TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Product Description
PT6405 combines the high abrasion resistance and non stick properties of the Ultra High
Molecular Weight Polyethylene with the cushioning of a polyurethane foam backing in an easily
applied pressure sensitive form. The tape absorbs shock, dampens noise, and cushions fragile
parts when used as a liner for chutes, bins, and delivery systems. The non stick, low friction,
UHMWPE surfaces speeds conveying and cleans easily. The acrylic pressure sensitive adhesive
applied to the foam backing allows the product to be attached to a broad variety of surfaces.
Application Ideas
PT6405 absorbs shock, dampens noise, and cushions fragile parts.
Technical Data
Property
Backing Material
Adhesive System
Adhesive Thickness (in.)
Max. Operating Temp (F)
Data
Conformable, vibration absorbing PU
foam
Acrylic
0.067
200
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers..
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification
purposes.
5/15/12
很抱歉,暂时无法提供与“PT6405 1X100”相匹配的价格&库存,您可以联系我们找货
