3601-16SQ
3601-16SQ
    TECHSPRAY
    XT-ARMOR OVEN SHIELD
3601-16SQ 数据手册
2017 PRODUCT CATALOG & A  PPLICATION GUIDE Maintenance & Repair Precision Cleaning PCB Assembly Rework & Repair www.techspray.com MAINTENANCE & REPAIR Dusters Techspray dusters blow away dust, microscopic contaminants, lint, metallic oxide deposits and other soils that can cause heat build-up or shorts in sensitive electronics. They are completely portable, ultra-pure, and free of moisture, oil, and other contaminants. • Moisture free • Zero residue • Safe on plastics • Non-ozone depleting • VOC exempt Nonflammable Duster • Nonflammable • Safest choice for energized equipment • Velocity – 11.3 M/s Nonflammable, 100% HFC-134a duster 1671-10S 10 oz. (283g) aerosol 1671-15S 15 oz. (425g) aerosol CAN1671-10S 10 oz. (283g) aerosol Canada compliant packaging CAN1671-15S 15 oz. (425g) aerosol Canada compliant packaging 1671-10S 1671-15S Vortex™ High Velocity Duster Economy Duster High velocity, 100% HFC-134a duster Economical HFC-152a duster • Most powerful blast • Nonflammable • Safest choice for energized equipment • Vortex 360° sprays upside-down • Velocity –14.6 m/s • Best value – 30% more volume • Lower global warming potential – 10% of HFC-134a • Velocity – 11.4 m/s 1673-10S 10 oz. (283g) aerosol 1697-8S Vortex 360° 8 oz. (227g) aerosol 1697-10S 10 oz. (283g) aerosol 1697-8S 1697-10S 1673-10S Renew-Duster 1580-10S Note: not for use on powered electrical equipment, on hot surfaces, and around open flames or sparks. • GWP less than 1/100th of HFC-134a • Nonflammable • Non-ozone depleting • Velocity – 12 m/s 10 oz. (283g) aerosol Dusters DUSTER SELECTION GUIDE 1697-10S Vortex Duster Spray Power Nonflammable 360º Spray GWP* Use On Live Circuits Best Yes No HFC-134a 1300 Yes 1697-8S Vortex 360º Duster Best Yes Yes HFC-134a 1300 Yes 1671 Duster Good Yes No HFC-134a Yes 1673 Economy Duster Good No No HFC-152a 140 1580 Renew-Duster Good Yes No HFO-1234ze 6 * Global warming potential (GWP) is calculated based on a 100 year time horizon. Carbon dioxide has a GWP of 1. 2 Contents 1300 No Yes MAINTENANCE & REPAIR Isopropyl Alcohol (IPA) Techspray has the broadest line of isopropyl alcohol (IPA) in the industry, ranging from aerosol, pre-saturated wipes, and bulk packaging. Two grades of IPA are available: 99.8% anhydrous (containing as little water as possible) for fast-drying cleaning and 70% IPA / 30% DI for stencil and other cleaning when slower evaporation is desired. 70% Bulk – Cleaning Grade IPA 1608-G4 1 gal. (3.8L) container 99.8% Bulk – Technical Grade IPA 1610-P 1610-PT 1610-G1 1610-G4 1610-5G 1610-54G 1 pt. (473mL) bottle 1 pt. (473mL) bottle w/ trigger sprayer 1 gal. (3.8L) bottle 1 gal. (3.8L) bottle sold only 4/cs 5 gal. (19L) container 54 gal. (205L) drum Specs: 99.8% IPA qualified as ACS reagent grade, fed spec TT-1-735A (amend 3, notice 2) grades A&B, ASTM D770-05 1610-5G 1610-PT 1610-P 1608-G4 Pop-up Tubs 70% IPA Wipes 1608-100DSP 1608-100FL 1608-100R 100 wipes in Disposable Tub 100 wipes in Flip-Top Tub 100 wipes refill roll Sealed top reduces waste from dry-out Springloaded lid automatically closes • 5”x8” (127mm x 203mm) wipes • 100 wipes/tub • Lint-free , tear resistant polyester Disposable Tubs 1610-100FL Flip-Top Tubs 1610-100DSP 1608-100DSP 1608-100FL Individually Wrapped Wipes E-Line IPA Electronics Cleaner • 99.8% pure IPA • 5.5”x5.5” (140mm x 140mm) wipes • 50 wipes/box • Lint-free , tear resistant poly-cellulose • 99.8% pure IPA • Compliant with SCAQMD rule 1171 • Plastic safe • Low toxicity • Non-ozone depleting 1610-50PK Isopropyl Alcohol (IPA) 99.8% IPA Wipes 1610-100DSP 100 wipes in Disposable Tub 1610-100FL 100 wipes in Flip-Top Tub 1610-100R 100 wipes refill roll Refill Roll 99.8% IPA in convenient aerosol package 1610-12S 12 oz. (340g) aerosol Specifications for 99.8% IPA: Fed spec TT-1-735A (amend 3, notice 2) grades A&B, ASTM D770-05 3 MAINTENANCE & REPAIR Precision, Safety, Performance . . . Advanced Chemistries to Improve Your Products & Processes. Techspray® offers cutting-edge technologies to improve your processes. Several formulas are available for applications ranging from electronics cleaning to heavy-duty industrial cleaning. POWERFUL, NONFLAMMABLE & COST EFFECTIVE CLEANER • Ideal replacement for n-propyl bromide (nPB) and other toxic industrial solvents • Available in aerosol or bulk for vapor degreasing, ultrasonic and soak applications • PWR-4™ Maintenance Cleaner for heavy-duty degreasing and contact cleaning, PWR-4™ Flux Remover for PCB cleaning NONFLAMMABLE & POWERFUL CLEANER • Top-selling solvent that’s effective on the broadest array of soils • Available in aerosol or bulk for ultrasonic and soak applications Maintenance Cleaners / Contact Cleaners NONFLAMMABLE, POWERFUL & HIGH PRECISION CLEANER • Replacement for AK225, which was banned because of environmental issues • Ideal for aviation, aerospace, medical and military applications • Available in aerosol or bulk for vapor degreasing, ultrasonic and soak applications ECONOMICAL & POWERFUL CLEANER, BUT FLAMMABLE • Effective cleaner, yet safe on sensitive plastics • Available in aerosol or bulk for ultrasonic and soak applications HIGH PERFORMANCE ECO-FRIENDLY CLEANERS • Water-based flux removers with zero GWP and low VOC • Engineered for batch and inline equipment SAFER REPLACEMENTS FOR TOXIC INDUSTRIAL SOLVENTS n-Propyl Bromide (nPB), Trichloroethylene (TCE), and Perchloroethylene (Perc) are three examples of harmful chemicals that are commonly used in aerosol cleaners in industrial applications. These chemicals are commonly used as cleaning solvents because they are nonflammable, have high solvency, and are relatively inexpensive. Because of safety concerns, these solvents are under close scrutiny by OSHA, EPA, and local agencies. For example, The American Conference of Governmental Industrial Hygienists (ACGIH) recommends a 10 ppm time-weighted average threshold limit of nPB, but has proposed a lower 0.1 ppm (ACGIH 2013). That’s because nPB is a suspected human carcinogen, and has shown to negatively impact neurological and reproductive functioning. Techspray offers effective replacements for these toxic solvents. PWR-4® High Performance Solvents provides all the cleaning power of nPB and other industrial solvents, but without the health risks. For more information, read “Toxic Chemicals Used for Industrial Cleaning” white paper at www.techspray.com 4 R-4™ solvent cleaners are ideal where a safer, flammable, and cost effective aerosol cleaner is ired. This innovative cleaner is much safer than our most common industrial solvents: TCE, nPB, and Methylene Chloride and quickly blasts off greases, fluxes, silicones, dirt and grime. MAINTENANCE & REPAIR NTRODUCING PWR-4 ™ OWERFUL NEW ON-FLAMMABLE LEANING SOLVENTS I want to switch to something safer, but need help…I’ve heard that nPB, TCE and some of these other cleaners are not good for us, but everything else is such a price jump! Why can’t I find a strong, safe cleaner at a price we can afford? Degreasers / Contact Cleaners The performance you need at the price you want! Non-flammable Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride Powerful cleaner — Ideal for degreasing and contact cleaning Available in aerosol or bulk for vapor-degreasing, ultra-sonic and bucket cleaning ples available on request. Contact us and start ng today! POWER UP…POWER FORWARD Maintenance Cleaner GET THE JOB DONE SPECS: www.pwr-4.com SAMPLES: 800-858-4043 SCAN FOR MOBILE SITE Blasts away oil and contaminants off of contacts, printed circuit boards, barcode instruments, switch boxes, gear boxes, and electronic motor controllers. Grease and oil flow right off, reducing the time and materials needed to scrub off stubborn soils. • Nonflammable • Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride • Powerful cleaner — Ideal for degreasing and contact cleaning • Available in aerosol or bulk for vapor degreasing, ultrasonic and immersion cleaning • Rapid evaporation • Non-ozone depleting • Cleaning applications: electronics, relays, switches & breakers, transformers, and electric motors and generators 3400-20S 3400-G 3400-5G 3400-54G 3400-5G 20 oz. (567g) aerosol 1 gal. (3.8L) pail 5 gal. (18.9L) pail 54 gal. (204L) drum 3400-20S Maintenance cleaners clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, gear boxes, and engines. P R OP ERTIES Nonflammable Evaporation rate (1=slow, 5=fast) VOC% (EPA) - Aerosol VOC% (EPA) - Bulk VOC% (CARB) - Aerosol VOC% (CARB) - Bulk AP P LI C ATION S Benchtop cleaning Ultrasonic Vapor degreasing Degreasers / Contact Cleaners MAINTENANCE CLEANER SELECTION GUIDE 340 0 PW R-4 Mai 163 nten 0 G3 ance Mai Clea nten 163 ner ance 2 G3 C lean Con er tact 163 Clea 5 G3 n e r Indu stria 163 l Cle 8 G3 ane Univ r ersa 165 l S 1 Pr olve ecis nt ionV 165 2 Pr ecis ionV Pl 285 1-20 astic S PW Safe R 4 Av 164 7-16 iatio n De S Av grea i a t ion 161 ser Deg 0 Ereas LINE er II IPA 162 0 ELINE Mai 162 nten 2 Eance LINE Clea Con ner 162 t act C 1 El e LINE aner Bulk Solv ent Rapid evaporation ● 5 75 75 - ● 5 64 75 - ● 5 64 75 - 4 69 69 - ● ● ● ● ● ● ● 5 61 100 ● 5 37 49 75 100 ● 5 13 18 75 100 ● 5 65 - ● ● 5 3 12.6 75 - 100 75 - 100 4 75 75 - 4 75 75 - 4 100 100 ● ● ● ● ● ● ● ● ● ● ● ● ● ● NOTE: Test for substrate compatibility as a part of your qualification process. * Non-heated ultrasonic only 5 MAINTENANCE & REPAIR Blue Shower Maintenance Cleaner • Nonflammable • Powerful cleaner • Rapid evaporation • Non-ozone depleting • Dielectric strength – 27.3 kv Nonflammable, powerful cleaner Clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, gear relays, and electronic motor controllers. 1630-16S 16 oz. (454g) aerosol Compliant with Boeing D6 17487, Rev T Industrial Maintenance Cleaner • All-in-one electronic maintenance & contact cleaner • Rapid evaporation • Non-ozone depleting • Low toxicity compared to TCE, nPB & Perc • Dielectric strength – 30.5 kv High power, fast evaporating maintenance cleaner Blast away heavy oils and greases off of metal parts, gear boxes, and engines. 1635-20S 20 oz. (567g) aerosol Universal Cleaner Nonflammable, powerful liquid cleaner Engineered to remove oils, fluxes and other contamination using a manual soak cleaning process or ultrasonic equipment. Degreasers / Contact Cleaners 1638-G 1638-5G 1638-54G 6 1 gal. (3.8L) pail 5 gal (19L) pail 54 gal. (205L) drum 1638-G Contact Cleaner Nonflammable, powerful contact cleaner Clean oxidation, oil, and other contaminants from contacts, metal switches, relays, edge connectors, buss bars, and circuit breakers. 1632-16S 16 oz. (454g) aerosol Flux Remover & Maintenance Cleaner Nonflammable and powerful precision cleaner Clean off flux residues, oil, and other contamination from electronics and other sensitive surfaces. 1651-16S 1651-G 1651-5G 1651-54G 16 oz. (454g) aerosol 1 gal. (3.8L) pail 5 gal. (19L) pail 54 gal. (205L) drum 1638-5G • Nonflammable • Powerful cleaner • Effective as maintenance cleaner and flux remover • Rapid evaporation • Non-ozone depleting • Dielectric strength – 27.3 kv • Nonflammable • Powerful cleaner • Rapid evaporation • Non-ozone depleting • Dielectric strength – 36.2 kv Compliant with Boeing D6 17487, Rev T • Nonflammable • Low VOC • Safe on most plastics • High precision – residue-free • Rapid evaporation • Non-ozone depleting Plastic-safe, nonflammable cleaner for sensitive electronics Engineered for use on sensitive plastic electronic components, packaging and casements. 1652-10S 1652-G 10 oz. (284g) aerosol 1 gal. (3.8L) pail • Nonflammable • Low VOC • Safe on sensitive plastics • High precision – residue-free • Rapid evaporation • Non-ozone depleting • Dielectric strength – 23 kv Specifications: NESHAP 63.741-753 MAINTENANCE & REPAIR Plastic-Safe Universal Cleaner Specialized Degreasers for Aviation and Aircraft Parts I want to switch to something safer, but need help…I’ve heard that nPB, TCE and some of these other cleaners are not good for us, but everything else is such a price jump! Why can’t I find a strong, safe cleaner at a price we can afford? INTRODUCING PWR-4 ™ POWERFUL NEW NON-FLAMMABLE CLEANING SOLVENTS PWR-4™ solvent cleaners are ideal where a safer, non-flammable, and cost effective aerosol cleaner is required. This innovative cleaner is much safer than the four most common industrial solvents: TCE, nPB, Perc and Methylene Chloride and quickly blasts off oils, greases, fluxes, silicones, dirt and grime. These specially engineered aviation degreasers quickly remove hydraulic fluid, fuel oils, lubricating oils and greases, and other organic residues. They are fast evaporating, quick penetrating, and ideal for cleaning aviation parts. Both are free of hazardous air pollutants (HAPs), and CARB compliant. The performance you need at the price you want! • Non-flammable • Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride • Powerful cleaner — Ideal for degreasing and contact cleaning • Available in aerosol or bulk for vapor-degreasing, ultra-sonic and bucket cleaning • Rapid evaporation Samples available on request. Contact us and start testing today! POWER UP…POWER FORWARD Aviation Degreaser GET THE JOB DONE SPECS: www.pwr-4.com SAMPLES: 800-858-4043 Exceptional nonflammable cleaner for aircraft parts degreasing SCAN FOR MOBILE SITE 2851-20S 20 oz (567g) aerosol Aviation Degreaser II NESHAP compliant cleaner for removing hydraulic and lubricating fluids 1647-16S 16 oz. (454g) aerosol Specifications: Meets Boeing D6 17487, Rev T, NESHAP 63.741-753 Degreasers / Contact Cleaners Specifications: Meets Airbus UK ABR9-0140 General Purpose Cleaning Solvent, FedEx CPN 0311737, Boeing D6 17487, Rev T • Nonflammable • Fast evaporation • Zero residue • Non-ozone depleting • Does not contain n-propyl bromide • Dielectric breakdown of 13.7 kV • CARB compliant • Nonflammable • Low VOC / NESHAP compliant • Fast evaporation • Zero residue • Non-ozone depleting • Does not contain n-propyl bromide • Dielectric breakdown of 11.9 kV • CARB compliant More Choices for Aviation Cleaning: Compliant with Boeing D6 17487, Rev T: G3 Blue Shower Maintenance Cleaner (1630-16S) G3 Blue Shower Contact Cleaner (1632-16S) 7 MAINTENANCE & REPAIR Blue Shower Maintenance Cleaner • Powerful cleaner • Ideal for sensitive plastics • Low toxicity • Non-ozone depleting Powerful and economical aerosol cleaner Clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, gear boxes, and engines. 1620-10S 10 oz. (284g) aerosol Flux Remover & Maintenance Cleaner • Effective as maintenance cleaner and flux remover • Ideal for sensitive plastics • For cold cleaning and ultrasonic (unheated only) • Non-ozone depleting Powerful and economical liquid cleaner Engineered to remove oils, fluxes and other contamination using soak cleaning process or ultrasonic equipment. 1621-G 1 gal. (3.8L) pail 1621-5G 5 gal (18.9L) pail 1621-54G 54 gal. (204L) drum 1621-G 1621-5G Contact Cleaner • Powerful cleaner • Ideal for sensitive plastics • Low toxicity • Non-ozone depleting Powerful and economical electronic contact cleaner Clean oxidation, oil, and other contaminants from contacts, metal switches, relays, edge connectors, buss bars, and circuit breakers. 1622-10S 1622-13S 10 oz. (284g) aerosol 13 oz. (369g) aerosol 1622-10S Degreasers / Contact Cleaners IPA Electronics Cleaner 8 99.8% IPA in convenient aerosol package Ideal for defluxing, stencil cleaning and fiber optic connector cleaning. 1610-12S 12 oz. (340g) aerosol 1622-13S • 99.8% pure IPA • Compliant with SCAQMD rule 1171 • Plastic safe • Low toxicity • Non-ozone depleting Specifications for 99.8% IPA: Fed spec TT-1-735A (amend 3, notice 2) grades A&B, ASTM D770-05 Zero-VOC General Purpose Cleaner General purpose remover of adhesives and coatings Ideal for heavy-duty degreasing and for removing paint, coatings and sticky adhesive residues. Because it is VOC-free, there are no VOC restrictions – even in southern California! 1611-P 1 pt. (473mL) can • Pure acetone • Ideal for removing inks & adhesives • VOC exempt • Low toxicity • Fast evaporation • Non-ozone depleting Note: test first on plastics and painted surfaces to check for compatibility. Eco-friendly, nonflammable, streak-free glass cleaner • Streak-free • Nonflammable • Non-ammoniated – safe on sensitive surfaces • Low VOC, no GWP • Non-ozone depleting Cleans glass, stainless steel, chrome, mirrors, tile, plastic, ceramic and enamel and leaves a streak-free finish. 1505-QT 1505-G 1 qt. (0.95L) w/ trigger sprayer 1 gal. (3.8L) jug 1505-QT MAINTENANCE & REPAIR Eco-Shine™ Glass & Surface Cleaner Glass Cleaner Foaming aerosol glass and surface cleaner 1625-18S • Foaming action • Streak-free • Safe on glass & plastics • Nonflammable 18 oz. (510g) aerosol Specifications: GM H1018, Ford Tox #142432 Roller Rejuvenator & Platen Cleaner Rubber roller cleaner and rejuvenator • Improves roller grip • Natural citrus-based solvent • Safe on most plastics Citrus-based solvent designed to clean and revitalize rubber rollers and platens. Improves rubber roller grip and reduces misfeeds and jams. 1612-2SQ Specifications: Ford Tox #142415 Note: Not available in California 2 oz. (59ml) bottle Label & Adhesive Remover Citrus-based solvent safely and effectively removes labels and adhesive gums off equipment and products. Penetrates quickly and allows label to be peeled off without gummy residue. 1613-6S Glass Cleaners / Adhesives • Removes labels and adhesive without scraping • Penetrates rapidly • Citrus-based solvent • Safe on most plastics Fast acting, citrus-based label and adhesive remover Note: Not available in California 4.5 oz. (128g) aerosol Adhesives • High strength • Fast tacking • Water resistant • Non-wrinkling Low soak-in adhesive exhibits particular strength when bonding surfaces such as dry wall, brick and concrete block. Heavy Duty Adhesive will also work on surfaces such as paper, plastic, foam, wood and other fabrics. Excellent for both temporary and permanent bonds. Heavy-Duty Adhesive 3500-11S 12 oz. (340g) aerosol Economy Adhesive 3505-11S 12 oz. (340g) aerosol Contact Adhesive 3510-12S 12 oz. (340g) aerosol 3500-11S 3510-12S 3505-11S 9 PRECISION CLEANING Flux Removers Flux removers (defluxers) remove flux residues and other contaminants left by manufacture, rework, or repair of printed circuit boards. Residues from higher, lead-free temperatures are more baked on and harder to clean. PWR-4™, G3®, E-LINE™ and Precision-V™ flux removers have been proven very effective at removing fluxes baked on at lead-free temperatures. Micro-components and fine pitch leads are delicate and easily damaged, so brushing and scrubbing should be avoided if possible. Both G3, E-LINE™ and Precision-V have a powerful spray and strong solvent that blasts off residues and cleans areas under components that a brush cannot touch. Techspray offers traditional solvent-based cleaners and cutting edge water-based technologies marketed under the Techspray Renew™ brand. All Techspray flux removers have the following advantages: • Help create bright, shiny solder joints • Improve PCB reliability • Prevent conformal coating defects • Prevent corrosion from contamination • RoHS compliant TECHSPRAY RENEW™ branded cleaners are innovative solutions that combine the best of current “green” technologies to make the most powerful eco-friendly cleaners on the market. Flux Removers 340 1 PW R-4 Flux 163 Rem 1 G3 over Flux Rem 163 over 4 G3 NoC lean 163 Flux 8 G3 Rem Bulk over Solv 165 e nt 1 Pr ecis ionV 164 9 Pr ecis ionV No 165 2 Pr -Cle ecis an F ionlux R V 161 P emo lasti 0 Ever c-Sa LINE f e IPA 162 1 ELINE Flux 155 Rem 0 Ec over o- d Flux er S 152 MT1 0 Ec o- d 00 Flux er S 153 MT2 0 Ec o- d 00 Flux er S MT3 00 FLUX REMOVER SELECTION GUIDE P ROPERTIES Nonflammable Evaporation rate (1=slow, 5=fast) VOC% (EPA) - Aerosol VOC% (EPA) - Bulk VOC% (CARB) - Aerosol VOC% (CARB) - Bulk APPLIC ATIONS Benchtop cleaning Ultrasonic Vapor degreasing Inline defluxing system Batch defluxing system ● 5 73 95 70 100 ● 5 64 75 - ● 5 64 75 - ● 5 61 100 ● 5 37 49 75 100 ● 5 64 75 - ● 5 13 18 75 100 3 75 100 75 100 4 75 75 - ● 1 45 45 ● 1 22 52 ● 1 52 22 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● NOTE: Test for substrate compatibility as a part of your qualification process. * Non-heated ultrasonic only + Rinse required 10 I want to switch to something safer, but need help…I’ve heard that nPB, TCE and some of these other cleaners are not good for us, but everything else is such a price jump! Why can’t I find a strong, safe cleaner at a price we can afford? R-4™ solvent cleaners are ideal where a safer, -flammable, and cost effective aerosol cleaner is uired. This innovative cleaner is much safer than four most common industrial solvents: TCE, nPB, and Methylene Chloride and quickly blasts off greases, fluxes, silicones, dirt and grime. Solvent Defluxers The performance you need at the price you want! Non-flammable Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride Powerful cleaner — Ideal for degreasing and contact cleaning Available in aerosol or bulk for vapor-degreasing, ultra-sonic and bucket cleaning Rapid evaporation ples available on request. Contact us and start ing today! Flux Remover POWER UP…POWER FORWARD GET THE JOB DONE Powerful, nonflammable and cost effective cleaner SPECS: www.pwr-4.com SAMPLES: 800-858-4043 SCAN FOR MOBILE SITE Cleans away flux residues and other contaminants in vapor cleaning and ultrasonic application. Easily removes residues from high temperature lead free soldering operations, no-clean fluxes and all handling soils. 3401-G 3401-5G 3401-54G 1 gal. (3.8L) pail 5 gal. (18.9L) pail 54 gal. (204L) drum 3401-5G 3401-G Flux Remover • Nonflammable • Powerful cleaner • Proven effective for lead-free processes • All-in-one cleaner and defluxer • Rapid evaporation • Non-ozone depleting Strong and fast-acting flux remover Remove flux residues and other contaminants left by manufacture, rework, or repair of printed circuit boards. 1631-5S 5 oz. (142g) aerosol w/brush attachment 1631-16S 16 oz. (454g) aerosol 1631-16SB 16 oz. (454g) aerosol w/brush attachment • Nonflammable • Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride • Powerful cleaner - Effective on R, RMA & no-clean fluxes • Available in bulk for vapor degreasing, ultrasonic and immersion cleaning • Rapid evaporation • Non-ozone depleting PRECISION CLEANING NTRODUCING PWR-4 ™ OWERFUL NEW ON-FLAMMABLE LEANING SOLVENTS 1631-5S 1638-5G 1631-16S 1631-16SB No-Clean Flux Remover • Nonflammable • Ideal for no-clean fluxes • Proven effective for lead-free processes • Rapid evaporation • Non-ozone depleting Strong and fast-acting no-clean flux remover Remove no-clean flux and white residues left by manufacture, rework, or repair of printed circuit boards. 1634-12S 12 oz. (340g) aerosol Nonflammable, powerful liquid cleaner Engineered to remove oils, fluxes and other contamination from electronics using a manual soak cleaning process or ultrasonic equipment. 1638-G 1638-5G 1638-54G 1 gal. (3.8L) pail 5 gal (19L) pail 54 gal. (205L) drum 1638-G 1638-5G • Nonflammable • Powerful cleaner • Effective as maintenance cleaner and flux remover • Rapid evaporation • Non-ozone depleting • Dielectric strength – 27.3 kv Solvent Defluxers Universal Cleaner 11 FPO PRECISION CLEANING No-Clean Flux Remover • Effective on R, RMA, no-clean and OA fluxes • Nonflammable • Non-ozone depleting • Rapid evaporation with no residue • Safe on most plastics Nonflammable and powerful cleaner for the toughest flux residues Engineered to cut flux residues from the most difficult-to-clean processes. Removes lead-free and no-clean residues, and white residues left by manufacturing, rework, or repair of circuit boards. 1649-12S 12 oz. (340g) aerosol Flux Remover & Maintenance Cleaner • Nonflammable • Low VOC • High precision – residue-free • Rapid evaporation • Non-ozone depleting • Safe on most plastics Nonflammable and powerful precision cleaner Formulated to reduce VOCs within your facility. Ideal for aviation and other applications where strict VOC caps apply (based on EPA VOC exemptions). Bulk chemicals ideal for soak cleaning and ultrasonics (not intended for vapor degreaser). 1651-16S 1651-G 1651-5G 16 oz. (454g) aerosol 1 gal. (3.8L) pail 5 gal. (19L) pail 1651-16S Plastic-Safe Universal Cleaner • Nonflammable • Low VOC • Safe on sensitive plastics • High precision – residue-free • Rapid evaporation • Non-ozone depleting Plastic-safe, nonflammable cleaner for sensitive electronics Plastic-safe formula is engineered for use on sensitive plastic components, packaging and casements. Ideal for optics cleaning, critical electronics and other sensitive surfaces. Qualifies under the aerospace NESHAP VOC guidelines. 1652-10S 1652-G 10 oz. (283g) aerosol 1 gal. (3.8L) pail Specifications: NESHAP 63.741-753 1652-10S Flux Remover & Maintenance Cleaner • Powerful cleaner • Proven effective for leadfree processes • Ideal for sensitive plastics Powerful and economical flux remover Solvent Defluxers Hydrocarbon-based defluxer formulated to be powerful, yet very economical. Eliminates brushing and scrubbing, saving time and materials. 1621-10S 1621-10SB 1621-G 1621-5G 1621-54G Specifications: GM H1013; USDA Accepted; Ford Tox #142431, USDA: Approved K-2 rated aerosol and bulk. 1621-G 1621-5G 1621-10S 1621-10SB Envi-Ro-Tech™ Defluxer Alcohol-based flux remover and maintenance cleaner Alcohol-based general duty defluxer and all-purpose cleaner for light oils, silicones, handling soils and other contaminants found in electronics manufacturing. 1679-PT 12 10 oz. (283g) aerosol 10 oz. (283g) aerosol w/brush attachment 1 gal. (3.8L) can 5 gal (19L) pail 54 gal (205L) drum 1 pt. (473mL) bottle w/trigger sprayer • Convenient and easy-to-use trigger sprayer • Safe on plastics • Ideal for removing handling soils PROCESS CLEANING Vapor Degreaser Solvents Techspray offers a wide variety of vapor degreaser formulas engineered to meet challenging requirements like cleanliness specifications, difficult-to-clean soils, solvent-sensitive materials, and restrictive regulations. All Techspray solvents have azeotropic properties that allow them to remain stable as they are cycled in a vapor degreaser. They are not reactive or corrosive to metals commonly found in the construction of vapor degreasers. PWR-R™ solvents are designed to replace nPB, TCE and Perc, matching and surpassing cleaning performance without the safety concerns. Precision-V™ vapor degreaser solvents are ideal replacements for AK-225 based cleaners, which were phased out due to the ozone depletion restrictions of the Montreal Protocol. To order, add the following to the part # shown in the chart below: -1G for 1 gal. (3.8L) -5G for 5 gal. (19L) -54G for 54 gal. (205L) 54 gallons 5 gallons 1 gallon 1654 1655 1656 1686 1680 1681 3400 3401 Product Name VC-1200 VC-1500 VC-1600 ME-1500 AE-1000 AE-1400 PWR4 Maintenance Cleaner PWR4 Flux Remover ND=Not Defined Base kB Solvents value DuPont Vertrel® XF 56 DuPont Vertrel® XF 62 DuPont Vertrel® XF 100 3M Novec 7100/7200 58 Asahi AE3000 ~0 ND Asahi AE3000 3M Novec 7100 100 3M Novec 7100 100 Boiling Point (°F/°C) 94/34 90/32 106/41 104/40 133/56 139/54 118/48 118/48 VOC Plastic(g/l) GWP Degreasing Defluxing Safe 552 684 ● 562 663 ● 1063 264 ● 889 43 ● ● ND 540 ● ND 540 ● ● ● 1201 ND ● 1201 ND ● Vapor Degreaser Solvents Part # 13 PRECISION CLEANING HIGH PERFORMANCE ECO-FRIENDLY CLEANERS Water-Based Defluxers Eco-dFluxer Water-based Inline & Batch Flux Removers Eco-dFLuxer cleaners are water-based, environmentally friendly and designed to work in both inline and batch cleaning equipment. They are optimal combinations of solvents and saponifiers that lower surface tension for penetration under low stand-offs, and powerful cleaning action to remove all flux residues. Effective on a wide variety of solders and fluxes: lead, leadfree, aqueous, RMA, no-clean, and new halide-free fluxes. High compatibility with common PCB metals and plastics. Eco-dFluxer cleaners are highly filterable with long bath life. High performance cleaning gives you brilliant solder joints and allows you to increase dilution, increase line speeds, reduce waste water, decrease cost per board, and most importantly… eliminate field failures due to ionic contamination! • High performance cleaning • Nonflammable • Low VOC, zero GWP • Also used for pallet cleaning in batch systems Eco-dFluxer SMT100 Water-Based Defluxers Powerful defluxer, allowing you to optimize your cleaning process. Reduce concentration and increase line speed to maximize your profit. Effective on no-clean, R, RMA and OA fluxes. 14 1550-G 1550-5G 1550-54G 1 gal. (3.8L) bottle 5 gal. (19L) container 54 gal. (205L) drum 1550-5G 1520-G 1530-G Eco-dFluxer SMT300 Powerful defluxer but safe on sensitive metals, preventing oxidation and leaving shiny solder joints. Safe, eco-friendly formula. Effective on no-clean, R, RMA, OA fluxes and new halide-free fluxes. 1530-G 1530-5G 1530-54G 1 gal. (3.8L) bottle 5 gal. (19L) container 54 gal. (205L) drum Defoamer DF1 Defoaming Agent for Inline & Batch Cleaners Eco-dFluxer SMT200 Reduce foaming as cleaner becomes loaded to extend bath life. Add directly to sump at 1 to 4 fl oz. (30-120ml) per 100 gallons (379L). Dilute in spray bottle to 15% with DI water to eliminate foaming issue on the spot. Superior metals compatibility, preventing oxidation and leaving shiny solder joints. Eco-friendly formula reduces shipping and disposal costs. Effective with reduced concentration even on the toughest noclean, R, RMA, OA and new halide-free fluxes. • Effective at all processing temperatures • Extends bath life • Silicone & particulate free • Nonflammable 1520-G 1520-5G 1520-54G 1 gal. (3.8L) bottle 5 gal. (19L) container 54 gal. (205L) drum 1555-P 1 pt. (473mL) container PCB ASSEMBLY HIGH PERFORMANCE ECO-FRIENDLY CLEANERS Stencil Cleaners Eco-Stencil UM Manual & Under Stencil Cleaner • Quickly clean paste or uncured adhesive • Safe for stencils, tools, misprinted boards • Nonflammable • Low VOC, zero GWP Applications: • Manual stencil tool, work surface, and squeegee cleaning • Automatic underside wipe stencil cleaning • Batch ultrasonic cleaning • Removes unsoldered leaded & lead-free solder pastes • Cleans off uncured adhesives 1570-100DSP 1570-QT 1570-G 1570-GX10 100 count pre-saturated wipes, 6"x8” (15cm x 20cm) 1qt. (0.95L) w/ trigger sprayer 1 gal. (3.8L) bottle 1 gal. (3.8L) concentrate makes 10 gallons (38L) 1570-QT Eco-Stencil AQ Water-Based Batch Stencil Cleaner 1572-G 1572-5G 1572-54G 1570-G 1570-100DSP • For use in batch stencil cleaners with automatic or manual rinse • Nonflammable • Low VOC, zero GWP • Highly concentrated – 10% dilution 1 gal. (3.8L) bottle 5 gal. (19L) container 54 gal. (205L) drum 1572-G Eco-Stencil RF Rinse-Free Batch Stencil Cleaner • Nonflammable • Rinse-free • Drop in replacement for IPA • Effective at ambient temperature • Low VOC, zero GWP • Highly concentrated - 20% dilution 1571-5G 1571-G Stencil Cleaners 1571-G 1 gal. (3.8L) bottle 1571-5G 5 gal. (19L) container 1571-54G 54 gal. (205L) drum 15 PCB ASSEMBLY Reflow Oven Maintenance Eco-Oven Reflow Oven, Wave Finger & Pallet Cleaner • Quickly clean flux residue from oven & wave fingers • Safe on warm ovens • Nonflammable • Low VOC, zero GWP Applications: • Removal of baked-on flux residues from SMT oven and wave equipment • Maintenance cleaning for heat exchange systems (NOTE: rinse thoroughly from aluminum and copper) • Finger cleaning in wave solder equipment • Remove accumulated flux from wave solder pallets 1573-QT 1573-G 1573-5G 1573-G 1573-QT 1 qt. (0.95L) w/ trigger sprayer 1 gal. (3.8L) bottle 5 gal. (19L) container Wave fingers XT-Armor™ Oven Shield Reflow Oven & Wave Maintenance Coating XT-Armor™ Oven Shield Reflow Oven & Wave Maintenance Coating is a water-based, environmentally friendly coating that is designed to protect PCB assembly equipment from flux residues. Flux sticks to the coating surface and then peels off – drastically reducing maintenance time. XT-Armor Oven Shield has been tested and proven compatible with all of the most popular oven and wave equipment: BTU, Heller, JTU, SMT, Speedline and Vitronics-Soltec. Reflow Oven Maintenance • Coating & flux residues peel off easily • Cures during equipment heat-up cycle • Low odor, non-hazardous, nonflammable • Easy wash-up with water • Environmentally friendly – zero VOC, zero GWP • Halide-free – prevent ionic contamination 16 3601-G 3601-16SQ Applications: • Protect cooling zones of reflow oven • Coat around wave fluxer • Coat top of wave pallet • Mask overspray area in coating spray booth 3601-16SQ 3601-G PROBLEM: Cleaning requires over 8 hours of machine downtime and man hours, with harsh chemicals, brushes and scrapers. SOLUTION: Flux contamination simply peels off, reducing downtime by 25% and labor by 50%. 16 fl. oz. (473mL) squeeze bottle 1 gal (3.8L) bottle PCB ASSEMBLY ESD Products Permanent ESD Coating • Rugged static dissipative coating • Surface resistivity of 106 To 109 ohms • Operating temperature range – up to 302°F (155°C) • Humidity independent • Superior adhesion to variety of surfaces: glass, plastic, etc. • Non-ozone depleting 1756-8S 1756-G 8 oz. (226g) aerosol (coats up to 200ft2) 1 gal. (3.8L) jug 1756-8S Zero Charge Anti-Stat Coating Zero Charge Mat & Tabletop Cleaner Anti-static coating for fabrics & flexible surfaces Safe, effective cleaner for ESD mats • All-purpose static control • For plastics, fabrics, and carpet • Fast drying • Nonflammable • Rejuvenates ESD-safe mats • Will not dry out surfaces • Leaves no insulative film • Nonflammable • No ammonia • Non-corrosive 1726-QT 1 qt. (.95L) bottle with trigger sprayer 1733-QT 1733-QT 1 qt. (.95L) bottle with trigger sprayer 1733-G 1 gal. (3.8L) bottle Zero Charge® ESD-Safe Floor Coating Zero Charge Hand Lotion ESD-safe floor coating Non-contaminating hand lotion for ESD sensitive environments • Resistivity between 10 To 10 • Effective in low humidity • High gloss polymer • Zinc free • Slip resistant 6 1720-G 1720-5G 10 • Improves wrist and heel strap contact • Does not contain silicone or lanolin • Non-contaminating — does not interfere with soldering • Non-greasy 1 gal. (3.8L) bottle (coats @1,200 ft2) 5 gal. (19L) pail (coats @6,000 ft2) 1702-8FP 8 fl. oz. (237ml) bottle with finger pump 1702-G 1 gal. (3.8L) bottle 1702-8FP 1720-G Cleans surfaces and leaves behind dissipative residue 1743-50PK 1743-QT • Cleans plastic & glass • Leaves ESD-safe coating • Leaves no insulative film • Nonflammable • Non-corrosive 50 pre-saturated wipes in packets 1 qt. (.95L) bottle w/trigger sprayer 1743-50PK ESD Products Zero Charge Screen & Keyboard Cleaner 1743-QT 17 PCB ASSEMBLY Conformal Coatings Techspray offers a variety of coating formulas to match field and engineering requirements. Specifications generally depend on the type of protection needed: e.g. thermal, moisture, and static resistance (see reference chart). Application method considerations: Dip – High volume method to fully coat boards. Thickness of final coating is controlled by viscosity and withdrawal speed from the pot. Selective spray system – Computer controlled selective spray systems, eliminate the need for masking. Higher viscosity than full coverage sprayer is generally needed (70-200 cps) to create precise edge definition and prevent splattering. Manual Application – Aerosol and brushing are generally used for small production runs, rework and repair. If using for rework, the aerosol needs to be compatible with the original coating. FINE-L-KOTE™ SR • UL recognized • Thermal resistance — to 392°F (200°C) • Dielectric strength — 1100 volts/mil • Moisture resistant • Chemically resistant • Vibration resistant — flexible Silicone coating that’s ideal for moisture and vibration protection Standard Viscosity — 4-10 CPS 2102-12S 12 oz. (355ml) aerosol 2102-P 1 pt. (473mL) can 2102-G 1 gal. (3.8L) can 2102-5G 5 gal. (19L) pail Specifications: Meets or exceeds MIL-I-46058C Type SR and IPC-CC-830B. UL94 V-0 rated. High Viscosity — 60-90 CPS 2102-GHV 1 gal. (3.8L) pail Conformal Coatings 2102-12S 18 FINE-L-KOTE™ HT • Designed for high temperature environments • Fast-drying silicone – 1-step process • Thermal resistance – to 662°F (350°C) • Dielectric strength – 560 volts/mil • Moisture resistant • Vibration resistant – flexible Silicone coating engineered for superior thermal and moisture resistance 2106-12S 2106-G 12 oz. (355ml) aerosol 1 gal. (3.8L) can Specifications: Meets or exceeds MIL-I-46058C Type SR and IPC-CC-830B. UL94 V-0 rated. 2106-12S PCB ASSEMBLY NEW! FINE-L-KOTE™ LED Silicone conformal coating designed to coat over LEDs • Fully transparent - will not block or change light intensity or wavelength • Protects against adverse environments • Flexibility prevents cracking • Resists moisture, salt, fungus and corrosive vapors from severe environments • Withstands high heat from PCB and operating environment Coat directly over LEDs without the time and expense of masking. Optical clarity prevents light from diffusing, scattering, or changing wavelength. Fine-L-Kote LED provides maximum protection from extreme temperatures on the flexible and rigid PCBs found in LED displays. 2120-P 2120-G 2120-5G 2120-5G 1 pt. (473mL) can 1 gal. (3.8L) can 5 gal. (19L) pail 2120-G CONFORMAL COATING SELECTION GUIDE 2108 Turbo-Coat 2109 Turbo-Coat HV 2102 Fine•L•Kote SR 2102 HV Fine•L•Kote SR 2106 Fine•L•Kote HT 2104 Fine•L•Kote UR Optically Clear Economical With Fastest Cure Economical With Fastest Cure Moisture & Vibration Resistant Moisture & Vibration Resistant High Operating Temperature Durable & Chemically Resistant ●  ●  ● ● ● ●  ●  ●   ● NO ● ● YES  ● USE 2108-12S  ● YES ● ● USE 2102-12S ● ● YES ● ● YES  ●   ● ● ● ● Chemical Resistant Vibration Resistant Ease of Rework ● ● ●   ●   ● ● ● ● ● ● ● ● ● ● ●   Tack Free Time (minutes) 60 3 9 60 60 45 15 Accelerated Cure Time/Temp 2 Step 30 Min.@ 32°C 45 Min.@ 93°C 1 Step 20 Min.@ 65°C 1 Step 55 Min.@ 55°C 2 Step 30 Min.@ 32°C 45 Min.@ 93°C 2 Step 30 Min.@ 32°C 45 Min.@ 93°C 1 Step 15 Min.@ 49°C 2 Step 20 Min.@ 49°C 30 Min.@ 82°C Ambient Cure Time Mil-I-46058C / 72 Hrs.
3601-16SQ 价格&库存
很抱歉,暂时无法提供与“3601-16SQ”相匹配的价格&库存,您可以联系我们找货
