HC882
HC882 Dual-band Helical Antenna + L-band
Frequency Coverage:
GNSS/QZSS-L1/L2, GLONASS-G1/G2/G3, Galileo-E1/E5b, BeiDou-B1/B2 + L-band correction services
The HC882 helical antenna is designed and crafted for precision positioning, covering
the GPS/QZSS-L1/L2, GLONASS-G1/G2/G3, Galileo-E1/E5b, and BeiDou-B1/B2
frequency bands, including the satellite-based augmentation system (SBAS) available
in the region of operation [WAAS (North America), EGNOS (Europe), MSAS (Japan), or
GAGAN (India)], as well as L-band correction services.
Weighing only 42 g, The HC882 features a precision-tuned helix element that provides
excellent axial ratios and operates without the requirement of a ground plane, making
it ideal for a wide variety of applications, including unmanned aerial vehicles (UAVs).
The HC882 features an industry-leading low current, low-noise amplifier (LNA) that
includes an integrated low-loss pre-filter to prevent harmonic interference from highamplitude signals, such as 700 MHz band LTE and other nearby in-band cellular signals.
All Tallysman® helical antenna elements are protected by a robust military-grade IP67compliant plastic enclosure. The enclosure’s base provides two threaded inserts for
secure attachment, as well as a rubber O-ring around the outer edge to seal the
antenna base and its integrated SMA connector.
Tallysman®’s HC882 has passed a rigorous 30-hour vibration test procedure, consisting
of five cycles of 2-hour tests per axis (x, y, z):
• Cycle 1: 1.05 Grms;
• Cycle 2: 1.20 Grms;
• Cycle 3: 1.35 Grms;
• Cycle 4: 3.67 Grms;
• Cycle 5: 3.67 Grms.
Applications
• Autonomous unmanned aerial vehicles (UAVs)
• Precision GNSS positioning
• Precision land survey positioning
• Mission-critical GNSS timing
• Network timing and synchronization
• Sea and land container tracking
• Fleet management and asset tracking
• Marine and avionics systems
• Law enforcement and public safety
Features
• Very low noise preamp: 1.6 dB typ
• Axial ratio: ≤ 0.5 dB at zenith
• LNA gain 28 dB typ. or 35 dB typ.
• Low current: 15 mA typ. or 21 mA typ.
• ESD circuit protection: 15 kV
• Invariant performance from 2.2 to 16 VDC
• IP67, REACH, and RoHS compliant
About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of
high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission is
to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at
competitive prices. Learn more at www.tallysman.com
Revision:
1.0
Benefits
• Extremely lightweight (42 g)
• Ideal for RTK and PPP surveying systems
• Excellent RH circular polarized signal reception
• Great multipath rejection
• Increased system accuracy
• Excellent signal-to-noise ratio
• Industrial temperature range
• Rugged design, ideal for harsh environments
Contact us:
info@tallysman.com
T: +1 613 591-3131
Frequency Coverage:
Antenna
Low Noise Amplifier (LNA) - Measured at 3.0 VDC and 25°C
Technology
Triple-frequency, RHCP quadrifilar Helix
Frequency Bandwith
Gain
Axial Ratio
dBic typ. at Zenith
dB at Zenith
L1
2.5
≤ 0.5
L2
2.7
≤ 0.5
GNSS
GPS / QZSS
GLONASS
L5
G1
1.5
≤ 0.5
G2
2.0
≤ 0.5
G3
1.0
≤ 0.5
E1
2.5
≤ 0.5
E5a
E5b
1.0
≤ 0.5
E6
B1
2.5
B2
Lower Band
1192 - 1255 MHz
L-band corrections services
1539 - 1559 MHz
Upper Band
1559 - 1606 MHz
Out-of-Band Rejection
> 63 dB @ < 1000 MHz
> 38 dB @ < 1100 MHz
> 30 dB @ < 1130 MHz
> 36 dB @ < 1400 MHz
> 44 dB @ < 1450 MHz
> 28 dB @ > 1700 MHz
Architecture
Pre-filter → LNA
Gain
Noise Figure
2.0 dB typ.
≤ 0.5
VSWR
< 1.5:1 typ. | 1.8:1 max.
1.1
≤ 0.5
Supply Voltage Range
2.2 to 16 VDC
B2a
Supply Current
15 mA (28 dB gain) | 21 mA (35 dB gain)
B3
ESD Circuit Protection
15 kV air discharge
L5
P 1dB Output
L6
Group Delay Variation
1.5
≤ 0.5
Iridium
Globalstar
Galileo
BeiDou
IRNSS / NavIC
QZSS
Mechanical Diagram
Satellite Communications
Phase Centre
Phase Centre Variation (PCV)
± 3.0 mm (all freq.)
Phase Centre Offset (PCO)
34 mm @ L1 | 38 mm @ L2/E5b
Mechanicals
Mechanical Size
44.2 mm (dia.) x 62.4 mm (h.)
Weight
42 g
Available Connectors
SMA
Radome / Enclosure
Radome and Base: EXL9330
Mount
3 M2.5 screws
Environmental
Operating Temperature
-40 °C to +85 °C
Storage Temperature
-50 °C to +95 °C
Random Vibration
MIL-STD-810E - Test method 514.5
4 hours per axis (x, y, z) at 3.674 Grms
Shock and Drop
Salt Fog
IP Rating (housing)
IP67
Compliance
IPC-A-610, FCC, RED / CE Mark, RoHS, REACH
Warranty:
Parts and Labour
3-year standard warranty
Ordering Information
Part Number
where xx = gain (28 or 35 dB)
Please refer to our Ordering Guide to review available radomes and connectors at:
https://www.tallysman.com/resource/tallysman-ordering-guide/
© 2019 Tallysman Inc. All rights reserved. Tallysman, the “When Precision Matters” tag line and the Tallysman logo are trademarks or registered
trademarks of Tallysman Inc. and/or its affiliates in Canada and certain other countries. All other trademarks mentioned in this document are the
property of their respective owners. The information presented is subject to change without notice. Tallysman assumes no responsibility for any
errors or omissions in this document. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind.
Revision:
1.0
33-HC882-xx
www.tallysman.com
很抱歉,暂时无法提供与“33-HC882-35”相匹配的价格&库存,您可以联系我们找货
