8 1.4 6357 6.3×5.7 6.3 5.7 0.3 6.6 6.6 7.3 0.5~0.8 2.1 6309 6.3×9 6.3 9.0 1 6.6 6.6 7.3 0.7~1.1 2.1 0867 8×6.7 8 6.7 0.3 8.3 8.3 9 0.7~1.1 3.2 8.3 Code  PART NUMBER SYSTEM Case Size ФD 0897 8×9.7 8 9.7 0.5 8.3 9 0.7~1.1 3.2 1077 10×7.7 10 7.7 0.5 10.3 10.3 11 0.7~1.1 4.6 10C4 10×12.4 10 12.4 0.5 10.3 10.3 11 0.7~1.1 4.6 ≦6.3Ф ≧8Ф CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor VSG ◆ Series Standard Ratings Rated Voltage (Vdc) 2.5(0E) 4(0G) 6.3(0J) 10(1A) 16(1C) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 220 6.3×5.7 25 2500 0.12 300 VSG0E221MCB6357 560 6.3×5.7 25 2500 0.12 420 VSG0E561MCB6357 560 6.3×5.7 16 3500 0.12 420 VSG0E561MCB6357E Part Number 680 8×6.7 20 3370 0.12 510 VSG0E681MCB0867 1500 10×12.4 12 5400 0.12 1125 VSG0E152MCB10C4 2700 10×12.4 12 5070 0.12 2025 VSG0E272MCB10C4 100 6.3×5.7 35 2200 0.12 300 VSG0G101MCB6357 150 5×5.7 30 1490 0.12 300 VSG0G151MCB0557 330 6.3×5.7 27 2700 0.12 400 VSG0G331MCB6357 680 10×7.7 20 4130 0.12 816 VSG0G681MCB1077 1200 10×12.4 12 5500 0.12 1440 VSG0G122MCB10C4 82 6.3×5.7 35 2200 0.12 300 VSG0J820MCB6357 100 5×5.7 35 1380 0.12 300 VSG0J101MCB0557 220 6.3×5.7 27 2320 0.12 416 VSG0J221MCB6357 330 10×7.7 22 3600 0.12 624 VSG0J331MCB1077 390 8×6.7 18 3220 0.12 737 VSG0J391MCB0867 820 10×12.4 12 5500 0.12 1550 VSG0J821MCB10C4 47 6.3×5.7 40 2100 0.12 300 VSG1A470MCB6357 56 6.3×5.7 40 2100 0.12 300 VSG1A560MCB6357 120 8×6.7 30 2600 0.12 360 VSG1A121MCB0867 270 10×7.7 25 3500 0.12 810 VSG1A271MCB1077 330 10×7.7 25 3770 0.12 990 VSG1A331MCB1077 560 10×12.4 13 5300 0.12 1680 VSG1A561MCB10C4 33 6.3×5.7 37 2050 0.12 300 VSG1C330MCB6357 39 6.3×5.7 45 2000 0.12 300 VSG1C390MCB6357 82 8×6.7 40 2300 0.12 394 VSG1C820MCB0867 100 6.3×5.7 24 2490 0.12 300 VSG1C101MCB6357 100 10×7.7 30 3200 0.12 480 VSG1C101MCB1077 180 6.3×5.7 22 3300 0.12 576 VSG1C181MCB6357 180 10×7.7 29 3200 0.12 864 VSG1C181MCB1077 270 6.3×9 22 3300 0.12 864 VSG1C271MCB6309 270 8×6.7 22 3300 0.12 864 VSG1C271MCB0867 270 8×6.7 22 3300 0.12 864 VSG1C271MCB0867F5 330 8×9.7 16 3890 0.12 1584 VSG1C331MCB0897 330 10×12.4 16 4800 0.12 1584 VSG1C331MCB10C4 560 10×12.4 16 4720 0.12 1792 VSG1C561MCB10C4 1000 10×12.4 18 4300 0.12 3200 VSG1C102MCB10C4 CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor Rated Voltage (Vdc) 25(1E) 35(1V) 50(1H) Rated Capacitance (μF) Case Size ФD×L (mm) ESR 100~300KHz (mΩ max) Rated Ripple Current 105℃,100KHz (mArms max) Tan δ max Leakage Current (μA max) 27 6.3×5.7 40 2100 0.12 135 47 6.3×5.7 30 2800 0.12 235 VSG1E470MCB6357 47 10×12.4 28 3800 0.12 410 VSG1V470MCB10C4 100 10×12.4 29 2600 0.12 700 VSG1V101MCB10C4 220 10×12.4 28 2600 0.12 1540 VSG1V221MCB10C4 100 10×12.4 27 3600 0.12 1000 VSG1H101MCB10C4 Part Number VSG1E270MCB6357L CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor PA RT N U M B E R S Y S T E M  RADIAL LEAD TYPE Series Rated Voltage Capacitance Tolerance Lead Forming Type Lead Length Case Dimension Special Request (1) (2) (3) (4) (5) (6) (7) (8) (1) Series Series DIP UPS UPR UUL UPE SMD VSG VSP VSU VSE URP URH UGP UGS UGV UPC (2) Rated Voltage Code 0E 0J 6K 7H 1A 1B AG 1C 1D 1P 1E 1F 1V 1H 1J 2A WV 2.5 6.3 6.8 7.5 10 12 14 16 20 22 25 30 35 50 63 100 (3) Capacitance Code 6R8 μF 6.8 100 10 180 560 101 181 561 102 182 18 56 100 180 560 1000 1800 (4) Capacitance Tolerance Code J Q R K V M H % ±5 +30 / -10 +20 / -0 ± 10 +20 / -10 ± 20 +20 / -5 (5) Lead Type Code C P Description Cutting Taping Drawing Fig 1 Fig 2 (6) Lead Length (Cut / Formed lead) Code 3 4 U 7 D X R B E G 2 M T N Length 3.5 4.5 5.5 7 4 2.3 2.5 2.8 3.1 3.3 2.5 3.5 3.8 +20mm min Tolerance ±0.5 ±0.2 ±0.3 -15mm min Taping Code Code Z 2 3 7 5 S Lead Pitch:+0.8/-0.2 2.0 2.5 3.5 3.5 5.0 5.0 (7) Case Dimension DIP Code 0508 6305 6308 6311 0807 0808 0811 0816 0820 1012 1016 1020 10×16 10×20 Size 5×8 6.3×5 6.3×8 6.3×11 8×7 8×8 8×11 8×16 8×20 10×12 SMD Code 0557 6343 6357 6377 6309 0867 0897 08C7 1077 10C4 Size 5×5.7 6.3×4.3 6.3×5.7 6.3×7.7 6.3×9 8×6.7 8×9.7 8×12.7 10×7.7 10×12.4 (8) Special Request Code R F L D Description High Rated ripple current Endurance Low Leakage Current Low Dissipation Factor Code U E --- --- Description Convex Rubber Low ESR --- --- CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor  MARKING AND DATE CODE Trade Mark "CS" Chinsan Solid Capacitor, Show on Dimension ≧8 Ф Code (Date Code) (1)DAY (1) (2) (3) Code 1 2 3 4 5 1 1 0 Week The first week The second week The third week The fourth week The fifth week (2)Month Code 1 2 3 4 5 6 Month Jan Feb Mar Apr May Jun Code 7 8 9 X Y Z Month July Aug Sep Oct Nov Dec Code 9 0 1 2 3 4 Year 2019 2020 2021 2022 2023 2024 (3)Year Series (Print Code) Series UPS UPR UUL UPE URP URH UGP UGV UGS Ф 5~ Ф 6.3 -- R L E Ф 8~ Ф 10 UPS -- UL UPE RP -- H P V -- RH GP GV GS UPC VSG VSP C G UPC SG VSU VSE P U E SP SU SE CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS CAPACITOR Aluminum Solid Capacitor SMD CARRIER TAPE DUMENTIONS Item Dimension Code 5057 (5x5.7) 6343 (6.3x4.3) 6357 (6.3x5.7) 6377 (6.3x7.7) 6309 (6.3x9) 0867 (8x6.7) 0897 (8x9.7) 08C7 (8x12.7) 1077 (10x7.7) 10C4 (10x12.4)  W ±0.3 16 16 16 16 16 24 24 24 24 24 A ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 B ±0.2 5.6 7.0 7.0 7.0 7.0 8.7 8.7 8.7 10.7 10.7 F ±0.1 7.5 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 P ±0.1 12 12 12 12 12 12 16 16 16 16 T ±0.2 6.2 4.7 6.2 8.2 10.0 7.2 10.3 13.2 8.3 13.0 SMD REEL DIMENTIONS AND PACKING QUANTITY Case Code Quantity per reel Quantity per Box※ 5057 1200 12000 6343 1500 15000 6357 1200 12000 6377 1000 10000 6309 800 8000 0867 1000 7000 0897 500 3500 08C7 400 2800 1077 500 3500 10C4 400 2800 ※ This may change according to a delivered quantity W 17.5 25.3
VSG1E270MCB6357L 价格&库存
很抱歉,暂时无法提供与“VSG1E270MCB6357L”相匹配的价格&库存,您可以联系我们找货
