KBPF404G - KBPF407G
Taiwan Semiconductor
4A, 400V - 1000V Glass Passivated Bridge Rectifier
FEATURES
KEY PARAMETERS
● Ideal for printed circuit board
● Reliable low cost construction utilizing molded plastic
technique
● High surge current capability
● UL Recognized File # E-326243
● Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
400 - 1000
V
IFSM
120
A
TJ MAX
150
°C
Package
KBPF
Configuration
Quad
APPLICATIONS
● General purpose use in AC/DC bridge full wave
rectification for SMPS, especially for the space constrained
appliances applications
MECHANICAL DATA
Case: KBPF
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: As marked
Weight: 1.4 g (approximately)
KBPF
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
KBPF
404G
KBPF
404G
400
Reverse voltage, total rms value
VR(RMS)
280
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current, 8.3 ms
single half sine-wave superimposed
on rated load per diode
KBPF
405G
KBPF
405G
600
KBPF
406G
KBPF
406G
800
KBPF
407G
KBPF
407G
1000
420
560
700
UNIT
V
V
IF
4
A
IFSM
120
A
Rating of fusing ( t
很抱歉,暂时无法提供与“KBPF407G B0G”相匹配的价格&库存,您可以联系我们找货
