CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
VSP
Series
2021 Change series code SP → VSP
Super Low ESR at a high frequency range
High ripple current capability
2,000 hours at 105°C
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
2.5 ~ 25Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
ESR
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table.(Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 105°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
※1
※2
Capacitance change
ESR
Leakage current
≦ specified value
In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
ESR should be measured at both of the terminal ends closest to the capacitor body
◆DIMENSIONS
◆Marking
Case Size ФD
PART NUMBER SYSTEM
L
α
A
B
C
W
P
0557
5×5.7
5
5.7
0.3
5.3
5.3
5.9
0.5~0.8
1.4
6343
6.3×4.3
6.3
4.3
+0.4
6.6
-0.3
6.6
7.3
0.5~0.8
2.1
6357
6.3×5.7
6.3
5.7
0.3
6.6
6.6
7.3
0.5~0.8
2.1
0867
8×6.7
8
6.7
0.3
8.3
8.3
9
0.7~1.1
3.2
0897
8×9.7
8
9.7
0.5
8.3
8.3
9
0.7~1.1
3.2
1077
10×7.7
10
7.7
0.5 10.3 10.3
11
0.7~1.1
4.6
10C4
10×12.4
10
12.4 0.5 10.3 10.3
11
0.7~1.1
4.6
≦6.3Ф
≧8Ф
VSP
Series
Standard Ratings
Rated
Voltage
(Vdc)
2.5(0E)
4(0G)
6.3(0J)
10(1A)
16(1C)
25(1E)
Rated
Capacitance
(μF)
Case Size
ФD×L (mm)
ESR
100~300KHz
(mΩ max)
Rated Ripple Current
105℃,100KHz
(mArms max)
Tan δ
max
Leakage
Current
(μA max)
180
5×5.7
21
2670
0.12
300
VSP0E181MCB0557
330
5×5.7
15
3150
0.12
300
VSP0E331MCB0557
330
6.3×4.3
17
3500
0.12
413
VSP0E331MCB6343
330
6.3×4.3
12
3500
0.12
700
VSP0E331MCB6343E
390
6.3×5.7
15
3160
0.12
344
VSP0E391MCB6357
560
6.3×5.7
16
3600
0.12
420
VSP0E561MCB6357
560
6.3×5.7
10
3870
0.12
500
VSP0E561MCB6357E
680
8×6.7
13
4100
0.12
510
VSP0E681MCB0567
2700
10×12.4
12
5070
0.12
2025
VSP0E272MCB10C4
330
6.3×5.7
15
3160
0.12
396
VSP0G331MCB6357
1500
8×12.7
12
4700
0.12
1800
VSP0G152MCB08C7
100
5×5.7
24
2500
0.12
300
VSP0J101MCB0557
120
5×5.7
24
2500
0.12
300
VSP0J121MCB0557
220
5×5.7
12
3500
0.12
700
VSP0J221MCB0557
220
6.3×4.3
17
3160
0.12
693
VSP0J221MCB6343
220
6.3×4.3
18
3000
0.12
500
VSP0J221MCB6343L
220
6.3×5.7
15
3160
0.12
416
VSP0J221MCB6357
330
6.3×5.7
17
3600
0.12
624
VSP0J331MCB6357
470
8×12.7
15
3950
0.12
888
VSP0J471MCB08C7
560
6.3×9
10
4700
0.12
706
VSP0J561MCB6309
330
8×12.7
17
3950
0.12
990
VSP1A331MCB08C7
100
6.3×5.7
24
2490
0.12
320
VSP1C101MCB6357
180
8×9.7
16
3890
0.12
576
VSP1C181MCB0897
270
6.3×9
9
5300
0.12
864
VSP1C271MCB6309
270
8×9.7
16
3890
0.12
864
VSP1C271MCB0897
47
6.3×5.7
30
2500
0.12
588
VSP1E470MCB6357
100
8×9.7
24
3300
0.12
500
VSP1E101MCB0897
120
8×9.7
22
3500
0.12
600
VSP1E121MCB0897
Part Number
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6311
0807
0808
0811
0816
0820
1012
1016
1020
Size
5×8
6.3×5
6.3×8
6.3×11
8×7
8×8
8×11
8×16
8×20
10×12
10×16
10×20
SMD Code
0557
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F
L
D
Description
High Rated ripple current
Endurance
Low Leakage Current
Low Dissipation Factor
Code
U
E
Description
Convex Rubber
Low ESR
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
SMD CARRIER TAPE DUMENTIONS
Item
Dimension Code
5057 (5x5.7)
6343 (6.3x4.3)
6357 (6.3x5.7)
6377 (6.3x7.7)
6309 (6.3x9)
0867 (8x6.7)
0897 (8x9.7)
08C7 (8x12.7)
1077 (10x7.7)
10C4 (10x12.4)
W
±0.3
16
16
16
16
16
24
24
24
24
24
A
±0.2
5.6
7.0
7.0
7.0
7.0
8.7
8.7
8.7
10.7
10.7
B
±0.2
5.6
7.0
7.0
7.0
7.0
8.7
8.7
8.7
10.7
10.7
F
±0.1
7.5
7.5
7.5
7.5
7.5
11.5
11.5
11.5
11.5
11.5
P
±0.1
12
12
12
12
12
12
16
16
16
16
T
±0.2
6.2
4.7
6.2
8.2
10.0
7.2
10.3
13.2
8.3
13.0
SMD REEL DIMENTIONS AND PACKING QUANTITY
Case Code
Quantity per reel
Quantity per Box※
5057
1200
12000
6343
1500
15000
6357
1200
12000
6377
1000
10000
6309
800
8000
0867
1000
7000
0897
500
3500
08C7
400
2800
1077
500
3500
10C4
400
2800
This may change according to a delivered quantity
W
17.5
25.3
很抱歉,暂时无法提供与“VSP0J221MCB6343”相匹配的价格&库存,您可以联系我们找货
