KBPF205G B0G
KBPF205G B0G
    TAIWANSEMICONDUCTOR(台半)
    SIP4
    BRIDGE RECT 1PHASE 600V 2A KBPF
KBPF205G B0G 数据手册
KBPF204G - KBPF207G Taiwan Semiconductor 2A, 400V - 1000V Glass Passivated Bridge Rectifier FEATURES KEY PARAMETERS ● Ideal for printed circuit board ● Reliable low cost construction utilizing molded plastic technique ● High surge current capability ● UL Recognized File # E-326243 ● Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 400 - 1000 V IFSM 60 A TJ MAX 150 °C Package KBPF Configuration Quad APPLICATIONS ● General purpose use in AC/DC bridge full wave rectification for SMPS, especially for the space constrained appliances applications MECHANICAL DATA ● ● ● ● ● Case: KBPF Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: As marked Weight: 1.4 g (approximately) KBPF ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM KBPF 204G KBPF 204G 400 Reverse voltage, total rms value VR(RMS) 280 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode KBPF 205G KBPF 205G 600 KBPF 206G KBPF 206G 800 KBPF 207G KBPF 207G 1000 420 560 700 UNIT V V IF 2 A IFSM 60 A Rating of fusing ( t
KBPF205G B0G 价格&库存
很抱歉,暂时无法提供与“KBPF205G B0G”相匹配的价格&库存,您可以联系我们找货
